相同优先级时间片轮转调度
timeslice_sample
跑timeslice_sample的示例,运行结果与文档说明的结果不一样
发布于 2021-06-08 12:01:36 浏览:635
单片机型号:STM32F070RBT6 使用MDK移植,或者使用RT—Thread-studio创建工程,同样跑的timeslice_sample的示例程序,运行结果都不一样,并且与文档中心或者内核实验手册描述的结果都不一样。 代码如下 ```c #include
#define THREAD_STACK_SIZE 1024 #define THREAD_PRIORITY 20 #define THREAD_TIMESLICE 10 /* 线程入口 */ static void thread_entry(void* parameter) { rt_uint32_t value; rt_uint32_t count = 0; value = (rt_uint32_t)parameter; while (1) { if(0 == (count % 5)) { rt_kprintf("thread %d is running ,thread %d count = %d\n", value , value , count); if(count > 200) return; } count++; } } int timeslice_sample(void) { rt_thread_t tid; /* 创建线程1 */ tid = rt_thread_create("thread1", thread_entry, (void*)1, THREAD_STACK_SIZE, THREAD_PRIORITY, THREAD_TIMESLICE); if (tid != RT_NULL) rt_thread_startup(tid); /* 创建线程2 */ tid = rt_thread_create("thread2", thread_entry, (void*)2, THREAD_STACK_SIZE, THREAD_PRIORITY, THREAD_TIMESLICE-5); if (tid != RT_NULL) rt_thread_startup(tid); return 0; } /* 导出到 msh 命令列表中 */ MSH_CMD_EXPORT(timeslice_sample, timeslice sample); ``` MDK移植运行结果如下: ``` msh >timeslice_sample thread 1 is running ,thread 1 count = 0 thread 1 is running ,thread 1 count = 5 thread 1 is running ,thread 1 count = 10 thread 1 is running ,thread 1 count = 15 thread 1 is running ,thread 1 count = 20 thread 1 is running ,thread 1 count = 25 thread 1 is running ,thread 1 count = 30 thread 1 is running ,thread 1 count = 35 thread 1 is running ,thread 1 count = 40 thread 1 is running ,thread 1 count = 45 thread 1 is running ,thread 1 count = 50 thread 1 is running ,thread 1 count = 55 thread 1 is running ,thread 1 count = 60 thread 1 is running ,thread 1 count = 65 thread 1 is running ,thread 1 count = 70 thread 1 is running ,thread 1 count = 75 thread 1 is running ,thread 1 count = 80 thread 1 is running ,thread 1 count = 85 thread 1 is running ,thread 1 count = 90 thread 1 is running ,thread 1 count = 95 thread 1 is running ,thread 1 count = 100 thread 1 is running ,thread 1 count = 105 thread 1 is running ,thread 1 count = 110 thread 1 is running ,thread 1 count = 115 thread 1 is running ,thread 1 count = 120 thread 1 is running ,thread 1 count = 125 thread 1 is running ,thread 1 count = 130 thread 1 is running ,thread 1 count = 135 thread 1 is running ,thread 1 count = 140 thread 1 is running ,thread 1 count = 145 thread 1 is running ,thread 1 count = 150 thread 1 is running ,thread 1 count = 155 thread 1 is running ,thread 1 count = 160 thread 1 is running ,thread 1 count = 165 thread 1 is running ,thread 1 count = 170 thread 1 is running ,thread 1 count = 175 thread 1 is running ,thread 1 count = 180 thread 1 is running ,thread 1 count = 185 thread 1 is running ,thread 1 count = 190 thread 1 is running ,thread 1 count = 195 thread 1 is running ,thread 1 count = 200 thread 1 is running ,thread 1 count = 205 thread 2 is running ,thread 2 count = 0 thread 2 is running ,thread 2 count = 5 thread 2 is running ,thread 2 count = 10 thread 2 is running ,thread 2 count = 15 thread 2 is running ,thread 2 count = 20 thread 2 is running ,thread 2 count = 25 thread 2 is running ,thread 2 count = 30 thread 2 is running ,thread 2 count = 35 thread 2 is running ,thread 2 count = 40 thread 2 is running ,thread 2 count = 45 thread 2 is running ,thread 2 count = 50 thread 2 is running ,thread 2 count = 55 thread 2 is running ,thread 2 count = 60 thread 2 is running ,thread 2 count = 65 thread 2 is running ,thread 2 count = 70 thread 2 is running ,thread 2 count = 75 thread 2 is running ,thread 2 count = 80 thread 2 is running ,thread 2 count = 85 thread 2 is running ,thread 2 count = 90 thread 2 is running ,thread 2 count = 95 thread 2 is running ,thread 2 count = 100 thread 2 is running ,thread 2 count = 105 thread 2 is running ,thread 2 count = 110 thread 2 is running ,thread 2 count = 115 thread 2 is running ,thread 2 count = 120 thread 2 is running ,thread 2 count = 125 thread 2 is running ,thread 2 count = 130 thread 2 is running ,thread 2 count = 135 thread 2 is running ,thread 2 count = 140 thread 2 is running ,thread 2 count = 145 thread 2 is running ,thread 2 count = 150 thread 2 is running ,thread 2 count = 155 thread 2 is running ,thread 2 count = 160 thread 2 is running ,thread 2 count = 165 thread 2 is running ,thread 2 count = 170 thread 2 is running ,thread 2 count = 175 thread 2 is running ,thread 2 count = 180 thread 2 is running ,thread 2 count = 185 thread 2 is running ,thread 2 count = 190 thread 2 is running ,thread 2 count = 195 thread 2 is running ,thread 2 count = 200 thread 2 is running ,thread 2 count = 205 msh >timeslice_sample thread 1 is running ,thread 1 count = 0 thread 1 is running ,thread 1 count = 5 thread 1 is running ,thread 1 count = 10 thread 1 is running ,thread 1 count = 15 thread 1 is running ,thread 1 count = 20 thread 1 is running ,thread 1 count = 25 thread 1 is running ,thread 1 count = 30 thread 1 is running ,thread 1 count = 35 thread 1 is running ,thread 1 count = 40 thread 1 is running ,thread 1 count = 45 thread 1 is running ,thread 1 count = 50 thread 1 is running ,thread 1 count = 55 thread 1 is running ,thread 1 count = 60 thread 1 is running ,thread 1 count = 65 thread 1 is running ,thread 1 count = 70 thread 1 is running ,thread 1 count = 75 thread 1 is running ,thread 1 count = 80 thread 1 is running ,thread 1 count = 85 thread 1 is running ,thread 1 count = 90 thread 1 is running ,thread 1 count = 95 thread 1 is running ,thread 1 count = 100 thread 1 is running ,thread 1 count = 105 thread 1 is running ,thread 1 count = 110 thread 1 is running ,thread 1 count = 115 thread 1 is running ,thread 1 count = 120 thread 1 is running ,thread 1 count = 125 thread 1 is running ,thread 1 count = 130 thread 1 is running ,thread 1 count = 135 thread 1 is running ,thread 1 count = 140 thread 1 is running ,thread 1 count = 145 thread 1 is running ,thread 1 count = 150 thread 1 is running ,thread 1 count = 155 thread 1 is running ,thread 1 count = 160 thread 1 is running ,thread 1 count = 165 thread 1 is running ,thread 1 count = 170 thread 1 is running ,thread 1 count = 175 thread 1 is running ,thread 1 count = 180 thread 1 is running ,thread 1 count = 185 thread 1 is running ,thread 1 count = 190 thread 1 is running ,thread 1 count = 195 thread 1 is running ,thread 1 count = 200 thread 1 is running ,thread 1 count = 205 thread 2 is running ,thread 2 count = 0 thread 2 is running ,thread 2 count = 5 thread 2 is running ,thread 2 count = 10 thread 2 is running ,thread 2 count = 15 thread 2 is running ,thread 2 count = 20 thread 2 is running ,thread 2 count = 25 thread 2 is running ,thread 2 count = 30 thread 2 is running ,thread 2 count = 35 thread 2 is running ,thread 2 count = 40 thread 2 is running ,thread 2 count = 45 thread 2 is running ,thread 2 count = 50 thread 2 is running ,thread 2 count = 55 thread 2 is running ,thread 2 count = 60 thread 2 is running ,thread 2 count = 65 thread 2 is running ,thread 2 count = 70 thread 2 is running ,thread 2 count = 75 thread 2 is running ,thread 2 count = 80 thread 2 is running ,thread 2 count = 85 thread 2 is running ,thread 2 count = 90 thread 2 is running ,thread 2 count = 95 thread 2 is running ,thread 2 count = 100 thread 2 is running ,thread 2 count = 105 thread 2 is running ,thread 2 count = 110 thread 2 is running ,thread 2 count = 115 thread 2 is running ,thread 2 count = 120 thread 2 is running ,thread 2 count = 125 thread 2 is running ,thread 2 count = 130 thread 2 is running ,thread 2 count = 135 thread 2 is running ,thread 2 count = 140 thread 2 is running ,thread 2 count = 145 thread 2 is running ,thread 2 count = 150 thread 2 is running ,thread 2 count = 155 thread 2 is running ,thread 2 count = 160 thread 2 is running ,thread 2 count = 165 thread 2 is running ,thread 2 count = 170 thread 2 is running ,thread 2 count = 175 thread 2 is running ,thread 2 count = 180 thread 2 is running ,thread 2 count = 185 thread 2 is running ,thread 2 count = 190 thread 2 is running ,thread 2 count = 195 thread 2 is running ,thread 2 count = 200 thread 2 is running ,thread 2 count = 205 msh > ``` 使用RT—Thread-studio创建工程,跑timeslice_sample的示例程序运行结果如下: ``` msh >timeslice_sample msh >thread 1 is running ,thread 1 count = 0 thread 1 is running ,thread 1 count = 5 thread 1 is running ,thread 2 count = 135thread 1 is running ,thread 1 count = 15 thread 1 is running ,thread 2 count = 205thread 1 is running ,thread 1 count = 25 thread 1 is running ,thread 1 count = 30 thread 1 is running ,thread 1 count = 35 thread 1 is running ,thread 1 count = 40 thread 1 is running ,thread 1 count = 45 thread 1 is running ,thread 1 count = 50 thread 1 is running ,thread 1 count = 55 thread 1 is running ,thread 1 count = 60 thread 1 is running ,thread 1 count = 65 thread 1 is running ,thread 1 count = 70 thread 1 is running ,thread 1 count = 75 thread 1 is running ,thread 1 count = 80 thread 1 is running ,thread 1 count = 85 thread 1 is running ,thread 1 count = 90 thread 1 is running ,thread 1 count = 95 thread 1 is running ,thread 1 count = 100 thread 1 is running ,thread 1 count = 105 thread 1 is running ,thread 1 count = 110 thread 1 is running ,thread 1 count = 115 thread 1 is running ,thread 1 count = 120 thread 1 is running ,thread 1 count = 125 thread 1 is running ,thread 1 count = 130 thread 1 is running ,thread 1 count = 135 thread 1 is running ,thread 1 count = 140 thread 1 is running ,thread 1 count = 145 thread 1 is running ,thread 1 count = 150 thread 1 is running ,thread 1 count = 155 thread 1 is running ,thread 1 count = 160 thread 1 is running ,thread 1 count = 165 thread 1 is running ,thread 1 count = 170 thread 1 is running ,thread 1 count = 175 thread 1 is running ,thread 1 count = 180 thread 1 is running ,thread 1 count = 185 thread 1 is running ,thread 1 count = 190 thread 1 is running ,thread 1 count = 195 thread 1 is running ,thread 1 count = 200 thread 1 is running ,thread 1 count = 205 ``` 如上所示,结果不一样
zhkag
2021-06-08
你看tshell的优先级一样吗? tshell的优先级对它也是有影响的
2021-06-08
就是2个线程轮询,因为优先级一样,结果应该一致才对,编译器有所不同,优化的效果可能也不一样。
635
CTUS_9871
关于时间片轮询中优先级高低导致轮询出错的问题
时间片轮转调度,,,,,,,,
时间片轮转调度,,,,,,
线程创建函数create最后的tick的作用?
RT-Thread 时间片示例问题
时间片例程 结果和pdf给出的结果不同
新手问题:刚开始学,看到优先级和时间片,有个问题问一下
没有相同优先级线程时,线程时间片的问题
关于互斥量与线程时间片的问题
时间片调度与超时调度
MCXN947测评系列(二)串口设备测评
猪的行独
