大家好,我在测试uart dma接收功能时,出现了下列现象,查找论坛资料,没有解决,请教一下串口dma接收的正确用法。
RTT4.0.3 / stm32f103re
依据bsp模板,新建核心板bsp,只添加了串口功能(中断接收模式收发正常)
测试代码:
// drv_usart.c
result = rt_hw_serial_register(&uart_obj[i].serial, uart_obj[i].config->name,
RT_DEVICE_FLAG_RDWR
| RT_DEVICE_FLAG_INT_RX
| RT_DEVICE_FLAG_INT_TX
| RT_DEVICE_FLAG_DMA_RX // 添加DMA收发
| RT_DEVICE_FLAG_DMA_TX
| uart_obj[i].uart_dma_flag
, NULL);
#include <rtdevice.h>
#define LOG_TAG "app.uart"
#define LOG_LVL LOG_LVL_DBG
//#define LOG_LVL LOG_LVL_INFO
#include <ulog.h>
#define DEVICE_UART2 "uart2"
#define THREAD_PRIORITY 25
#define THREAD_STACK_SIZE 512
#define THREAD_TIMESLICE 10
static rt_device_t dev_uart2_handle;
static struct rt_messagequeue u2_mq;
static struct rt_thread u2_thread;
static rt_uint8_t u2_thread_stack[THREAD_STACK_SIZE];
typedef struct uart_rx_msg
rt_device_t dev;
rt_size_t size;
}uart_rx_msg_t;
static rt_err_t u2_uart_input(rt_device_t dev, rt_size_t size)
uart_rx_msg_t msg;
rt_err_t ret;
msg.dev = dev;
msg.size = size;
ret = rt_mq_send(&u2_mq, &msg, sizeof(msg));
if(ret == -RT_EFULL)
//LOG_W("mq full...\r\n");
return ret;
static void u2_read_thread_entry(void *para)
uart_rx_msg_t msg;
rt_err_t ret;
rt_uint32_t rx_length;
static char rx_buf[RT_SERIAL_RB_BUFSZ + 1]; // 要根据串口初始化时 control 设置的大小调整,这里写rtt默认的串口大小
while(1)
rt_memset(&msg, 0, sizeof(uart_rx_msg_t));
rt_memset(rx_buf, 0, RT_SERIAL_RB_BUFSZ + 1);
// 从消息队列读消息
ret = rt_mq_recv(&u2_mq, &msg, sizeof(msg), RT_WAITING_FOREVER);
if(ret == RT_EOK)
// 从串口读取数据
rx_length = rt_device_read(msg.dev, 0, rx_buf, msg.size);
rx_buf[rx_length] = '\0';
LOG_D("uart rx data, dev:%s, size:%d, data:%s\r\n", msg.dev, rx_length, rx_buf);
// 解析数据
// TODO
static int dy_uart_send(rt_device_t dev, void* buf)
rt_err_t ret = -1;
ret = rt_device_write(dev, 0, buf, rt_strlen(buf));
return ret;
static int app_uart_init(void)
rt_err_t ret = RT_EOK;
static char msg_pool[256];
struct serial_configure u2config = RT_SERIAL_CONFIG_DEFAULT;
// find
dev_uart2_handle = rt_device_find(DEVICE_UART2);
if(dev_uart2_handle == RT_NULL)
LOG_E("can't find %s device.\r\n", DEVICE_UART2);
return RT_ERROR;
// mq
ret = rt_mq_init(&u2_mq, "u2_rx_mq",
msg_pool, // 消息缓存
sizeof(uart_rx_msg_t), // 一条消息的最大长度
sizeof(msg_pool), // 消息缓存区大小
RT_IPC_FLAG_FIFO);
ASSERT(ret == RT_EOK);
// control
// u2config.bufsz = 128; // 修改缓冲区大小
// rt_device_control(dev_uart2_handle, RT_DEVICE_CTRL_CONFIG, &u2config);
// open
ret = rt_device_open(dev_uart2_handle, RT_DEVICE_FLAG_DMA_RX); // 以DMA接收及轮询发送方式打开
if(ret != RT_EOK)
LOG_E("can't open %s device. ret:%d\r\n", DEVICE_UART2, ret);
// rx callback
rt_device_set_rx_indicate(dev_uart2_handle, u2_uart_input);
ret = rt_thread_init(&u2_thread,
"u2_rx",
u2_read_thread_entry,
RT_NULL,
u2_thread_stack,
THREAD_STACK_SIZE,
THREAD_PRIORITY,
THREAD_TIMESLICE);
rt_thread_startup(&u2_thread);
return RT_EOK;
INIT_APP_EXPORT(app_uart_init);
static void uart_send_test(void)
rt_err_t ret = -1;
char str_buf[] = "uart send test.\n"; // 15+1
ret = dy_uart_send(dev_uart2_handle, str_buf);
if(ret == 0)
LOG_E("uart send failed.\r\n");
else
LOG_D("send ok. ret:%d\r\n", ret);
MSH_CMD_EXPORT(uart_send_test, u2 send test);
现象:
`result = rt_hw_serial_register(&uart_obj[i].serial, uart_obj[i].config->name,
RT_DEVICE_FLAG_RDWR
, NULL);`
这一部分代码你修改了?官方指导并不要求修改。
https://docs.rt-thread.org/#/rt-thread-version/rt-thread-standard/programming-manual/device/uart/uart?id=%e4%b8%b2%e5%8f%a3%e8%ae%be%e5%a4%87%e4%bd%bf%e7%94%a8%e7%a4%ba%e4%be%8b
请问是
注册这里?还是rt_device_open
这里?我没弄明白- -
