Encoder
encoder添加驱动后,drv_rtc.c报错
发布于 2021-05-29 17:27:33 浏览:1128
./libraries/drivers/drv_rtc.c:36:8: error: unknown type name 'RTC_HandleTypeDef' static RTC_HandleTypeDef RTC_Handler; ^ ../libraries/drivers/drv_rtc.c: In function 'get_rtc_timestamp': ../libraries/drivers/drv_rtc.c:40:5: error: unknown type name 'RTC_TimeTypeDef' RTC_TimeTypeDef RTC_TimeStruct = {0}; ^ ../libraries/drivers/drv_rtc.c:41:5: error: unknown type name 'RTC_DateTypeDef' RTC_DateTypeDef RTC_DateStruct = {0}; ^ ../libraries/drivers/drv_rtc.c:44:5: warning: implicit declaration of function 'HAL_RTC_GetTime' [-Wimplicit-function-declaration] HAL_RTC_GetTime(&RTC_Handler, &RTC_TimeStruct, RTC_FORMAT_BIN); ^ ../libraries/drivers/drv_rtc.c:44:52: error: 'RTC_FORMAT_BIN' undeclared (first use in this function) HAL_RTC_GetTime(&RTC_Handler, &RTC_TimeStruct, RTC_FORMAT_BIN); ^ ../libraries/drivers/drv_rtc.c:44:52: note: each undeclared identifier is reported only once for each function it appears in ../libraries/drivers/drv_rtc.c:45:5: warning: implicit declaration of function 'HAL_RTC_GetDate' [-Wimplicit-function-declaration] HAL_RTC_GetDate(&RTC_Handler, &RTC_DateStruct, RTC_FORMAT_BIN); ^ ../libraries/drivers/drv_rtc.c:47:36: error: request for member 'Seconds' in something not a structure or union tm_new.tm_sec = RTC_TimeStruct.Seconds; ^ ../libraries/drivers/drv_rtc.c:48:36: error: request for member 'Minutes' in something not a structure or union tm_new.tm_min = RTC_TimeStruct.Minutes; ^ ../libraries/drivers/drv_rtc.c:49:36: error: request for member 'Hours' in something not a structure or union tm_new.tm_hour = RTC_TimeStruct.Hours; ^ ../libraries/drivers/drv_rtc.c:50:36: error: request for member 'Date' in something not a structure or union tm_new.tm_mday = RTC_DateStruct.Date; ^ ../libraries/drivers/drv_rtc.c:51:36: error: request for member 'Month' in something not a structure or union tm_new.tm_mon = RTC_DateStruct.Month - 1; ^ ../libraries/drivers/drv_rtc.c:52:36: error: request for member 'Year' in something not a structure or union tm_new.tm_year = RTC_DateStruct.Year + 100; ^ ../libraries/drivers/drv_rtc.c: In function 'set_rtc_time_stamp': ../libraries/drivers/drv_rtc.c:60:5: error: unknown type name 'RTC_TimeTypeDef' RTC_TimeTypeDef RTC_TimeStruct = {0}; ^ ../libraries/drivers/drv_rtc.c:61:5: error: unknown type name 'RTC_DateTypeDef' RTC_DateTypeDef RTC_DateStruct = {0}; ^ ../libraries/drivers/drv_rtc.c:70:19: error: request for member 'Seconds' in something not a structure or union RTC_TimeStruct.Seconds = p_tm->tm_sec ; ^ ../libraries/drivers/drv_rtc.c:71:19: error: request for member 'Minutes' in something not a structure or union RTC_TimeStruct.Minutes = p_tm->tm_min ; ^ ../libraries/drivers/drv_rtc.c:72:19: error: request for member 'Hours' in something not a structure or union RTC_TimeStruct.Hours = p_tm->tm_hour; ^ ../libraries/drivers/drv_rtc.c:73:19: error: request for member 'Date' in something not a structure or union RTC_DateStruct.Date = p_tm->tm_mday; ^ ../libraries/drivers/drv_rtc.c:74:19: error: request for member 'Month' in something not a structure or union RTC_DateStruct.Month = p_tm->tm_mon + 1 ; ^ ../libraries/drivers/drv_rtc.c:75:19: error: request for member 'Year' in something not a structure or union RTC_DateStruct.Year = p_tm->tm_year - 100; ^ ../libraries/drivers/drv_rtc.c:76:19: error: request for member 'WeekDay' in something not a structure or union RTC_DateStruct.WeekDay = p_tm->tm_wday + 1; ^ ../libraries/drivers/drv_rtc.c:78:9: warning: implicit declaration of function 'HAL_RTC_SetTime' [-Wimplicit-function-declaration] if (HAL_RTC_SetTime(&RTC_Handler, &RTC_TimeStruct, RTC_FORMAT_BIN) != HAL_OK) ^ ../libraries/drivers/drv_rtc.c:78:56: error: 'RTC_FORMAT_BIN' undeclared (first use in this function) if (HAL_RTC_SetTime(&RTC_Handler, &RTC_TimeStruct, RTC_FORMAT_BIN) != HAL_OK) ^ ../libraries/drivers/drv_rtc.c:82:9: warning: implicit declaration of function 'HAL_RTC_SetDate' [-Wimplicit-function-declaration] if (HAL_RTC_SetDate(&RTC_Handler, &RTC_DateStruct, RTC_FORMAT_BIN) != HAL_OK) ^ ../libraries/drivers/drv_rtc.c: In function 'rt_rtc_config': ../libraries/drivers/drv_rtc.c:129:16: error: request for member 'Instance' in something not a structure or union RTC_Handler.Instance = RTC; ^ ../libraries/drivers/drv_rtc.c:158:20: error: request for member 'Init' in something not a structure or union RTC_Handler.Init.AsynchPrediv = 0X7F; ^ ../libraries/drivers/drv_rtc.c:160:20: error: request for member 'Init' in something not a structure or union RTC_Handler.Init.SynchPrediv = 0XFF; ^ ../libraries/drivers/drv_rtc.c:162:20: error: request for member 'Init' in something not a structure or union RTC_Handler.Init.HourFormat = RTC_HOURFORMAT_24; ^ ../libraries/drivers/drv_rtc.c:162:39: error: 'RTC_HOURFORMAT_24' undeclared (first use in this function) RTC_Handler.Init.HourFormat = RTC_HOURFORMAT_24; ^ ../libraries/drivers/drv_rtc.c:163:20: error: request for member 'Init' in something not a structure or union RTC_Handler.Init.OutPut = RTC_OUTPUT_DISABLE; ^ ../libraries/drivers/drv_rtc.c:163:35: error: 'RTC_OUTPUT_DISABLE' undeclared (first use in this function) RTC_Handler.Init.OutPut = RTC_OUTPUT_DISABLE; ^ ../libraries/drivers/drv_rtc.c:164:20: error: request for member 'Init' in something not a structure or union RTC_Handler.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH; ^ ../libraries/drivers/drv_rtc.c:164:43: error: 'RTC_OUTPUT_POLARITY_HIGH' undeclared (first use in this function) RTC_Handler.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH; ^ ../libraries/drivers/drv_rtc.c:165:20: error: request for member 'Init' in something not a structure or union RTC_Handler.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN; ^ ../libraries/drivers/drv_rtc.c:165:39: error: 'RTC_OUTPUT_TYPE_OPENDRAIN' undeclared (first use in this function) RTC_Handler.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN; ^ ../libraries/drivers/drv_rtc.c:167:13: warning: implicit declaration of function 'HAL_RTC_Init' [-Wimplicit-function-declaration] if (HAL_RTC_Init(&RTC_Handler) != HAL_OK) ^ make: *** [libraries/drivers/subdir.mk:51: libraries/drivers/drv_rtc.o] Error 1 make: *** Waiting for unfinished jobs.... "make -j8 all" terminated with exit code 2. Build might be incomplete. 我尝试了各种方法终于把ART-PI的编码器驱动加进去了,增加了所有定义后,编码器文件没报错,但是rtc开始报错了,,实在没办法了,,求大家帮我看看哪里有问题“?
wwk
2021-05-29
问题刚找到,,谢谢大家。
2021-05-29
应该是你的RTC没有定义好。请和对一下rtconfig.h中的有关RTC内容。
1.1k
wwk
RTC驱动框架几点建议
[新人试水] LPC1768 Nano3_9 添加RTC
STM32 关于RTC的问题
stm32f4xx-HAL BSP的RTC设置不对
关于STM32的RTC设置年份不正确的问题
RTT的RTC驱动调试
rtc驱动中的bkp模块起不到防止时间的重新设置
rtc时钟跑十几个小时后,比实际时间快几秒怎么解决
stm32如何断电之后开发板rtc时间继续往前跑
