无法创建工程
RT-Thread Studio 无法创建工程
发布于 2021-05-13 14:48:25 浏览:565
``` !SESSION 2021-05-13 14:33:03.823 ----------------------------------------------- eclipse.buildId=unknown java.version=1.8.0_144 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN Command-line arguments: -os win32 -ws win32 -arch x86_64 !ENTRY org.eclipse.ui 2 0 2021-05-13 14:33:07.114 !MESSAGE Warnings while parsing the images from the 'org.eclipse.ui.commandImages' extension point. !SUBENTRY 1 org.eclipse.ui 2 0 2021-05-13 14:33:07.114 !MESSAGE Cannot bind to an undefined command: plug-in='com.genuitec.eclipse.theming.ui', id='com.genuitec.myeclipse.help.darktheme.commandid' !ENTRY org.eclipse.egit.ui 2 0 2021-05-13 14:33:28.160 !MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git user global configuration and to define the default location to store repositories: 'C:\Users\CNDEWAN13'. If this is not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and EGit might behave differently since they see different configuration options. This warning can be switched off on the Team > Git > Confirmations and Warnings preference page. !ENTRY org.eclipse.launchbar.core 2 0 2021-05-13 14:33:28.256 !MESSAGE Enablement expression is missing for descriptor type org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2021-05-13 14:33:28.257 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2021-05-13 14:33:28.258 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.rt-thread.studio.project.ui 4 0 2021-05-13 14:33:44.220 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:34:03.727 !MESSAGE D:\RT-ThreadStudio\workspace\.metadata\Temp>cd /d D:/RT-ThreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.27/gener !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:34:03.728 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set RTT_ROOT= !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:34:03.728 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set ENV_ROOT=D:/RT-ThreadStudio/platform/env_released/env !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:34:03.728 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set RTT_EXEC_PATH=D:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:34:03.729 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set KCONF_EXEC_PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\exec !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:34:03.729 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set RTT_CC=gcc !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:34:03.729 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set SCONS=D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:34:03.730 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PKGS_ROOT=D:/RT-ThreadStudio/platform/env_released/env\packages !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:34:03.730 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\VMware\VMware Player\bin\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Git\cmd;C:\Program Files\TortoiseGit\bin;C:\Program Files (x86)\NetSarang\Xshell 7\;C:\Program Files (x86)\NetSarang\Xftp 7\;C:\Program Files\dotnet\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\;C:\Users\CNDEWAN13\AppData\Local\Microsoft\WindowsApps;C:\Program Files\JetBrains\IntelliJ IDEA 2020.3.2\bin;C:\Program Files\JetBrains\GoLand 2020.3.3\bin;C:\Users\CNDEWAN13\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\CNDEWAN13\.dotnet\tools;C:\Program Files\JetBrains\PyCharm 2020.1\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:34:03.731 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\VMware\VMware Player\bin\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Git\cmd;C:\Program Files\TortoiseGit\bin;C:\Program Files (x86)\NetSarang\Xshell 7\;C:\Program Files (x86)\NetSarang\Xftp 7\;C:\Program Files\dotnet\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\;C:\Users\CNDEWAN13\AppData\Local\Microsoft\WindowsApps;C:\Program Files\JetBrains\IntelliJ IDEA 2020.3.2\bin;C:\Program Files\JetBrains\GoLand 2020.3.3\bin;C:\Users\CNDEWAN13\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\CNDEWAN13\.dotnet\tools;C:\Program Files\JetBrains\PyCharm 2020.1\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:34:03.731 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\VMware\VMware Player\bin\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Git\cmd;C:\Program Files\TortoiseGit\bin;C:\Program Files (x86)\NetSarang\Xshell 7\;C:\Program Files (x86)\NetSarang\Xftp 7\;C:\Program Files\dotnet\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\;C:\Users\CNDEWAN13\AppData\Local\Microsoft\WindowsApps;C:\Program Files\JetBrains\IntelliJ IDEA 2020.3.2\bin;C:\Program Files\JetBrains\GoLand 2020.3.3\bin;C:\Users\CNDEWAN13\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\CNDEWAN13\.dotnet\tools;C:\Program Files\JetBrains\PyCharm 2020.1\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:34:03.732 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\bin;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\VMware\VMware Player\bin\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Git\cmd;C:\Program Files\TortoiseGit\bin;C:\Program Files (x86)\NetSarang\Xshell 7\;C:\Program Files (x86)\NetSarang\Xftp 7\;C:\Program Files\dotnet\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\;C:\Users\CNDEWAN13\AppData\Local\Microsoft\WindowsApps;C:\Program Files\JetBrains\IntelliJ IDEA 2020.3.2\bin;C:\Program Files\JetBrains\GoLand 2020.3.3\bin;C:\Users\CNDEWAN13\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\CNDEWAN13\.dotnet\tools;C:\Program Files\JetBrains\PyCharm 2020.1\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:34:03.732 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=D:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;D:/RT-ThreadStudio/platform/env_released/env\tools\bin;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\VMware\VMware Player\bin\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Git\cmd;C:\Program Files\TortoiseGit\bin;C:\Program Files (x86)\NetSarang\Xshell 7\;C:\Program Files (x86)\NetSarang\Xftp 7\;C:\Program Files\dotnet\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\;C:\Users\CNDEWAN13\AppData\Local\Microsoft\WindowsApps;C:\Program Files\JetBrains\IntelliJ IDEA 2020.3.2\bin;C:\Program Files\JetBrains\GoLand 2020.3.3\bin;C:\Users\CNDEWAN13\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\CNDEWAN13\.dotnet\tools;C:\Program Files\JetBrains\PyCharm 2020.1\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:34:03.732 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\exec;D:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;D:/RT-ThreadStudio/platform/env_released/env\tools\bin;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\VMware\VMware Player\bin\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Git\cmd;C:\Program Files\TortoiseGit\bin;C:\Program Files (x86)\NetSarang\Xshell 7\;C:\Program Files (x86)\NetSarang\Xftp 7\;C:\Program Files\dotnet\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\;C:\Users\CNDEWAN13\AppData\Local\Microsoft\WindowsApps;C:\Program Files\JetBrains\IntelliJ IDEA 2020.3.2\bin;C:\Program Files\JetBrains\GoLand 2020.3.3\bin;C:\Users\CNDEWAN13\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\CNDEWAN13\.dotnet\tools;C:\Program Files\JetBrains\PyCharm 2020.1\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:34:03.733 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\qemu\qemu32;D:/RT-ThreadStudio/platform/env_released/env\tools\exec;D:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;D:/RT-ThreadStudio/platform/env_released/env\tools\bin;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\VMware\VMware Player\bin\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Git\cmd;C:\Program Files\TortoiseGit\bin;C:\Program Files (x86)\NetSarang\Xshell 7\;C:\Program Files (x86)\NetSarang\Xftp 7\;C:\Program Files\dotnet\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\;C:\Users\CNDEWAN13\AppData\Local\Microsoft\WindowsApps;C:\Program Files\JetBrains\IntelliJ IDEA 2020.3.2\bin;C:\Program Files\JetBrains\GoLand 2020.3.3\bin;C:\Users\CNDEWAN13\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\CNDEWAN13\.dotnet\tools;C:\Program Files\JetBrains\PyCharm 2020.1\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:34:03.733 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PYTHONPATH=D:/RT-ThreadStudio/platform/env_released/env\tools\Python27; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:34:03.733 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\qemu\qemu32;D:/RT-ThreadStudio/platform/env_released/env\tools\exec;D:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;D:/RT-ThreadStudio/platform/env_released/env\tools\bin;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\VMware\VMware Player\bin\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Git\cmd;C:\Program Files\TortoiseGit\bin;C:\Program Files (x86)\NetSarang\Xshell 7\;C:\Program Files (x86)\NetSarang\Xftp 7\;C:\Program Files\dotnet\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\;C:\Users\CNDEWAN13\AppData\Local\Microsoft\WindowsApps;C:\Program Files\JetBrains\IntelliJ IDEA 2020.3.2\bin;C:\Program Files\JetBrains\GoLand 2020.3.3\bin;C:\Users\CNDEWAN13\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\CNDEWAN13\.dotnet\tools;C:\Program Files\JetBrains\PyCharm 2020.1\bin;D:\RT-ThreadStudio;; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:34:03.734 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>"D:/RT-ThreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.27/gener/prj_gen.exe" --csp_project="true" --csp_parameter_file="D:\RT-ThreadStudio\workspace/.metadata/Temp/rtt_parameter_demo.json" -n xxx !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:34:03.783 !MESSAGE 拒绝访问。 !SESSION 2021-05-13 14:36:58.808 ----------------------------------------------- eclipse.buildId=unknown java.version=1.8.0_144 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN Command-line arguments: -os win32 -ws win32 -arch x86_64 !ENTRY org.eclipse.ui 2 0 2021-05-13 14:37:01.097 !MESSAGE Warnings while parsing the images from the 'org.eclipse.ui.commandImages' extension point. !SUBENTRY 1 org.eclipse.ui 2 0 2021-05-13 14:37:01.097 !MESSAGE Cannot bind to an undefined command: plug-in='com.genuitec.eclipse.theming.ui', id='com.genuitec.myeclipse.help.darktheme.commandid' !ENTRY org.eclipse.launchbar.core 2 0 2021-05-13 14:37:05.967 !MESSAGE Enablement expression is missing for descriptor type org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2021-05-13 14:37:05.968 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2021-05-13 14:37:05.968 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.egit.ui 2 0 2021-05-13 14:37:06.055 !MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git user global configuration and to define the default location to store repositories: 'C:\Users\CNDEWAN13'. If this is not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and EGit might behave differently since they see different configuration options. This warning can be switched off on the Team > Git > Confirmations and Warnings preference page. !SESSION 2021-05-13 14:37:28.854 ----------------------------------------------- eclipse.buildId=unknown java.version=1.8.0_144 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN Command-line arguments: -os win32 -ws win32 -arch x86_64 !ENTRY org.eclipse.ui 2 0 2021-05-13 14:37:31.120 !MESSAGE Warnings while parsing the images from the 'org.eclipse.ui.commandImages' extension point. !SUBENTRY 1 org.eclipse.ui 2 0 2021-05-13 14:37:31.120 !MESSAGE Cannot bind to an undefined command: plug-in='com.genuitec.eclipse.theming.ui', id='com.genuitec.myeclipse.help.darktheme.commandid' !ENTRY org.eclipse.launchbar.core 2 0 2021-05-13 14:37:36.063 !MESSAGE Enablement expression is missing for descriptor type org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2021-05-13 14:37:36.064 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2021-05-13 14:37:36.064 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.egit.ui 2 0 2021-05-13 14:37:36.148 !MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git user global configuration and to define the default location to store repositories: 'C:\Users\CNDEWAN13'. If this is not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and EGit might behave differently since they see different configuration options. This warning can be switched off on the Team > Git > Confirmations and Warnings preference page. !ENTRY org.rt-thread.studio.project.ui 4 0 2021-05-13 14:40:08.992 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2021-05-13 14:40:47.209 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:41:00.505 !MESSAGE D:\RT-ThreadStudio\workspace\.metadata\Temp>cd /d D:/RT-ThreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.27/gener !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:41:00.506 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set RTT_ROOT= !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:41:00.506 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set ENV_ROOT=D:/RT-ThreadStudio/platform/env_released/env !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:41:00.507 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set RTT_EXEC_PATH=D:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:41:00.507 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set KCONF_EXEC_PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\exec !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:41:00.508 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set RTT_CC=gcc !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:41:00.508 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set SCONS=D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:41:00.508 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PKGS_ROOT=D:/RT-ThreadStudio/platform/env_released/env\packages !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:41:00.508 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\VMware\VMware Player\bin\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Git\cmd;C:\Program Files\TortoiseGit\bin;C:\Program Files (x86)\NetSarang\Xshell 7\;C:\Program Files (x86)\NetSarang\Xftp 7\;C:\Program Files\dotnet\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\;C:\Users\CNDEWAN13\AppData\Local\Microsoft\WindowsApps;C:\Program Files\JetBrains\IntelliJ IDEA 2020.3.2\bin;C:\Program Files\JetBrains\GoLand 2020.3.3\bin;C:\Users\CNDEWAN13\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\CNDEWAN13\.dotnet\tools;C:\Program Files\JetBrains\PyCharm 2020.1\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:41:00.509 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\VMware\VMware Player\bin\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Git\cmd;C:\Program Files\TortoiseGit\bin;C:\Program Files (x86)\NetSarang\Xshell 7\;C:\Program Files (x86)\NetSarang\Xftp 7\;C:\Program Files\dotnet\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\;C:\Users\CNDEWAN13\AppData\Local\Microsoft\WindowsApps;C:\Program Files\JetBrains\IntelliJ IDEA 2020.3.2\bin;C:\Program Files\JetBrains\GoLand 2020.3.3\bin;C:\Users\CNDEWAN13\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\CNDEWAN13\.dotnet\tools;C:\Program Files\JetBrains\PyCharm 2020.1\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:41:00.509 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\VMware\VMware Player\bin\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Git\cmd;C:\Program Files\TortoiseGit\bin;C:\Program Files (x86)\NetSarang\Xshell 7\;C:\Program Files (x86)\NetSarang\Xftp 7\;C:\Program Files\dotnet\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\;C:\Users\CNDEWAN13\AppData\Local\Microsoft\WindowsApps;C:\Program Files\JetBrains\IntelliJ IDEA 2020.3.2\bin;C:\Program Files\JetBrains\GoLand 2020.3.3\bin;C:\Users\CNDEWAN13\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\CNDEWAN13\.dotnet\tools;C:\Program Files\JetBrains\PyCharm 2020.1\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:41:00.509 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\bin;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\VMware\VMware Player\bin\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Git\cmd;C:\Program Files\TortoiseGit\bin;C:\Program Files (x86)\NetSarang\Xshell 7\;C:\Program Files (x86)\NetSarang\Xftp 7\;C:\Program Files\dotnet\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\;C:\Users\CNDEWAN13\AppData\Local\Microsoft\WindowsApps;C:\Program Files\JetBrains\IntelliJ IDEA 2020.3.2\bin;C:\Program Files\JetBrains\GoLand 2020.3.3\bin;C:\Users\CNDEWAN13\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\CNDEWAN13\.dotnet\tools;C:\Program Files\JetBrains\PyCharm 2020.1\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:41:00.510 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=D:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;D:/RT-ThreadStudio/platform/env_released/env\tools\bin;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\VMware\VMware Player\bin\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Git\cmd;C:\Program Files\TortoiseGit\bin;C:\Program Files (x86)\NetSarang\Xshell 7\;C:\Program Files (x86)\NetSarang\Xftp 7\;C:\Program Files\dotnet\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\;C:\Users\CNDEWAN13\AppData\Local\Microsoft\WindowsApps;C:\Program Files\JetBrains\IntelliJ IDEA 2020.3.2\bin;C:\Program Files\JetBrains\GoLand 2020.3.3\bin;C:\Users\CNDEWAN13\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\CNDEWAN13\.dotnet\tools;C:\Program Files\JetBrains\PyCharm 2020.1\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:41:00.510 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\exec;D:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;D:/RT-ThreadStudio/platform/env_released/env\tools\bin;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\VMware\VMware Player\bin\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Git\cmd;C:\Program Files\TortoiseGit\bin;C:\Program Files (x86)\NetSarang\Xshell 7\;C:\Program Files (x86)\NetSarang\Xftp 7\;C:\Program Files\dotnet\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\;C:\Users\CNDEWAN13\AppData\Local\Microsoft\WindowsApps;C:\Program Files\JetBrains\IntelliJ IDEA 2020.3.2\bin;C:\Program Files\JetBrains\GoLand 2020.3.3\bin;C:\Users\CNDEWAN13\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\CNDEWAN13\.dotnet\tools;C:\Program Files\JetBrains\PyCharm 2020.1\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:41:00.510 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\qemu\qemu32;D:/RT-ThreadStudio/platform/env_released/env\tools\exec;D:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;D:/RT-ThreadStudio/platform/env_released/env\tools\bin;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\VMware\VMware Player\bin\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Git\cmd;C:\Program Files\TortoiseGit\bin;C:\Program Files (x86)\NetSarang\Xshell 7\;C:\Program Files (x86)\NetSarang\Xftp 7\;C:\Program Files\dotnet\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\;C:\Users\CNDEWAN13\AppData\Local\Microsoft\WindowsApps;C:\Program Files\JetBrains\IntelliJ IDEA 2020.3.2\bin;C:\Program Files\JetBrains\GoLand 2020.3.3\bin;C:\Users\CNDEWAN13\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\CNDEWAN13\.dotnet\tools;C:\Program Files\JetBrains\PyCharm 2020.1\bin;D:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:41:00.511 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PYTHONPATH=D:/RT-ThreadStudio/platform/env_released/env\tools\Python27; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:41:00.511 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=D:/RT-ThreadStudio/platform/env_released/env\tools\qemu\qemu32;D:/RT-ThreadStudio/platform/env_released/env\tools\exec;D:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;D:/RT-ThreadStudio/platform/env_released/env\tools\bin;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;D:/RT-ThreadStudio/platform/env_released/env\tools\Python27;D:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Program Files (x86)\VMware\VMware Player\bin\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Git\cmd;C:\Program Files\TortoiseGit\bin;C:\Program Files (x86)\NetSarang\Xshell 7\;C:\Program Files (x86)\NetSarang\Xftp 7\;C:\Program Files\dotnet\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\Scripts\;C:\Users\CNDEWAN13\AppData\Local\Programs\Python\Python37\;C:\Users\CNDEWAN13\AppData\Local\Microsoft\WindowsApps;C:\Program Files\JetBrains\IntelliJ IDEA 2020.3.2\bin;C:\Program Files\JetBrains\GoLand 2020.3.3\bin;C:\Users\CNDEWAN13\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\CNDEWAN13\.dotnet\tools;C:\Program Files\JetBrains\PyCharm 2020.1\bin;D:\RT-ThreadStudio;; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:41:00.511 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>"D:/RT-ThreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.27/gener/prj_gen.exe" --csp_project="true" --csp_parameter_file="D:\RT-ThreadStudio\workspace/.metadata/Temp/rtt_parameter_demo.json" -n xxx !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-13 14:41:00.515 !MESSAGE 拒绝访问。 ```
RT-Thread小师弟
2021-05-13
微信:rtthread2020
问题描述详细一点才好解决噢
2021-05-13
先安装一下微软的C++运行库吧,不行就重新安装
rcp
2021-05-19
"D:/RT-ThreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.27/gener/prj_gen.exe" 这个prj_gen.exe被杀毒软件删除了,恢复一下 [prj_gen.exe](https://oss-club.rt-thread.org/uploads/20210519/69aeee07cabfbd5b0ec848359e765e55.exe)
565
smartmos
RT-Thread Studio无法创建工程
创建工程过程中发生异常,创建工程取消,请重试。
仅有ART-Pi开发包时,RTT Studio无法创建ART-Pi工程
RT Thread studio创建项目失败
RTT studio 创建工程失败
STUDIO2.0无法自动联接下载网上库文件
RT-thread Studio创建项目失败
RT-Studio版本: 2.0.0 创建工程失败
RT-ThreadStudio 无法创建工程
安装程序成功后,创建工程时报错
