NUCLEO-F767ZI
RT-Thread studio基于NUCLEO-F767ZI开发板创建失败
发布于 2021-05-15 11:31:36 浏览:732
在RT-Thread studio 中直接生成的,结果以下报错,还需要什么配置吗? ``` 1:17:02 **** Incremental Build of configuration Debug for project NUCLEO-F767ZI **** make -j8 all arm-none-eabi-gcc "../rt-thread/tools/kconfig-frontends/utils/gettext.c" arm-none-eabi-gcc "../rt-thread/tools/kconfig-frontends/libs/parser/confdata.c" arm-none-eabi-gcc "../rt-thread/tools/kconfig-frontends/libs/parser/expr.c" arm-none-eabi-gcc "../rt-thread/tools/kconfig-frontends/libs/parser/hconf.c" arm-none-eabi-gcc "../rt-thread/tools/kconfig-frontends/libs/parser/lconf.c" arm-none-eabi-gcc "../rt-thread/tools/kconfig-frontends/libs/parser/menu.c" arm-none-eabi-gcc "../rt-thread/tools/kconfig-frontends/libs/parser/symbol.c" arm-none-eabi-gcc "../rt-thread/tools/kconfig-frontends/libs/parser/util.c" libs/parser/hconf.gperf:12:82: error: unknown type name 'GPERF_LEN_TYPE' libs/parser/hconf.gperf:153:1: error: conflicting types for 'kconf_id_lookup' libs/parser/hconf.gperf:12:31: note: previous declaration of 'kconf_id_lookup' was here libs/parser/hconf.gperf: In function 'kconf_id_lookup': libs/parser/hconf.gperf:164:32: error: array type has incomplete element type 'struct kconf_id' libs/parser/hconf.gperf:26:78: error: 'T_IF' undeclared (first use in this function) libs/parser/hconf.gperf:26:78: note: each undeclared identifier is reported only once for each function it appears in libs/parser/hconf.gperf:26:85: error: 'TF_COMMAND' undeclared (first use in this function) libs/parser/hconf.gperf:26:96: error: 'TF_PARAM' undeclared (first use in this function) libs/parser/hconf.gperf:37:78: error: 'T_TYPE' undeclared (first use in this function) libs/parser/hconf.gperf:37:99: error: 'S_INT' undeclared (first use in this function) libs/parser/hconf.gperf:27:78: error: 'T_ENDIF' undeclared (first use in this function) libs/parser/hconf.gperf:30:77: error: 'T_DEFAULT' undeclared (first use in this function) libs/parser/hconf.gperf:30:100: error: 'S_UNKNOWN' undeclared (first use in this function) libs/parser/hconf.gperf:32:98: error: 'S_TRISTATE' undeclared (first use in this function) libs/parser/hconf.gperf:20:77: error: 'T_ENDCHOICE' undeclared (first use in this function) libs/parser/hconf.gperf:25:78: error: 'T_HELP' undeclared (first use in this function) libs/parser/hconf.gperf:36:101: error: 'S_BOOLEAN' undeclared (first use in this function) libs/parser/hconf.gperf:47:78: error: 'T_OPT_DEFCONFIG_LIST' undeclared (first use in this function) libs/parser/hconf.gperf:47:99: error: 'TF_OPTION' undeclared (first use in this function) libs/parser/hconf.gperf:45:79: error: 'T_ON' undeclared (first use in this function) libs/parser/hconf.gperf:29:78: error: 'T_OPTIONAL' undeclared (first use in this function) libs/parser/hconf.gperf:44:79: error: 'T_OPTION' undeclared (first use in this function) libs/parser/hconf.gperf:17:78: error: 'T_ENDMENU' undeclared (first use in this function) libs/parser/hconf.gperf:15:78: error: 'T_MAINMENU' undeclared (first use in this function) libs/parser/hconf.gperf:23:78: error: 'T_MENUCONFIG' undeclared (first use in this function) libs/parser/hconf.gperf:46:78: error: 'T_OPT_MODULES' undeclared (first use in this function) libs/parser/hconf.gperf:49:78: error: 'T_OPT_ALLNOCONFIG_Y' undeclared (first use in this function) libs/parser/hconf.gperf:16:79: error: 'T_MENU' undeclared (first use in this function) libs/parser/hconf.gperf:40:79: error: 'T_SELECT' undeclared (first use in this function) libs/parser/hconf.gperf:21:78: error: 'T_COMMENT' undeclared (first use in this function) libs/parser/hconf.gperf:48:79: error: 'T_OPT_ENV' undeclared (first use in this function) libs/parser/hconf.gperf:42:79: error: 'T_RANGE' undeclared (first use in this function) libs/parser/hconf.gperf:19:79: error: 'T_CHOICE' undeclared (first use in this function) libs/parser/hconf.gperf:18:79: error: 'T_SOURCE' undeclared (first use in this function) libs/parser/hconf.gperf:43:78: error: 'T_VISIBLE' undeclared (first use in this function) libs/parser/hconf.gperf:38:100: error: 'S_HEX' undeclared (first use in this function) libs/parser/hconf.gperf:22:79: error: 'T_CONFIG' undeclared (first use in this function) libs/parser/hconf.gperf:41:79: error: 'T_IMPLY' undeclared (first use in this function) libs/parser/hconf.gperf:39:100: error: 'S_STRING' undeclared (first use in this function) libs/parser/hconf.gperf:31:79: error: 'T_PROMPT' undeclared (first use in this function) libs/parser/hconf.gperf:28:78: error: 'T_DEPENDS' undeclared (first use in this function) libs/parser/hconf.gperf:42:34: warning: implicit declaration of function 'strncmp' [-Wimplicit-function-declaration] libs/parser/hconf.gperf:164:32: warning: unused variable 'wordlist' [-Wunused-variable] ../rt-thread/tools/kconfig-frontends/utils/gettext.c:10:17: fatal error: lkc.h: No such file or directory compilation terminated. make: *** [rt-thread/tools/kconfig-frontends/libs/parser/subdir.mk:39: rt-thread/tools/kconfig-frontends/libs/parser/hconf.o] Error 1 make: *** Waiting for unfinished jobs.... In file included from ../rt-thread/tools/kconfig-frontends/libs/parser/expr.c:10:0: ../rt-thread/tools/kconfig-frontends/libs/parser/lkc.h:12:22: fatal error: libintl.h: No such file or directory compilation terminated. make: *** [rt-thread/tools/kconfig-frontends/utils/subdir.mk:18: rt-thread/tools/kconfig-frontends/utils/gettext.o] Error 1 In file included from ../rt-thread/tools/kconfig-frontends/libs/parser/lconf.c:795:0: ../rt-thread/tools/kconfig-frontends/libs/parser/lkc.h:12:22: fatal error: libintl.h: No such file or directory compilation terminated. make: *** [rt-thread/tools/kconfig-frontends/libs/parser/subdir.mk:39: rt-thread/tools/kconfig-frontends/libs/parser/expr.o] Error 1 In file included from ../rt-thread/tools/kconfig-frontends/libs/parser/confdata.c:17:0: ../rt-thread/tools/kconfig-frontends/libs/parser/lkc.h:12:22: fatal error: libintl.h: No such file or directory compilation terminated. In file included from ../rt-thread/tools/kconfig-frontends/libs/parser/symbol.c:9:0: c:\rt-threadstudio\repo\extract\toolchain_support_packages\arm\gnu_tools_for_arm_embedded_processors\5.4.1\arm-none-eabi\include\regex.h:43:9: error: unknown type name 'off_t' typedef off_t regoff_t; ^ In file included from ../rt-thread/tools/kconfig-frontends/libs/parser/util.c:11:0: ../rt-thread/tools/kconfig-frontends/libs/parser/lkc.h:12:22: fatal error: libintl.h: No such file or directory compilation terminated. ../rt-thread/tools/kconfig-frontends/libs/parser/symbol.c:10:25: fatal error: sys/utsname.h: No such file or directory compilation terminated. In file included from ../rt-thread/tools/kconfig-frontends/libs/parser/menu.c:11:0: ../rt-thread/tools/kconfig-frontends/libs/parser/lkc.h:12:22: fatal error: libintl.h: No such file or directory compilation terminated. make: *** [rt-thread/tools/kconfig-frontends/libs/parser/subdir.mk:39: rt-thread/tools/kconfig-frontends/libs/parser/lconf.o] Error 1 make: *** [rt-thread/tools/kconfig-frontends/libs/parser/subdir.mk:39: rt-thread/tools/kconfig-frontends/libs/parser/util.o] Error 1 make: *** [rt-thread/tools/kconfig-frontends/libs/parser/subdir.mk:39: rt-thread/tools/kconfig-frontends/libs/parser/confdata.o] Error 1 make: *** [rt-thread/tools/kconfig-frontends/libs/parser/subdir.mk:39: rt-thread/tools/kconfig-frontends/libs/parser/menu.o] Error 1 make: *** [rt-thread/tools/kconfig-frontends/libs/parser/subdir.mk:39: rt-thread/tools/kconfig-frontends/libs/parser/symbol.o] Error 1 "make -j8 all" terminated with exit code 2. Build might be incomplete. 11:17:09 Build Failed. 56 errors, 2 warnings. (took 7s.297ms) ```
2021-05-15
如果直接生成就报错,你需要向NUCLEO-F767ZI开发板的维护者反馈BUG。
732
MicroLin
rt_thread studio 啥时候能用呢
RT_Thread使用反馈帖子
RTT studio 下的 AT指令问题。
rt thread Studio 关于J-LINK下载问题
RT-Thread studio 调试设置问题
RTT-Studio 如何设置调试配置参数?
rt_thread studio 软件包配置
RT-Studio目前只能开发STM32的项目吗?
rtt studio 生成hex名字修改
