RT_thread中CAN通讯,插拔线后通讯不上!!!
发布于 2021-04-28 10:59:34 浏览:1008
使用现有阿波罗开发板的BSP模板开发,ENV开启CAN通讯后,通讯发送和接收都正常,可是当我把通讯线拔掉后,然后再插上就通讯不上了。程序中贴一部分初始化代码: ```c static rt_err_t drv_configure(struct rt_can_device *dev_can, struct can_configure *cfg) { struct stm32_drv_can *drv_can; rt_uint32_t baud_index; CAN_InitTypeDef *drv_init; RT_ASSERT(dev_can); RT_ASSERT(cfg); drv_can = (struct stm32_drv_can *)dev_can->parent.user_data; drv_init = &drv_can->CanHandle.Init; drv_init->TimeTriggeredMode = DISABLE; drv_init->AutoBusOff = ENABLE; drv_init->AutoWakeUp = DISABLE; drv_init->AutoRetransmission = DISABLE; drv_init->ReceiveFifoLocked = DISABLE; drv_init->TransmitFifoPriority = ENABLE; switch (cfg->mode) { case RT_CAN_MODE_NORMAL: drv_init->Mode = CAN_MODE_NORMAL; break; case RT_CAN_MODE_LISEN: drv_init->Mode = CAN_MODE_SILENT; break; case RT_CAN_MODE_LOOPBACK: drv_init->Mode = CAN_MODE_LOOPBACK; break; case RT_CAN_MODE_LOOPBACKANLISEN: drv_init->Mode = CAN_MODE_SILENT_LOOPBACK; break; } baud_index = get_can_baud_index(cfg->baud_rate); drv_init->SyncJumpWidth = BAUD_DATA(SJW, baud_index); drv_init->TimeSeg1 = BAUD_DATA(BS1, baud_index); drv_init->TimeSeg2 = BAUD_DATA(BS2, baud_index); drv_init->Prescaler = BAUD_DATA(RRESCL, baud_index); if (HAL_CAN_Init(&drv_can->CanHandle) != HAL_OK) { return RT_ERROR; } /* Filter conf */ HAL_CAN_ConfigFilter(&drv_can->CanHandle, &drv_can->FilterConfig); /* can start */ HAL_CAN_Start(&drv_can->CanHandle); return RT_EOK; } ``` `drv_init->AutoBusOff = ENABLE;`我这句是开启的,好像没用。 请问大神们指导下,谢谢!
2021-04-28
CAN本身不具备热插拔的机制。不过我建议在CAN初始化时将drv_init->AutoBusOff = ENABLE;还可以将drv_init->AutoRetransmission = DISABLE;设置为drv_init->AutoRetransmission = ENABLE;
1k
LordYuan
谁有STM32裸跑的CANopen程序啊???
CAN驱动程序框架
CAN驱动接口如何规范一下
STM32F10XCAN驱动使用的问题
rtthread2.1.0下,找不到can1设备
