线程调度
线程调度问题,高低优先级线程不会一直占用CPU
发布于 2021-05-12 23:32:57 浏览:1159
用正点原子STM32F4探索者开发板,系统使用RT_THREAD V4.0.3,做DHT11温度采集实验时,定义read_temp_thread 线程为高优先级(初始编程线程未让出CPU),led_thread为低优先级,理论来说,read_temp_thread 线程会一直占用CPU,下载到板子之后发现led_thread线程会正常运行。求解答!!! ```c /* * Copyright (c) 2006-2021, RT-Thread Development Team * * SPDX-License-Identifier: Apache-2.0 * * Change Logs: * Date Author Notes * 2018-11-06 SummerGift first version * 2018-11-19 flybreak add stm32f407-atk-explorer bsp */ #include
#define LED0_PIN GET_PIN(F, 9) #define DHT11_DATA_PIN GET_PIN(G, 9) #define THREAD_PRIORITY 15 //#define THREAD_STACK_SIZE 512 #define THREAD_TIMESLICE 5 ALIGN(RT_ALIGN_SIZE) static char led_thread_stack[1024]; static struct rt_thread led_thread; static char read_temp_stack[2048]; static struct rt_thread read_temp_thread; static void led_thread_entry(void *param) { rt_pin_mode(LED0_PIN, PIN_MODE_OUTPUT); while (1) { rt_pin_write(LED0_PIN, PIN_HIGH); rt_thread_mdelay(500); rt_pin_write(LED0_PIN, PIN_LOW); rt_thread_mdelay(500); rt_kprintf("led_thread running!\n"); } } static void read_temp_entry(void *param) { rt_device_t dev = RT_NULL; struct rt_sensor_data sensor_data; rt_uint8_t get_data_freq = 1; /* 1Hz */ rt_size_t res; dev = rt_device_find(param); if(dev == RT_NULL) { rt_kprintf("can't find device:%s",param); return; } if(rt_device_open(dev,RT_DEVICE_FLAG_RDWR) != RT_EOK) { rt_kprintf("can't open the device:%c",param); return; } rt_device_control(dev,RT_SENSOR_CTRL_SET_ODR,(void *)(&get_data_freq)); while(1) { res = rt_device_read(dev,1,&sensor_data,2); if(res != 1) { rt_kprintf("can't read the device:%c\n",param); return; } else { if(sensor_data.data.temp >= 0) { uint8_t temp = (sensor_data.data.temp&0xffff)>>0; uint8_t humi = (sensor_data.data.temp&0xffff0000)>>16; rt_kprintf("temp:%d,humi:%d\n",temp,humi); } } //rt_thread_mdelay(1000); } } int main(void) { rt_thread_init(&led_thread, "thread2", led_thread_entry, RT_NULL, &led_thread_stack[0], sizeof(led_thread_stack), THREAD_PRIORITY-1,THREAD_TIMESLICE); rt_thread_startup(&led_thread); rt_thread_init(&read_temp_thread, "read_temp", read_temp_entry, "temp_dht11", &read_temp_stack[0], sizeof(read_temp_stack), THREAD_PRIORITY-2,THREAD_TIMESLICE); rt_thread_startup(&read_temp_thread); } static int rt_hw_dht11_port(void) { struct rt_sensor_config cfg; cfg.intf.user_data = (void *)DHT11_DATA_PIN; rt_hw_dht11_init("dht11", &cfg); return RT_EOK; } INIT_COMPONENT_EXPORT(rt_hw_dht11_port); ``` ![无标题.jpg](https://oss-club.rt-thread.org/uploads/20210512/9dbe2e74fc3c7e2511dc978538a9c526.jpg)
liuduanfei
2021-05-13
查看一下代码,是不是在读取数据的时候有线程让出。你自己没有写不代表没有。
yangjie
2021-05-13
hello
看看 device read 对接的驱动是不是让出了
2021-05-13
在main函数中首先你让led_thread线程运行了,它就有机会运行,然后才让read_temp_thread线程运行,因为read_temp_thread的优先级高,所以它一直运行不会出让CPU。
cxhxy12345
2021-05-13
你可能是创建线程时参数传入错误了 rt_thread_init(.. "temp_dht11", .. 这里的temp_dht11改成dht11试下
1.2k
XingYun
simulator工程的线程调度存在缺陷,导致程序非常容易崩溃
求助:如何在串口接收线程中调度其他线程?
rt_mutex教程线程优先级高的没有delay,怎么会运行线程优先级低的
rtt是一个os时钟中断调度一次吗
RT-Thread Nano的线程切换机制?
多次调用rt_thread_startup出现stack overflow错误
有些线程,不希望被耗时的线程打断
请问 RT_OBJECT_HOOK_CALL 调用后会直接开始运行被勾起的函数嘛
使用canfestival软件包报错
内核线程调度切换时疑问
