外部flash
关于F1使用通用BOOT+片外FLASH升级SFUD初始化失败的问题
发布于 2021-03-20 14:21:34 浏览:1473
使用SPI3具体IO为PB2(片选),PB3,PB4,PB5。 ``` [SFUD]Find a Winbond flash chip. Size is 8388608 bytes. [SFUD]spi flash device is initialize success. [SFUD]Find a Winbond flash chip. Size is 8388608 bytes. [SFUD]spi flash device is initialize success. ________ ________ |___ /\ \ / /___ / / / \ \_/ / / / / / \ / / / / /__ | | / /__ /_____| |_| /_____| Powered by RT-Thread. V0.9.2 build Mar 18 2021 [D/FAL] (fal_flash_init:63) Flash device | onchip_flash | addr: 0x08000000 | len: 0x00080000 | blk_size: 0x00000800 |initialized finish. [D/FAL] (fal_flash_init:63) Flash device | nor_flash | addr: 0x00000000 | len: 0x00800000 | blk_size: 0x00001000 |initialized finish. [I/FAL] ==================== FAL partition table ==================== [I/FAL] | name | flash_dev | offset | length | [I/FAL] ------------------------------------------------------------- [I/FAL] | app | onchip_flash | 0x00010000 | 0x00070000 | [I/FAL] | download | nor_flash | 0x00000000 | 0x00080000 | [I/FAL] | factory | nor_flash | 0x00080000 | 0x00080000 | [I/FAL] ============================================================= [I/FAL] RT-Thread Flash Abstraction Layer (V0.4.0) initialize success. [I/FAL] System initialization successful. [I]RT-Thread OTA package(V0.2.1) initialize success. [E]Get firmware header occur CRC32(calc.crc: 7b93c5c8 != hdr.info_crc32: ffffffff) error on 'download' partition! [E]Get OTA download partition firmware header failed! [E]Get firmware header occur CRC32(calc.crc: 7b93c5c8 != hdr.info_crc32: ffffffff) error on 'app' partition! [I]Begin to execute the program on app partition. [I/FAL] Find user firmware at app partition 0x08010000 successfully. [I/FAL] Bootloader jumps to user firmware now. [D/drv.spi] spi3 bus init done \ | / - RT - Thread Operating System / | \ 4.0.2 build Mar 20 2021 2006 - 2019 Copyright by rt-thread team [D/drv.spi] spi30 attach to spi3 done [D/drv.spi] sys freq: 64000000, pclk2 freq: 64000000, SPI limiting freq: 5000000, BaudRatePrescaler: 24 [D/drv.spi] spi3 init done [D/drv.spi] spi3 transfer prepare and start [D/drv.spi] spi3 sendbuf: 20002578, recvbuf: 0, length: 1 [D/drv.spi] spi3 transfer done [D/drv.spi] spi3 transfer prepare and start [D/drv.spi] spi3 sendbuf: 0, recvbuf: 2000257C, length: 3 [D/drv.spi] spi3 transfer done [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud.c:862) The flash device manufacturer ID is 0xEF, memory type ID is 0x40, capacity ID is 0x17. [D/drv.spi] spi3 transfer prepare and start [D/drv.spi] spi3 sendbuf: 20002500, recvbuf: 0, length: 5 [D/drv.spi] spi3 transfer done [D/drv.spi] spi3 transfer prepare and start [D/drv.spi] spi3 sendbuf: 0, recvbuf: 20002534, length: 8 [D/drv.spi] spi3 transfer done [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:132) Check SFDP header is OK. The reversion is V1.5, NPN is 0. [D/drv.spi] spi3 transfer prepare and start [D/drv.spi] spi3 sendbuf: 20002500, recvbuf: 0, length: 5 [D/drv.spi] spi3 transfer done [D/drv.spi] spi3 transfer prepare and start [D/drv.spi] spi3 sendbuf: 0, recvbuf: 20002534, length: 8 [D/drv.spi] spi3 transfer done [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:175) Check JEDEC basic flash parameter header is OK. The table id is 0, reversion is V1.5, length is 16, parameter table pointer is 0x000080. [D/drv.spi] spi3 transfer prepare and start [D/drv.spi] spi3 sendbuf: 20002500, recvbuf: 0, length: 5 [D/drv.spi] spi3 transfer done [D/drv.spi] spi3 transfer prepare and start [D/drv.spi] spi3 sendbuf: 0, recvbuf: 20002534, length: 36 [D/drv.spi] spi3 transfer done [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:203) JEDEC basic flash parameter table info: [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:204) MSB-LSB 3 2 1 0 [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:207) [0001] 0xFF 0xF9 0x20 0xE5 [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:207) [0002] 0x03 0xFF 0xFF 0xFF [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:207) [0003] 0x6B 0x08 0xEB 0x44 [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:207) [0004] 0xBB 0x42 0x3B 0x08 [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:207) [0005] 0xFF 0xFF 0xFF 0xFE [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:207) [0006] 0x00 0x00 0xFF 0xFF [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:207) [0007] 0xEB 0x40 0xFF 0xFF [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:207) [0008] 0x52 0x0F 0x20 0x0C [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:207) [0009] 0x00 0x00 0xD8 0x10 [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:215) 4 KB Erase is supported throughout the device. Command is 0x20. [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:234) Write granularity is 64 bytes or larger. [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:245) Target flash status register is non-volatile. [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:271) 3-Byte only addressing. [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:305) Capacity is 8388608 Bytes. [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:312) Flash device supports 4KB block erase. Command is 0x20. [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:312) Flash device supports 32KB block erase. Command is 0x52. [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:312) Flash device supports 64KB block erase. Command is 0xD8. [SFUD] Find a Winbond flash chip. Size is 8388608 bytes. [D/drv.spi] spi3 transfer prepare and start [D/drv.spi] spi3 sendbuf: 2000257C, recvbuf: 0, length: 1 [D/drv.spi] spi3 transfer done [D/drv.spi] spi3 transfer prepare and start [D/drv.spi] spi3 sendbuf: 2000254F, recvbuf: 0, length: 1 [D/drv.spi] spi3 transfer done [D/drv.spi] spi3 transfer prepare and start [D/drv.spi] spi3 sendbuf: 0, recvbuf: 2000255F, length: 1 [D/drv.spi] spi3 transfer done [D/drv.spi] spi3 transfer prepare and start [D/drv.spi] spi3 sendbuf: 2000257D, recvbuf: 0, length: 1 [D/drv.spi] spi3 transfer done [D/drv.spi] spi3 transfer prepare and start [D/drv.spi] spi3 sendbuf: 2000254F, recvbuf: 0, length: 1 [D/drv.spi] spi3 transfer done [D/drv.spi] spi3 transfer prepare and start [D/drv.spi] spi3 sendbuf: 0, recvbuf: 2000255F, length: 1 [D/drv.spi] spi3 transfer done [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud.c:840) Flash device reset success. [SFUD] norflash0 flash device is initialize success. [SFUD] Probe SPI flash norflash0 by SPI device spi30 success. rt_sfud_flash_probe norflash0 spi30 success !!! (device_table[i]->ops.read) has assert failed at fal_flash_init. ```
2021-03-20
请问你单步跟踪了吗?出问题在什么具体位置?源代码在哪里?
1.5k
FromUnknown
【分享】如何使用 SFUD 库来操作 SPI Flash 设备
SFUD怎么使用
请教大家一下关于 SFUD 的的问题
移植sfud
使用SFUD操作FLASH
env使用easyflash不是3.2.4版本,而且没有type插件?
新增了W25X32设备成功,无法格式化
easyflash随着数据存储量增加,耗费时间加长
关于SFDP的问题
spi nand flash 能使用SFUD驱动吗
