IAP_在线更新
如何确定文件在flash中的物理地址
发布于 2021-02-18 21:47:17 浏览:1172
目前在自行编写调试bootloader,希望复制download分区的os.bin文件到app分区,可否使用memcpy函数直接进行复制?是否有其他便利方式进行文件复制? ####1. Flash分区见下图 ![f307c484e6f82c76b80354a281b5c3fb.png](https://oss-club.rt-thread.org/uploads/20210218/f307c484e6f82c76b80354a281b5c3fb.png) ####2. os.bin文件是通过ymodem下载到download分区,下载时分区内已经有其他文件
ericwang215
2021-02-19
已解决,可以参考如下代码。 ``` #include
#include "dfs_file.h" #include
#define DBG_TAG "ota" #define DBG_LVL DBG_INFO // DBG_LOG, DBG_INFO, DBG_WARNING, DBG_ERROR #include
// this line must after -> #define DBG_TAG #define DATA_PARTITION_NAME "download" #define APP_PARTITION_NAME "app" typedef void (*pFunction)(void); static const struct fal_partition *dl_part = RT_NULL; static char *recv_partition = APP_PARTITION_NAME; pFunction JumpToApplication; uint32_t JumpAddress; rt_thread_t tidOTA; void ota(void *parameter) { static struct stat stat_buf; static struct dfs_fd fd; uint32_t length; uint32_t pos = 0; char buffer[100]; if (stat("os.bin", &stat_buf) == 0) { LOG_I("find new firmware file os.bin!"); LOG_I("OS file size = %d", stat_buf.st_size); /* find app partition */ if ((dl_part = fal_partition_find(recv_partition)) == RT_NULL) { LOG_E("APP partition (%s) find error!", recv_partition); return; } /* check os size */ if (stat_buf.st_size > dl_part->len) { LOG_E("Firmware is too large! File size (%d), '%s' partition size (%d)", stat_buf.st_size, recv_partition, dl_part->len); return; } /* erase app partition */ LOG_I("Start erase. Size (%d)", stat_buf.st_size); if (fal_partition_erase(dl_part, 0, stat_buf.st_size) < 0) { LOG_E("Firmware download failed! Partition (%s) erase error!", dl_part->name); return; } /* copy os file from download to app partition */ if (dfs_file_open(&fd, "/os.bin", O_RDONLY) < 0) { LOG_E("Open %s failed!", "/os.bin"); } do { memset(buffer, 0, sizeof(buffer)); length = dfs_file_read(&fd, buffer, sizeof(buffer)); if (length > 0) { fal_partition_write(dl_part, pos, (uint8_t *)buffer, sizeof(buffer)); pos += length; } } while (length > 0); dfs_file_close(&fd); /* remove the os file */ if(dfs_file_unlink("os.bin") != 0) { LOG_E("Romove os.bin file fail!"); } /* restart bootloader to jump to app */ LOG_I("OS file loaded successfully!"); LOG_W("About to restart..."); rt_thread_mdelay(100); rt_hw_cpu_reset(); } else { LOG_W("NOT find new firmware file!"); LOG_I("Start program execution..."); /* Test if user code is programmed starting from address "RT_APP_PART_ADDR" */ if (((*(__IO uint32_t *)RT_APP_PART_ADDR) & 0x2FFE0000) == 0x20000000) { /* Jump to user application */ JumpAddress = *(__IO uint32_t *)(RT_APP_PART_ADDR + 4); JumpToApplication = (pFunction)JumpAddress; /* Initialize user application's Stack Pointer */ __set_MSP(*(__IO uint32_t *)RT_APP_PART_ADDR); JumpToApplication(); } } } int ota_entry(void) { tidOTA = rt_thread_create("ota", ota, RT_NULL, 1024, 11, 10); if (tidOTA != RT_NULL) { rt_thread_startup(tidOTA); } else { if (tidOTA) rt_thread_delete(tidOTA); return -RT_ERROR; } return RT_EOK; } ```
StackYuan
2021-02-19
memcpy不具备对flash改写的能力,可以看看ymodem是如何借助dfs/fal的写入方式
Jone
2021-02-19
写了还是懒
看解读楼主用的fal进行分区的,这里简单说下使用fal操作流程: 1. 先找app分区,然后将其进行擦除 ``` app = fal_partition_find("app"); fal_partition_erase(app, addr, size); ``` 2. 找download分区 ``` down = fal_partition_find("download"); ``` 3. 从download分区读文件读到缓存中,然后写入app分区。如果文件较大的话请分包读写,注意大小要根据flash页对齐 ``` fal_partition_read(down, read_addr, buf, buf_size); fal_partition_write(app, write_addr, buf, buf_size); ```
1.2k
ericwang215
关于FAL移植
添加fal软件包之后编译出现错误,求助!
FAL驱动移植&构建脚本问题
帮我看一下这样分区会不会冲突??
EasyFlash 4.0疑似出BUG
疑似FAL日志输出与DFS冲突??
fal软件包偏移量大于等于当前分区的大小会报错
为什么片内Flash总是写失败?
片上flash的文件系统的建立
NXP MCXN947测评之 adc
