创建失败
创建RTThread工程失败。
发布于 2021-04-27 15:12:07 浏览:703
日志如下 ``` !SESSION 2021-04-27 14:57:15.206 ----------------------------------------------- eclipse.buildId=unknown java.version=1.8.0_144 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN Command-line arguments: -os win32 -ws win32 -arch x86_64 !ENTRY org.eclipse.ui 2 0 2021-04-27 14:57:21.944 !MESSAGE Warnings while parsing the images from the 'org.eclipse.ui.commandImages' extension point. !SUBENTRY 1 org.eclipse.ui 2 0 2021-04-27 14:57:21.944 !MESSAGE Cannot bind to an undefined command: plug-in='com.genuitec.eclipse.theming.ui', id='com.genuitec.myeclipse.help.darktheme.commandid' !SESSION 2021-04-27 14:57:41.460 ----------------------------------------------- eclipse.buildId=unknown java.version=1.8.0_144 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN Command-line arguments: -os win32 -ws win32 -arch x86_64 !ENTRY org.eclipse.ui 2 0 2021-04-27 14:57:48.101 !MESSAGE Warnings while parsing the images from the 'org.eclipse.ui.commandImages' extension point. !SUBENTRY 1 org.eclipse.ui 2 0 2021-04-27 14:57:48.101 !MESSAGE Cannot bind to an undefined command: plug-in='com.genuitec.eclipse.theming.ui', id='com.genuitec.myeclipse.help.darktheme.commandid' !ENTRY org.eclipse.launchbar.core 2 0 2021-04-27 14:58:00.398 !MESSAGE Enablement expression is missing for descriptor type org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2021-04-27 14:58:00.403 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2021-04-27 14:58:00.407 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.egit.ui 2 0 2021-04-27 14:58:02.753 !MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git user global configuration and to define the default location to store repositories: 'C:\Users\Administrator'. If this is not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and EGit might behave differently since they see different configuration options. This warning can be switched off on the Team > Git > Confirmations and Warnings preference page. !ENTRY org.rt-thread.studio.project.ui 4 0 2021-04-27 15:00:07.173 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2021-04-27 15:00:07.177 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2021-04-27 15:05:34.490 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2021-04-27 15:05:34.495 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2021-04-27 15:05:34.502 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2021-04-27 15:05:34.512 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2021-04-27 15:05:38.974 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:43.865 !MESSAGE C:\RT-ThreadStudio\workspace\.metadata\Temp>cd /d E:/win_RT-ThreadStudio/RT-ThreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.27/gener !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:43.869 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set RTT_ROOT= !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:43.873 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set ENV_ROOT=E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:43.876 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set RTT_EXEC_PATH=E:/win_RT-ThreadStudio/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:43.879 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set KCONF_EXEC_PATH=E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\exec !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:43.882 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set RTT_CC=gcc !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:43.886 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set SCONS=E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:43.889 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PKGS_ROOT=E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\packages !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:43.892 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin/server;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;E:\win_RT-ThreadStudio\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:43.894 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin/server;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;E:\win_RT-ThreadStudio\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:43.897 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin/server;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;E:\win_RT-ThreadStudio\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:43.900 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin/server;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;E:\win_RT-ThreadStudio\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:43.903 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/win_RT-ThreadStudio/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin/server;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;E:\win_RT-ThreadStudio\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:43.907 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\exec;E:/win_RT-ThreadStudio/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin/server;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;E:\win_RT-ThreadStudio\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:43.909 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\qemu\qemu32;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\exec;E:/win_RT-ThreadStudio/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin/server;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;E:\win_RT-ThreadStudio\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:43.912 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PYTHONPATH=E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:43.915 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\qemu\qemu32;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\exec;E:/win_RT-ThreadStudio/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin/server;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;E:\win_RT-ThreadStudio\RT-ThreadStudio;; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:43.918 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>"E:/win_RT-ThreadStudio/RT-ThreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.27/gener/prj_gen.exe" --csp_project="true" --csp_parameter_file="C:\RT-ThreadStudio\workspace/.metadata/Temp/rtt_parameter_demo.json" -n xxx !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:52.967 !MESSAGE [14396] Failed to execute script main !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:52.971 !MESSAGE finally exit. !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:52.975 !MESSAGE Traceback (most recent call last): !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:52.978 !MESSAGE File "main.py", line 216, in
!ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:52.981 !MESSAGE File "site-packages\click\core.py", line 829, in __call__ !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:52.985 !MESSAGE File "site-packages\click\core.py", line 782, in main !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:52.988 !MESSAGE File "site-packages\click\core.py", line 1066, in invoke !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:52.992 !MESSAGE File "site-packages\click\core.py", line 610, in invoke !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:52.996 !MESSAGE File "main.py", line 183, in gen_prj_process !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:53.000 !MESSAGE File "backend\csp_proj\bridge_to_top.py", line 14, in csp_proj_gen !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:53.004 !MESSAGE File "c:\users\yaxing.chen\appdata\local\programs\python\python37-32\lib\codecs.py", line 322, in decode !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:05:53.007 !MESSAGE UnicodeDecodeError: 'utf-8' codec can't decode byte 0x84 in position 0: invalid start byte !SESSION 2021-04-27 15:06:45.015 ----------------------------------------------- eclipse.buildId=unknown java.version=1.8.0_144 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN Command-line arguments: -os win32 -ws win32 -arch x86_64 !ENTRY org.eclipse.launchbar.core 2 0 2021-04-27 15:07:11.972 !MESSAGE Enablement expression is missing for descriptor type org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2021-04-27 15:07:11.980 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2021-04-27 15:07:11.984 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.egit.ui 2 0 2021-04-27 15:07:12.167 !MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git user global configuration and to define the default location to store repositories: 'C:\Users\Administrator'. If this is not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and EGit might behave differently since they see different configuration options. This warning can be switched off on the Team > Git > Confirmations and Warnings preference page. !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:30.829 !MESSAGE C:\RT-ThreadStudio\workspace\.metadata\Temp>cd /d E:/win_RT-ThreadStudio/RT-ThreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.27/gener !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:30.834 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set RTT_ROOT= !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:30.838 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set ENV_ROOT=E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:30.842 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set RTT_EXEC_PATH=E:/win_RT-ThreadStudio/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:30.846 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set KCONF_EXEC_PATH=E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\exec !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:30.849 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set RTT_CC=gcc !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:30.852 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set SCONS=E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:30.856 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PKGS_ROOT=E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\packages !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:30.859 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin/server;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;E:\win_RT-ThreadStudio\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:30.863 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin/server;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;E:\win_RT-ThreadStudio\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:30.868 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin/server;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;E:\win_RT-ThreadStudio\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:30.872 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin/server;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;E:\win_RT-ThreadStudio\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:30.876 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/win_RT-ThreadStudio/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin/server;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;E:\win_RT-ThreadStudio\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:30.880 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\exec;E:/win_RT-ThreadStudio/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin/server;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;E:\win_RT-ThreadStudio\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:30.884 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\qemu\qemu32;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\exec;E:/win_RT-ThreadStudio/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin/server;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;E:\win_RT-ThreadStudio\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:30.888 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PYTHONPATH=E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:30.892 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\qemu\qemu32;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\exec;E:/win_RT-ThreadStudio/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/win_RT-ThreadStudio/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin/server;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/bin;E:/win_RT-ThreadStudio/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;E:\win_RT-ThreadStudio\RT-ThreadStudio;; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:30.897 !MESSAGE E:\win_RT-ThreadStudio\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>"E:/win_RT-ThreadStudio/RT-ThreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.27/gener/prj_gen.exe" --csp_project="true" --csp_parameter_file="C:\RT-ThreadStudio\workspace/.metadata/Temp/rtt_parameter_demo.json" -n xxx !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:32.849 !MESSAGE [15080] Failed to execute script main !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:32.854 !MESSAGE finally exit. !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:32.858 !MESSAGE Traceback (most recent call last): !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:32.863 !MESSAGE File "main.py", line 216, in
!ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:32.868 !MESSAGE File "site-packages\click\core.py", line 829, in __call__ !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:32.873 !MESSAGE File "site-packages\click\core.py", line 782, in main !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:32.878 !MESSAGE File "site-packages\click\core.py", line 1066, in invoke !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:32.882 !MESSAGE File "site-packages\click\core.py", line 610, in invoke !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:32.887 !MESSAGE File "main.py", line 183, in gen_prj_process !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:32.892 !MESSAGE File "backend\csp_proj\bridge_to_top.py", line 14, in csp_proj_gen !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:32.897 !MESSAGE File "c:\users\yaxing.chen\appdata\local\programs\python\python37-32\lib\codecs.py", line 322, in decode !ENTRY org.rt-thread.studio.common.ui 1 0 2021-04-27 15:07:32.903 !MESSAGE UnicodeDecodeError: 'utf-8' codec can't decode byte 0x84 in position 0: invalid start byte ```
chenyaxing
2021-04-27
泥上偶然留指爪,鸿飞那复计东西。
看起来是你选择的工程路径中有非法字符,检查下有没有中文 空格 或者 \\ 之类的高难度路径
403463275
2021-04-27
啥都不懂
1.首先确保安装rt-thread studio的时候,使用管理员安装,没有杀毒软件进行拦截。 2.所有的都是正确安装的可以试下使用管理员运行。 3.卸载原有软件下载最新版重新安装。 一般我们使用rt-thread studio新建工程的时候,软件会对工程名的合法性会进行判断,能点击下一步说明工程名是对的。
游走在01的海洋
2021-06-07
一、[官方出的创建工程的视频](https://www.bilibili.com/video/BV1aJ411t7qo?p=1) 二、[这个是最近出的关于原子战舰版的开发板视频网址](https://club.rt-thread.org/ask/article/2822.html)
703
dwx1040
动态线程创建数量的限制在哪里修改
RTT studio 创建工程失败
RT-Thread工程创建失败
