msh >(rt_object_get_type((rt_object_t)thread) == RT_Object_Class_Thread) assertion failed at function:rt_thread_resume, line number:770
void pack_thread_entry(void *parameter)
rt_err_t result;
rt_size_t len = 0;
rt_size_t size = 0;
uint8_t cal[512] = {0};
uint16_t send_len = 0;
uint8_t send[512] = {0};
struct msg ind_send;
g_data_ringbuffer = rt_ringbuffer_create(RINGBUFFER_SIZE);
while (1)
// len = rt_ringbuffer_data_len(g_data_ringbuffer);
// if (len >= CTD_PACK_SIZE)
if (g_data_count == 24)
g_data_count = 0;
// while (rt_ringbuffer_data_len(g_data_ringbuffer))
size = rt_ringbuffer_get(g_data_ringbuffer, cal, len);
// rt_ringbuffer_reset(g_data_ringbuffer);
// send_len = package_ind_data(cal, size, send);
// for (uint16_t i = 0; i < send_len; i++)
// pm_printf("%c", send[i]);
send_len = 1024;
ind_send.data_ptr = send;
ind_send.data_size = send_len;
result = rt_mq_send(g_ind_send_mq, (void*)&ind_send, sizeof(struct msg));
if ( result == -RT_EFULL)
/* 消息队列满 */
rt_kprintf("ind_send_mq full!\n");
/* 申请一块内存 要是内存池满了 就挂起等待 */
// ind_send = rt_mp_alloc(tmp_msg_mp, RT_WAITING_FOREVER);
// ind_send->data_size = send_len;
// ind_send->data_ptr = send;
// rt_mb_send(tmp_msg_mb, (rt_ubase_t)ind_send);
// ind_send = NULL;
rt_thread_mdelay(10);
定位问题,这是在rt_mq_send中死机打印上述提示信息的
消息队列换为邮箱+内存池,仍有同样问题
注释掉消息队列,仅用ringbuffer,正常
注释掉ringbuffer,仅用消息队列,正常
这是什么原因呢,是因为用ringbuffer有哪不合适吗
谢谢回复。
线程栈设置得够大。
但还是这两个数组得问题,因为读出来ringbuffer里面得数据量超过数组得512了。
