就是挂载SPI FLASH的时候失败,代码:
int rt_hw_spi_flash_init(void)
int ret;
__HAL_RCC_GPIOA_CLK_ENABLE();
ret = rt_hw_spi_device_attach("spi1", "spi10", GPIOA, GPIO_PIN_4);
if (ret != RT_EOK)
rt_kprintf("rt_hw_spi_device_attach failed! \n");
return ret;
else
rt_kprintf("rt_hw_spi_device_attach succ! \n");
if (RT_NULL == rt_sfud_flash_probe("W25Q256", "spi10"))
rt_kprintf("rt_sfud_flash_probe failed! \n");
return -RT_ERROR;
return RT_EOK;
INIT_COMPONENT_EXPORT(rt_hw_spi_flash_init);
打印的log:
> [22:55:52.505]
- RT - Thread Operating System
/ \ 3.1.4 build Feb 21 2021
2006 - 2019 Copyright by rt-thread team
[SFUD] (..\..\..\components\drivers\spi\sfud\src\骹ud.c:861) The flash device manufacturer ID is 0x00, memory type ID is 0x00, capacity ID is 0x00.
[SFUD] (..\..\..\components\drivers\spi\sfu鋅src\sfud_sfdp.c:122) Error: Check SFDP sig頰ture error. It's must be 50444653h('S' 'F' 'D' 'P').
跾FUD] Wa騨ing: Read SFDP paramet錼 header in鎜rmation fa閘ed. The W25Q256 is not support 蔈DEC SFDP.
[SFUD] Warning: This flash device is not found or not support.
[SFUD] Error: W25Q256 flash device is initialize fail.
ERROR: SPI flash probfailed by SPI device spi10.
rt_sfu鋉flash_probe failed!
韘h >device type ref count
spi10 SPI Device 0
spi1 SPI Bus 0
鮝rt3 Character Device 2
pin Miscellaneous Device 0
问题解决了,是SPI FLASH一个pin的电阻问题,感谢各位关注帮助;
/ | \ 3.1.4 build Feb 21 2021
[SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud.c:861) The flash device manufacturer ID is 0xEF, memory type ID is 0x40, capacity ID is 0x19.
[SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:131) Check SFDP header is OK. The reversion is V1.0, NPN is 0.
[SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:173) Check JEDEC basic flash parameter header is OK. The table id is 0, reversion is V1.0, length is 9, parameter table pointer is *[SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:203) JEDEC basic flash parameter table info:
[SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:204) MSB-LSB 3 2 1 0
[SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0001] 0xFF 0xF3 0x20 0xE5
[SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0002] 0x0F 0xFF 0xFF 0xFF
[SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0003] 0x6B 0x08 0xEB 0x44
[SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0004] 0xBB 0x42 0x3B 0x08
[SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0005] 0xFF 0xFF 0xFF 0xFE
[SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0006] 0x00 0x00 0xFF 0xFF
[SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0007] 0xEB 0x21 0xFF 0xFF
[SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0008] 0x52 0x0F 0x20 0x0C
[SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0009] 0x00 0x00 0xD8 0x10
[SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:215) 4 KB Erase is supported throughout the device. Command is 0x20.
[SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:234) Write granularity is 64 bytes or larger.
[SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:245) Target flash status register is non-volatile.
[SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:276) 3- or 4-Byte addressing.
[SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:305) Capacity is 33554432 Bytes.
[SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:311) Flash device supports 4KB block erase. Command is 0x20.
[SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:311) Flash device supports 32KB block erase. Command is 0x52.
[SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:311) Flash device supports 64KB block erase. Command is 0xD8.
[SFUD] Find a Winbond flash chip. Size is 33554432 bytes.
[SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud.c:840) Flash device reset success.
[SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud.c:941) Enter 4-Byte addressing mode success.
[SFUD] W25Q256 flash device is initialize success.
[SFUD] Probe SPI flash W25Q256 by SPI device spi10 success.
在哪可以查看SPI FLASH初始化
芯片的数据读取的全部为0。所以是失败的。
可以参考Pandora STM32L475 的 W25Q128的驱动。
