qemu-vexpress-a9
全局变量
qemu-vexpress-a9 上c++ 全局类的构造函数没有调用
发布于 2021-04-30 13:32:58 浏览:896
win10 qemu-vexpress-a9 环境下面,局部变量的c++能正使用,但全局变量的那些类,构造函数没有调用。cplusplus_system_init函数有调用,__ctors_start__和__ctors_end__地址一样。 ```c RT_WEAK int cplusplus_system_init(void) { #if defined(__CC_ARM) || defined(__CLANG_ARM) /* If there is no SHT$$INIT_ARRAY, calling * $Super$$__cpp_initialize__aeabi_() will cause fault. At least until Keil5.12 * the problem still exists. So we have to initialize the C++ runtime by ourself. */ typedef void PROC(); extern const unsigned long SHT$$INIT_ARRAY$$Base[]; extern const unsigned long SHT$$INIT_ARRAY$$Limit[]; const unsigned long *base = SHT$$INIT_ARRAY$$Base; const unsigned long *lim = SHT$$INIT_ARRAY$$Limit; for (; base != lim; base++) { PROC *proc = (PROC *)((const char *)base + *base); (*proc)(); } #elif defined(__GNUC__) typedef void(*pfunc)(); extern pfunc __ctors_start__[]; extern pfunc __ctors_end__[]; pfunc *p; for (p = __ctors_start__; p < __ctors_end__; p++) (*p)(); #endif return 0; } ``` *main.c* ```c #include
#include "test.h" int main(void) { printf("test: %d\n",test_b()); return 0; } ``` *test.h* ```c int test_b(void); ``` *test.cpp* ```c #include
class B{ public: B(){ printf("B::B()\n"); b = 5; } ~B(){} int b; }; B b; extern "C" int test_b(void){ return b.b; } ``` 结果 ``` PS H:\work\qemu\rt-thread\rt-thread\bsp\qemu-vexpress-a9> .\qemu.bat WARNING: Image format was not specified for 'sd.bin' and probing guessed raw. Automatically detecting the format is dangerous for raw images, write operations on block 0 will be restricted. Specify the 'raw' format explicitly to remove the restrictions. dsound: Could not initialize DirectSoundCapture dsound: Reason: No sound driver is available for use, or the given GUID is not a valid DirectSound device ID \ | / - RT - Thread Operating System / | \ 4.0.3 build Apr 29 2021 2006 - 2021 Copyright by rt-thread team lwIP-2.0.2 initialized! [32m[I/sal.skt] Socket Abstraction Layer initialize success. m[I/SDIO] SD card capacity 65536 KB. [I/SDIO] switching card to hig h speed failed! file system initialization done! test: 0 msh /> ```
2021-04-30
建议阅读文档:https://www.rt-thread.org/document/site/application-note/components/cplusplus/an0035-cpp/
cxhxy12345
2021-04-30
你这里是不是因该先声明后赋值, class B{ public: B(){ printf("B::B()\n"); int b = 5;//加个声明 } ~B(){} int b;//这里去掉 };
896
ckk
RT-STUDIO下加入TOUCHGFX?
有没有人在RTT上使用C++编程
nano c++ 报错如何处理
让成员函数能作为rt_device中的回调函数
成员函数作为回调函数
C++编译问题 undefined reference to `_exit'
开启C++功能后,rt_kprintf和单步调试功能无法使用
RT-Thread Studio C++ 异常处理 (与预期不一致)
C++继承Thread类报错怎么办?
STM32使用C++ 编译报错
