bug
建立RTThread工程失败
发布于 2021-05-18 19:49:20 浏览:649
[日志.log.txt](https://oss-club.rt-thread.org/uploads/20210518/62598950101e5a25ff05c7200761ec9c.txt) ``` !SESSION 2021-05-18 15:20:47.120 ----------------------------------------------- eclipse.buildId=unknown java.version=1.8.0_144 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN Command-line arguments: -os win32 -ws win32 -arch x86_64 !ENTRY org.eclipse.ui 2 0 2021-05-18 15:21:03.947 !MESSAGE Warnings while parsing the images from the 'org.eclipse.ui.commandImages' extension point. !SUBENTRY 1 org.eclipse.ui 2 0 2021-05-18 15:21:03.947 !MESSAGE Cannot bind to an undefined command: plug-in='com.genuitec.eclipse.theming.ui', id='com.genuitec.myeclipse.help.darktheme.commandid' !ENTRY org.eclipse.egit.ui 2 0 2021-05-18 15:22:20.127 !MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git user global configuration and to define the default location to store repositories: 'C:\Users\HG_DENG'. If this is not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and EGit might behave differently since they see different configuration options. This warning can be switched off on the Team > Git > Confirmations and Warnings preference page. !ENTRY org.eclipse.ui 4 0 2021-05-18 15:22:20.260 !MESSAGE Unhandled event loop exception !STACK 0 java.lang.NullPointerException at com.genuitec.eclipse.core.util.PlatformUIUtil.getActivePage(PlatformUIUtil.java:68) at com.genuitec.eclipse.startup.workspace.WorkspaceTracker.lambda$1(WorkspaceTracker.java:193) at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:40) at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:185) at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3919) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3550) at org.eclipse.jface.operation.ModalContext$ModalContextThread.block(ModalContext.java:168) at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372) at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:474) at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:240) at org.rtthread.studio.application.ApplicationWorkbenchAdvisor.disconnectFromWorkspace(ApplicationWorkbenchAdvisor.java:506) at org.rtthread.studio.application.ApplicationWorkbenchAdvisor.access$2(ApplicationWorkbenchAdvisor.java:483) at org.rtthread.studio.application.ApplicationWorkbenchAdvisor$2.run(ApplicationWorkbenchAdvisor.java:324) at org.rtthread.studio.application.ApplicationWorkbenchAdvisor.postShutdown(ApplicationWorkbenchAdvisor.java:345) at org.eclipse.ui.internal.Workbench.shutdown(Workbench.java:3044) at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1232) at org.eclipse.ui.internal.Workbench.lambda$4(Workbench.java:1482) at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:72) at org.eclipse.ui.internal.Workbench.close(Workbench.java:1482) at org.eclipse.ui.internal.Workbench.close(Workbench.java:1455) at org.rtthread.studio.application.ApplicationWorkbenchWindowAdvisor$9.run(ApplicationWorkbenchWindowAdvisor.java:1051) at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:40) at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:185) at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3919) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3550) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1173) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1062) at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156) at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:642) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:569) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:151) at org.rtthread.studio.application.Application.start(Application.java:148) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:595) at org.eclipse.equinox.launcher.Main.run(Main.java:1501) !ENTRY org.eclipse.core.jobs 4 2 2021-05-18 15:22:20.832 !MESSAGE 在“Updating DevStyle...”期间发生了内部错误。 !STACK 0 java.lang.NullPointerException at com.genuitec.eclipse.core.util.P2Utils.getProvisioningAgent(P2Utils.java:27) at com.genuitec.eclipse.core.util.P2Utils.getProfileRegistry(P2Utils.java:37) at com.genuitec.eclipse.webclipse.evergreen.internal.EvergreenUpdateProcess.run(EvergreenUpdateProcess.java:149) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) !ENTRY org.eclipse.equinox.p2.updatechecker 4 0 2021-05-18 15:22:21.469 !MESSAGE Exception in update check thread !STACK 0 java.lang.IllegalStateException: 束上下文不再有效 at org.eclipse.osgi.internal.framework.BundleContextImpl.checkValid(BundleContextImpl.java:992) at org.eclipse.osgi.internal.framework.BundleContextImpl.getServiceReference(BundleContextImpl.java:567) at org.eclipse.osgi.internal.framework.BundleContextImpl.getServiceReference(BundleContextImpl.java:1019) at org.eclipse.equinox.internal.p2.core.helpers.ServiceHelper.getService(ServiceHelper.java:32) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.getSharedPreferences(AbstractRepositoryManager.java:515) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.restoreRepositories(AbstractRepositoryManager.java:1018) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.addRepository(AbstractRepositoryManager.java:120) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:677) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:110) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:105) at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker.getAvailableRepositories(UpdateChecker.java:152) at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker.checkForUpdates(UpdateChecker.java:130) at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker$UpdateCheckThread.run(UpdateChecker.java:78) !SESSION 2021-05-18 17:50:49.251 ----------------------------------------------- eclipse.buildId=unknown java.version=1.8.0_144 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN Command-line arguments: -os win32 -ws win32 -arch x86_64 !ENTRY org.eclipse.egit.ui 2 0 2021-05-18 17:51:24.962 !MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git user global configuration and to define the default location to store repositories: 'C:\Users\HG_DENG'. If this is not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and EGit might behave differently since they see different configuration options. This warning can be switched off on the Team > Git > Confirmations and Warnings preference page. !ENTRY org.eclipse.ui 4 0 2021-05-18 17:51:25.065 !MESSAGE Unhandled event loop exception !STACK 0 java.lang.NullPointerException at com.genuitec.eclipse.core.util.PlatformUIUtil.getActivePage(PlatformUIUtil.java:68) at com.genuitec.eclipse.startup.workspace.WorkspaceTracker.lambda$1(WorkspaceTracker.java:193) at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:40) at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:185) at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3919) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3550) at org.eclipse.jface.operation.ModalContext$ModalContextThread.block(ModalContext.java:168) at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372) at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:474) at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:240) at org.rtthread.studio.application.ApplicationWorkbenchAdvisor.disconnectFromWorkspace(ApplicationWorkbenchAdvisor.java:506) at org.rtthread.studio.application.ApplicationWorkbenchAdvisor.access$2(ApplicationWorkbenchAdvisor.java:483) at org.rtthread.studio.application.ApplicationWorkbenchAdvisor$2.run(ApplicationWorkbenchAdvisor.java:324) at org.rtthread.studio.application.ApplicationWorkbenchAdvisor.postShutdown(ApplicationWorkbenchAdvisor.java:345) at org.eclipse.ui.internal.Workbench.shutdown(Workbench.java:3044) at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1232) at org.eclipse.ui.internal.Workbench.lambda$4(Workbench.java:1482) at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:72) at org.eclipse.ui.internal.Workbench.close(Workbench.java:1482) at org.eclipse.ui.internal.Workbench.close(Workbench.java:1455) at org.rtthread.studio.application.ApplicationWorkbenchWindowAdvisor$9.run(ApplicationWorkbenchWindowAdvisor.java:1051) at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:40) at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:185) at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3919) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3550) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1173) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1062) at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156) at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:642) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:569) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:151) at org.rtthread.studio.application.Application.start(Application.java:148) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:595) at org.eclipse.equinox.launcher.Main.run(Main.java:1501) !SESSION 2021-05-18 17:56:40.070 ----------------------------------------------- eclipse.buildId=unknown java.version=1.8.0_144 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN Command-line arguments: -os win32 -ws win32 -arch x86_64 !ENTRY org.eclipse.egit.ui 2 0 2021-05-18 17:57:12.551 !MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git user global configuration and to define the default location to store repositories: 'C:\Users\HG_DENG'. If this is not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and EGit might behave differently since they see different configuration options. This warning can be switched off on the Team > Git > Confirmations and Warnings preference page. !ENTRY org.eclipse.launchbar.core 2 0 2021-05-18 17:57:15.399 !MESSAGE Enablement expression is missing for descriptor type org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2021-05-18 17:57:15.402 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2021-05-18 17:57:15.405 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.rt-thread.studio.project.ui 4 0 2021-05-18 17:57:31.653 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2021-05-18 17:57:31.658 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2021-05-18 17:58:31.920 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2021-05-18 17:58:31.929 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2021-05-18 17:58:31.936 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2021-05-18 17:58:31.946 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2021-05-18 17:58:33.367 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2021-05-18 17:58:33.374 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2021-05-18 17:58:33.383 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2021-05-18 17:58:33.395 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2021-05-18 17:58:35.564 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:40.934 !MESSAGE E:\RT-ThreadStudio\workspace\.metadata\Temp>cd /d E:/RT-ThreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.27/gener !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:40.951 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set RTT_ROOT= !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:40.955 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set ENV_ROOT=E:/RT-ThreadStudio/platform/env_released/env !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:40.958 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set RTT_EXEC_PATH=E:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:40.960 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set KCONF_EXEC_PATH=E:/RT-ThreadStudio/platform/env_released/env\tools\exec !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:40.963 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set RTT_CC=gcc !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:40.966 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set SCONS=E:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:40.968 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PKGS_ROOT=E:/RT-ThreadStudio/platform/env_released/env\packages !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:40.972 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/RT-ThreadStudio/jre/bin/server;E:/RT-ThreadStudio/jre/bin;E:/RT-ThreadStudio/jre/lib/amd64;E:\win_Xshell 6\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;E:\jde\bin;E:\jde\jre\bin;E:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:40.974 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/RT-ThreadStudio/jre/bin/server;E:/RT-ThreadStudio/jre/bin;E:/RT-ThreadStudio/jre/lib/amd64;E:\win_Xshell 6\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;E:\jde\bin;E:\jde\jre\bin;E:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:40.977 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/RT-ThreadStudio/jre/bin/server;E:/RT-ThreadStudio/jre/bin;E:/RT-ThreadStudio/jre/lib/amd64;E:\win_Xshell 6\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;E:\jde\bin;E:\jde\jre\bin;E:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:40.979 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/RT-ThreadStudio/platform/env_released/env\tools\bin;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/RT-ThreadStudio/jre/bin/server;E:/RT-ThreadStudio/jre/bin;E:/RT-ThreadStudio/jre/lib/amd64;E:\win_Xshell 6\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;E:\jde\bin;E:\jde\jre\bin;E:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:40.982 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;E:/RT-ThreadStudio/platform/env_released/env\tools\bin;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/RT-ThreadStudio/jre/bin/server;E:/RT-ThreadStudio/jre/bin;E:/RT-ThreadStudio/jre/lib/amd64;E:\win_Xshell 6\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;E:\jde\bin;E:\jde\jre\bin;E:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:40.984 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/RT-ThreadStudio/platform/env_released/env\tools\exec;E:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;E:/RT-ThreadStudio/platform/env_released/env\tools\bin;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/RT-ThreadStudio/jre/bin/server;E:/RT-ThreadStudio/jre/bin;E:/RT-ThreadStudio/jre/lib/amd64;E:\win_Xshell 6\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;E:\jde\bin;E:\jde\jre\bin;E:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:40.987 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/RT-ThreadStudio/platform/env_released/env\tools\qemu\qemu32;E:/RT-ThreadStudio/platform/env_released/env\tools\exec;E:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;E:/RT-ThreadStudio/platform/env_released/env\tools\bin;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/RT-ThreadStudio/jre/bin/server;E:/RT-ThreadStudio/jre/bin;E:/RT-ThreadStudio/jre/lib/amd64;E:\win_Xshell 6\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;E:\jde\bin;E:\jde\jre\bin;E:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:40.989 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PYTHONPATH=E:/RT-ThreadStudio/platform/env_released/env\tools\Python27; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:40.992 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/RT-ThreadStudio/platform/env_released/env\tools\qemu\qemu32;E:/RT-ThreadStudio/platform/env_released/env\tools\exec;E:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;E:/RT-ThreadStudio/platform/env_released/env\tools\bin;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/RT-ThreadStudio/jre/bin/server;E:/RT-ThreadStudio/jre/bin;E:/RT-ThreadStudio/jre/lib/amd64;E:\win_Xshell 6\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;E:\jde\bin;E:\jde\jre\bin;E:\RT-ThreadStudio;; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:40.994 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>"E:/RT-ThreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.27/gener/prj_gen.exe" --csp_project="true" --csp_parameter_file="E:\RT-ThreadStudio\workspace/.metadata/Temp/rtt_parameter_demo.json" -n xxx !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:43.298 !MESSAGE [7320] Failed to execute script main !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:43.302 !MESSAGE finally exit. !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:43.305 !MESSAGE Traceback (most recent call last): !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:43.308 !MESSAGE File "main.py", line 216, in
!ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:43.310 !MESSAGE File "site-packages\click\core.py", line 829, in __call__ !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:43.313 !MESSAGE File "site-packages\click\core.py", line 782, in main !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:43.315 !MESSAGE File "site-packages\click\core.py", line 1066, in invoke !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:43.318 !MESSAGE File "site-packages\click\core.py", line 610, in invoke !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:43.321 !MESSAGE File "main.py", line 183, in gen_prj_process !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:43.324 !MESSAGE File "backend\csp_proj\bridge_to_top.py", line 14, in csp_proj_gen !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:43.327 !MESSAGE File "c:\users\yaxing.chen\appdata\local\programs\python\python37-32\lib\codecs.py", line 322, in decode !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 17:58:43.331 !MESSAGE UnicodeDecodeError: 'utf-8' codec can't decode byte 0x84 in position 0: invalid start byte !SESSION 2021-05-18 18:03:36.034 ----------------------------------------------- eclipse.buildId=unknown java.version=1.8.0_144 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN Command-line arguments: -os win32 -ws win32 -arch x86_64 !ENTRY org.eclipse.egit.ui 2 0 2021-05-18 18:04:03.081 !MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git user global configuration and to define the default location to store repositories: 'C:\Users\HG_DENG'. If this is not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and EGit might behave differently since they see different configuration options. This warning can be switched off on the Team > Git > Confirmations and Warnings preference page. !ENTRY org.eclipse.launchbar.core 2 0 2021-05-18 18:04:08.770 !MESSAGE Enablement expression is missing for descriptor type org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2021-05-18 18:04:08.773 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2021-05-18 18:04:08.775 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.rt-thread.studio.project.ui 4 0 2021-05-18 18:04:21.454 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2021-05-18 18:04:21.459 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2021-05-18 18:04:21.465 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2021-05-18 18:04:21.478 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2021-05-18 18:04:23.624 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:26.949 !MESSAGE E:\RT-ThreadStudio\workspace\.metadata\Temp>cd /d E:/RT-ThreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.27/gener !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:26.959 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set RTT_ROOT= !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:26.962 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set ENV_ROOT=E:/RT-ThreadStudio/platform/env_released/env !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:26.965 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set RTT_EXEC_PATH=E:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:26.968 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set KCONF_EXEC_PATH=E:/RT-ThreadStudio/platform/env_released/env\tools\exec !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:26.971 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set RTT_CC=gcc !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:26.975 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set SCONS=E:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:26.978 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PKGS_ROOT=E:/RT-ThreadStudio/platform/env_released/env\packages !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:26.980 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/RT-ThreadStudio/jre/bin/server;E:/RT-ThreadStudio/jre/bin;E:/RT-ThreadStudio/jre/lib/amd64;E:\win_Xshell 6\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;E:\jde\bin;E:\jde\jre\bin;E:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:26.984 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/RT-ThreadStudio/jre/bin/server;E:/RT-ThreadStudio/jre/bin;E:/RT-ThreadStudio/jre/lib/amd64;E:\win_Xshell 6\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;E:\jde\bin;E:\jde\jre\bin;E:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:26.987 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/RT-ThreadStudio/jre/bin/server;E:/RT-ThreadStudio/jre/bin;E:/RT-ThreadStudio/jre/lib/amd64;E:\win_Xshell 6\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;E:\jde\bin;E:\jde\jre\bin;E:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:26.990 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/RT-ThreadStudio/platform/env_released/env\tools\bin;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/RT-ThreadStudio/jre/bin/server;E:/RT-ThreadStudio/jre/bin;E:/RT-ThreadStudio/jre/lib/amd64;E:\win_Xshell 6\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;E:\jde\bin;E:\jde\jre\bin;E:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:26.993 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;E:/RT-ThreadStudio/platform/env_released/env\tools\bin;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/RT-ThreadStudio/jre/bin/server;E:/RT-ThreadStudio/jre/bin;E:/RT-ThreadStudio/jre/lib/amd64;E:\win_Xshell 6\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;E:\jde\bin;E:\jde\jre\bin;E:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:26.996 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/RT-ThreadStudio/platform/env_released/env\tools\exec;E:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;E:/RT-ThreadStudio/platform/env_released/env\tools\bin;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/RT-ThreadStudio/jre/bin/server;E:/RT-ThreadStudio/jre/bin;E:/RT-ThreadStudio/jre/lib/amd64;E:\win_Xshell 6\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;E:\jde\bin;E:\jde\jre\bin;E:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:26.999 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/RT-ThreadStudio/platform/env_released/env\tools\qemu\qemu32;E:/RT-ThreadStudio/platform/env_released/env\tools\exec;E:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;E:/RT-ThreadStudio/platform/env_released/env\tools\bin;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/RT-ThreadStudio/jre/bin/server;E:/RT-ThreadStudio/jre/bin;E:/RT-ThreadStudio/jre/lib/amd64;E:\win_Xshell 6\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;E:\jde\bin;E:\jde\jre\bin;E:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:27.002 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PYTHONPATH=E:/RT-ThreadStudio/platform/env_released/env\tools\Python27; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:27.006 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/RT-ThreadStudio/platform/env_released/env\tools\qemu\qemu32;E:/RT-ThreadStudio/platform/env_released/env\tools\exec;E:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;E:/RT-ThreadStudio/platform/env_released/env\tools\bin;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/RT-ThreadStudio/jre/bin/server;E:/RT-ThreadStudio/jre/bin;E:/RT-ThreadStudio/jre/lib/amd64;E:\win_Xshell 6\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;E:\jde\bin;E:\jde\jre\bin;E:\RT-ThreadStudio;; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:27.009 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>"E:/RT-ThreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.27/gener/prj_gen.exe" --csp_project="true" --csp_parameter_file="E:\RT-ThreadStudio\workspace/.metadata/Temp/rtt_parameter_demo.json" -n xxx !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:28.338 !MESSAGE [7140] Failed to execute script main !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:28.344 !MESSAGE finally exit. !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:28.348 !MESSAGE Traceback (most recent call last): !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:28.353 !MESSAGE File "main.py", line 216, in
!ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:28.357 !MESSAGE File "site-packages\click\core.py", line 829, in __call__ !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:28.361 !MESSAGE File "site-packages\click\core.py", line 782, in main !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:28.363 !MESSAGE File "site-packages\click\core.py", line 1066, in invoke !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:28.366 !MESSAGE File "site-packages\click\core.py", line 610, in invoke !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:28.369 !MESSAGE File "main.py", line 183, in gen_prj_process !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:28.373 !MESSAGE File "backend\csp_proj\bridge_to_top.py", line 14, in csp_proj_gen !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:28.376 !MESSAGE File "c:\users\yaxing.chen\appdata\local\programs\python\python37-32\lib\codecs.py", line 322, in decode !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 18:04:28.380 !MESSAGE UnicodeDecodeError: 'utf-8' codec can't decode byte 0x84 in position 0: invalid start byte !SESSION 2021-05-18 19:44:35.689 ----------------------------------------------- eclipse.buildId=unknown java.version=1.8.0_144 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN Command-line arguments: -os win32 -ws win32 -arch x86_64 !ENTRY org.eclipse.egit.ui 2 0 2021-05-18 19:45:12.633 !MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git user global configuration and to define the default location to store repositories: 'C:\Users\HG_DENG'. If this is not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and EGit might behave differently since they see different configuration options. This warning can be switched off on the Team > Git > Confirmations and Warnings preference page. !ENTRY org.eclipse.launchbar.core 2 0 2021-05-18 19:45:18.751 !MESSAGE Enablement expression is missing for descriptor type org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2021-05-18 19:45:18.762 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2021-05-18 19:45:18.770 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.rt-thread.studio.project.ui 4 0 2021-05-18 19:45:39.400 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2021-05-18 19:45:39.409 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2021-05-18 19:45:39.418 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2021-05-18 19:45:39.432 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2021-05-18 19:45:41.627 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:44.805 !MESSAGE E:\RT-ThreadStudio\workspace\.metadata\Temp>cd /d E:/RT-ThreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.27/gener !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:44.812 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set RTT_ROOT= !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:44.820 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set ENV_ROOT=E:/RT-ThreadStudio/platform/env_released/env !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:44.826 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set RTT_EXEC_PATH=E:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:44.831 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set KCONF_EXEC_PATH=E:/RT-ThreadStudio/platform/env_released/env\tools\exec !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:44.837 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set RTT_CC=gcc !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:44.842 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set SCONS=E:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:44.848 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PKGS_ROOT=E:/RT-ThreadStudio/platform/env_released/env\packages !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:44.854 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/RT-ThreadStudio/jre/bin/server;E:/RT-ThreadStudio/jre/bin;E:/RT-ThreadStudio/jre/lib/amd64;E:\win_Xshell 6\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;E:\jde\bin;E:\jde\jre\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Users\HG_DENG\AppData\Local\Microsoft\WindowsApps;E:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:44.860 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/RT-ThreadStudio/jre/bin/server;E:/RT-ThreadStudio/jre/bin;E:/RT-ThreadStudio/jre/lib/amd64;E:\win_Xshell 6\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;E:\jde\bin;E:\jde\jre\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Users\HG_DENG\AppData\Local\Microsoft\WindowsApps;E:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:44.865 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/RT-ThreadStudio/jre/bin/server;E:/RT-ThreadStudio/jre/bin;E:/RT-ThreadStudio/jre/lib/amd64;E:\win_Xshell 6\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;E:\jde\bin;E:\jde\jre\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Users\HG_DENG\AppData\Local\Microsoft\WindowsApps;E:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:44.871 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/RT-ThreadStudio/platform/env_released/env\tools\bin;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/RT-ThreadStudio/jre/bin/server;E:/RT-ThreadStudio/jre/bin;E:/RT-ThreadStudio/jre/lib/amd64;E:\win_Xshell 6\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;E:\jde\bin;E:\jde\jre\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Users\HG_DENG\AppData\Local\Microsoft\WindowsApps;E:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:44.877 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;E:/RT-ThreadStudio/platform/env_released/env\tools\bin;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/RT-ThreadStudio/jre/bin/server;E:/RT-ThreadStudio/jre/bin;E:/RT-ThreadStudio/jre/lib/amd64;E:\win_Xshell 6\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;E:\jde\bin;E:\jde\jre\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Users\HG_DENG\AppData\Local\Microsoft\WindowsApps;E:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:44.883 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/RT-ThreadStudio/platform/env_released/env\tools\exec;E:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;E:/RT-ThreadStudio/platform/env_released/env\tools\bin;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/RT-ThreadStudio/jre/bin/server;E:/RT-ThreadStudio/jre/bin;E:/RT-ThreadStudio/jre/lib/amd64;E:\win_Xshell 6\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;E:\jde\bin;E:\jde\jre\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Users\HG_DENG\AppData\Local\Microsoft\WindowsApps;E:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:44.890 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/RT-ThreadStudio/platform/env_released/env\tools\qemu\qemu32;E:/RT-ThreadStudio/platform/env_released/env\tools\exec;E:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;E:/RT-ThreadStudio/platform/env_released/env\tools\bin;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/RT-ThreadStudio/jre/bin/server;E:/RT-ThreadStudio/jre/bin;E:/RT-ThreadStudio/jre/lib/amd64;E:\win_Xshell 6\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;E:\jde\bin;E:\jde\jre\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Users\HG_DENG\AppData\Local\Microsoft\WindowsApps;E:\RT-ThreadStudio; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:44.895 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PYTHONPATH=E:/RT-ThreadStudio/platform/env_released/env\tools\Python27; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:44.900 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>set PATH=E:/RT-ThreadStudio/platform/env_released/env\tools\qemu\qemu32;E:/RT-ThreadStudio/platform/env_released/env\tools\exec;E:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin;E:/RT-ThreadStudio/platform/env_released/env\tools\bin;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27\Scripts;E:/RT-ThreadStudio/platform/env_released/env\tools\Python27;E:/RT-ThreadStudio/platform/env_released/env\tools\MinGit-2.25.1-32-bit\cmd;E:/RT-ThreadStudio/jre/bin/server;E:/RT-ThreadStudio/jre/bin;E:/RT-ThreadStudio/jre/lib/amd64;E:\win_Xshell 6\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;E:\jde\bin;E:\jde\jre\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Users\HG_DENG\AppData\Local\Microsoft\WindowsApps;E:\RT-ThreadStudio;; !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:44.905 !MESSAGE E:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.27\gener>"E:/RT-ThreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.27/gener/prj_gen.exe" --csp_project="true" --csp_parameter_file="E:\RT-ThreadStudio\workspace/.metadata/Temp/rtt_parameter_demo.json" -n xxx !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:46.143 !MESSAGE [9272] Failed to execute script main !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:46.149 !MESSAGE finally exit. !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:46.157 !MESSAGE Traceback (most recent call last): !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:46.165 !MESSAGE File "main.py", line 216, in
!ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:46.173 !MESSAGE File "site-packages\click\core.py", line 829, in __call__ !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:46.179 !MESSAGE File "site-packages\click\core.py", line 782, in main !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:46.185 !MESSAGE File "site-packages\click\core.py", line 1066, in invoke !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:46.192 !MESSAGE File "site-packages\click\core.py", line 610, in invoke !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:46.199 !MESSAGE File "main.py", line 183, in gen_prj_process !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:46.205 !MESSAGE File "backend\csp_proj\bridge_to_top.py", line 14, in csp_proj_gen !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:46.213 !MESSAGE File "c:\users\yaxing.chen\appdata\local\programs\python\python37-32\lib\codecs.py", line 322, in decode !ENTRY org.rt-thread.studio.common.ui 1 0 2021-05-18 19:45:46.221 !MESSAGE UnicodeDecodeError: 'utf-8' codec can't decode byte 0x84 in position 0: invalid start byte ```
chenyaxing
2021-05-18
泥上偶然留指爪,鸿飞那复计东西。
`E:\RT-ThreadStudio\workspace/.metadata/Temp/rtt_parameter_demo.json` 这个文件贴出来看看
游走在01的海洋
2021-05-19
你的问题说的详细一些吧:比如创建工程的使用的完全版还是精简版;创建过程使用的教程是什么等;你这样一下贴代码问题,很多人没耐心看的 你先看看这个提问帖说明:https://club.rt-thread.org/ask/question/423914.html
2021-05-19
先安装一下微软的C++运行库。
649
deng_1040
M5311出现AT response get line failed!
可否将LWIP升级到2.1.2 和 2.0.3?
signal内核是不是有问题,还是我方法不对
关于在stm32F107CVT6中使用以太网芯片DM9161AEP的内存不足异常
4.0.1版本的看门狗是不是有bug?
workqueue中调用rt_i2c_transfer互斥锁线程bug
DMA 串口7 严重BUF反馈
rt_event_recv bug
小内存管理法里面heap_mem 初始化问题
kawaii_mqtt AT使用长时间运行死机的原因分析
