device
hmc5883l
rtt-package
rtt使用hmc5883l磁力计的包,获取的3轴数据一直为0,是读取不到?
发布于 2021-01-23 17:56:52 浏览:1431
![捕获.PNG](https://oss-club.rt-thread.org/uploads/20210123/70ba84ba19d3a50094b25c74c0e3c6d8.png) 使用I2c1总线,mpu6050,bpm180,hmc5983l,除了hmc5983其他两个传感器都能读出数据。初始化,注册设备都没有问题。就是hmc5983读出的数据为0(无论是命令行读取还是代码读取),.在arduino中可以读出三轴数据,排除设备坏掉了。 代码: main.c(其他的mpu6050和bmp180的代码我没贴) : ```/* * Copyright (c) 2006-2018, RT-Thread Development Team * * SPDX-License-Identifier: Apache-2.0 * * Change Logs: * Date Author Notes * 2018-11-06 SummerGift first version */ #include
#include "sensor_inven_mpu6xxx.h" #include
#include "bmp180.h" #include "sensor_intf_hmc5883.h" #define DBG_TAG "main" #define DBG_LVL DBG_LOG //debug led #define LED0_PIN GET_PIN(A,8) //i2c_bus #define I2C_BUS_NAME "i2c1" rt_thread_t mpu6050_thread,hmc5983_thread,bmp180_thread,pwm_thread; static void read_hmc5983_entry(void *parameter); int main(void) { //hmc5983 hmc5983_thread = rt_thread_create("hmc_pro", read_hmc5983_entry, I2C_BUS_NAME, 1024, RT_THREAD_PRIORITY_MAX / 2, 20); if (hmc5983_thread != RT_NULL) { rt_thread_startup(hmc5983_thread); } return RT_EOK; } static void read_hmc5983_entry(void *parameter) { rt_device_t dev = RT_NULL; struct rt_sensor_data sensor_data; rt_size_t res; dev = rt_device_find("mag_hmc"); if (dev == RT_NULL) { rt_kprintf("Can't find device:%s\n", "mag_hmc"); return; } if (rt_device_open(dev, RT_DEVICE_FLAG_RDWR) != RT_EOK) { rt_kprintf("open device failed!\n"); return; } while (1) { res = rt_device_read(dev, 0, &sensor_data, 1); if (res != 1) { rt_kprintf("read data failed!size is %d\n", res); rt_device_close(dev); return; } else { //rt_kprintf("hmc5983l:%d,%d,%d,%5d\n",sensor_data.data.mag.x, sensor_data.data.mag.y, sensor_data.data.mag.z, sensor_data.timestamp); } rt_thread_mdelay(100); } } //初始化hmc5983 //init hmc5983 static int rt_hw_hmc5983_port(void) { struct rt_sensor_config cfg; cfg.intf.dev_name = "i2c1"; /* i2c bus */ cfg.intf.user_data = (void *)HMC5883_ADDR; /* i2c slave addr */ rt_hw_hmc5883_init("hmc",&cfg); return RT_EOK; } INIT_ENV_EXPORT(rt_hw_hmc5983_port); ```
红枫
2021-01-24
看看i2c总线是否有上拉电阻
manipulators
2021-01-24
上拉了还是一样,使用电阻阻值1: vcc->1K->scl,vcc->1K->sda和2: vcc->2.2K->scl,vcc->2.2K->sda
iamyhw
2021-01-24
官方文档的IIC例子就是读传感器的,贴出代码给大家看看,或许能找到问题
1.4k
manipulators
usb device 驱动始终是叹号
SystemView的SEGGER_RTT_Device.c是干嘛的?
stm32f10x USB device 编译错误
stm32f107使用usb device的问题?
rtthread的代码里,drivers和devicedrivers有什么联系?
rtthread smart 下可以使用原来的 device 框架吗
请问Nano版怎样使用device接口?
device线程问题
RT-Thread新建项目
NXP MCXN947测评之 adc
