外部中断
使用外部中断释放信号量,在线程里接收数据,一次成功一次失败,这个代码有问题吗?
发布于 2021-04-21 10:10:47 浏览:994
中断回调函数释放信号量 void ReceiveData(void *args) { rt_sem_release(&idcard_lock); } 线程接收数据 static void idcardthd_entry(void* parameter) { int32_t ret = RET_WS_WORK; rt_sem_init(&idcard_lock, "idcard_lock", 0, RT_IPC_FLAG_FIFO); RTAPP_Debug("idcardthd_entry!\n"); /*进行二代证波特率匹配*/ while(1) { if((CONF_GetUsbCommFunc()&CONF_USBFUNC_SDT) != 0) { ret =RET_WS_OK; break; } else { ret = IDCard_AutoBaudProc(); if(ret == RET_WS_WORK) { rt_thread_delay(RT_THREAD_DELAY_TIME); } if(ret == RET_WS_OK) /*波特率匹配成功*/ { break; } else if(ret == MATCHING_FAILURE) /*波特率匹配不成功结束线程*/ { break; } } } /*二代证波特率匹配成功进入二代证数据接收发送处理线程*/ if(ret == RET_WS_OK) { while(1) { if(RT_EOK == rt_sem_take(&idcard_lock, RT_WAITING_FOREVER)) { rt_base_t level; level = rt_hw_interrupt_disable(); wSendBufLen = IDBox_ReceiveData(ucSendBuf,sizeof(ucSendBuf)); rt_hw_interrupt_enable(level); IDCard_Proc(NULL); } } } RTAPP_Debug("idcardthd_entry end\n"); } 数据接收 uint16_t IDBox_ReceiveData(uint8_t * buffer, uint16_t buflen) { uint8_t temp = 0; uint16_t len = 0; uint8_t *data = buffer; uint8_t i = 0; if(IDBox_CheckSendDataLock()) { return 0; } IDBOX_S_SDATA_Q_CFG_INPUT(); IDBOX_S_SCLK_Q_CFG_INPUT(); while (IDBOX_S_SCLK_GET_STATUS() != 0) { if (IDBOX_S_TX_FRAME_GET_STATUS() == 0) goto retn; } while (IDBOX_S_TX_FRAME_GET_STATUS() != 0) { temp =0x80; *data = 0x00; for (i=0;i<8;i++) { while(IDBOX_S_SCLK_GET_STATUS() == 0); if ( IDBOX_S_SDATA_GET_STATUS() != 0) (*data)|= temp; temp >>= 1; while(IDBOX_S_SCLK_GET_STATUS() != 0) { if (IDBOX_S_TX_FRAME_GET_STATUS() == 0) goto retn; } } IDBOX_S_SDATA_Q_CFG_OUTPUT(); IDBOX_S_SDATA_SET_LOW(); while(IDBOX_S_SCLK_GET_STATUS() == 0); while(IDBOX_S_SCLK_GET_STATUS() != 0) { if (IDBOX_S_TX_FRAME_GET_STATUS() == 0) goto retn; } IDBOX_S_SDATA_Q_CFG_INPUT(); if(len >= buflen) { goto retn; } data++; len++; } retn: IDBOX_S_SDATA_Q_CFG_OUTPUT(); IDBOX_S_SDATA_SET_HIGH(); IDBOX_S_SCLK_Q_CFG_OUTPUT(); IDBOX_S_SCLK_SET_HIGH(); //rt_sem_release(&idcard_lock); return len; }
2021-04-21
同样的问题不要频繁提交重复的,本问题3小时后将删除。 另外,贴代码建议加代码标签。 * https://club.rt-thread.org/u/17805/question * https://club.rt-thread.org/ask/question/430892.html * https://club.rt-thread.org/ask/question/430890.html * https://club.rt-thread.org/ask/question/430889.html
994
庄先生
外部中断中能改变外部中断的功能,作为普通管脚用吗
外部中断计数输入的脉冲
关于4.0.2版本中STM32的PIN设备外部中断的相关问题
外部中断问题,现在开机上电前几次不能用,后面就可以了
我用外部中断接收数据,接收的时序非常严谨,现在是一次可以一次不行
外部中断我接收数据一次可以一次不行,我中断优先级设置最高了,是还有中断干扰吗?
配置的GPIO中断无法执行中断服务子程序
增加系统,引脚为上升沿触发,触发中断,进入到中断时间延时10us,系统会干扰吗
rt 1052 触摸屏 INT 中断
外部中断回调函数执行问题
