串口收发不定长数据存在乱码和丢包
发布于 2021-06-09 15:33:08 浏览:1168
官方的串口demo3,串口收发不定长数据。源码不修改,只是更改了串口端号。串口1收发数据,串口2进行log观察。发现存在丢包、乱码现象。 ``` /* * Copyright (c) 2006-2021, RT-Thread Development Team * * SPDX-License-Identifier: Apache-2.0 * * Change Logs: * Date Author Notes * 2021-06-02 MF the first version */ #include
#define SAMPLE_UART_NAME "uart1" #define DATA_CMD_END '\r' /* 结束位设置为 \r,即回车符 */ #define ONE_DATA_MAXLEN 20 /* 不定长数据的最大长度 */ /* 用于接收消息的信号量 */ static struct rt_semaphore rx_sem; static rt_device_t serial; /* 接收数据回调函数 */ static rt_err_t uart_rx_ind(rt_device_t dev, rt_size_t size) { /* 串口接收到数据后产生中断,调用此回调函数,然后发送接收信号量 */ if (size > 0) { rt_sem_release(&rx_sem); } return RT_EOK; } static char uart_sample_get_char(void) { char ch; while (rt_device_read(serial, 0, &ch, 1) == 0) { rt_sem_control(&rx_sem, RT_IPC_CMD_RESET, RT_NULL); rt_sem_take(&rx_sem, RT_WAITING_FOREVER); } return ch; } /* 数据解析线程 */ static void data_parsing(void) { char ch; char data[ONE_DATA_MAXLEN]; static char i = 0; while (1) { ch = uart_sample_get_char(); rt_device_write(serial, 0, &ch, 1); if(ch == DATA_CMD_END) { data[i++] = '\0'; rt_kprintf("data=%s\r\n",data); i = 0; continue; } i = (i >= ONE_DATA_MAXLEN-1) ? ONE_DATA_MAXLEN-1 : i; data[i++] = ch; } } static int u(int argc, char *argv[]) { rt_err_t ret = RT_EOK; char uart_name[RT_NAME_MAX]; char str[] = "hello RT-Thread!\r\n"; if (argc == 2) { rt_strncpy(uart_name, argv[1], RT_NAME_MAX); } else { rt_strncpy(uart_name, SAMPLE_UART_NAME, RT_NAME_MAX); } /* 查找系统中的串口设备 */ serial = rt_device_find(uart_name); if (!serial) { rt_kprintf("find %s failed!\n", uart_name); return RT_ERROR; } /* 初始化信号量 */ rt_sem_init(&rx_sem, "rx_sem", 0, RT_IPC_FLAG_FIFO); /* 以中断接收及轮询发送模式打开串口设备 */ rt_device_open(serial, RT_DEVICE_FLAG_INT_RX); /* 设置接收回调函数 */ rt_device_set_rx_indicate(serial, uart_rx_ind); /* 发送字符串 */ rt_device_write(serial, 0, str, (sizeof(str) - 1)); /* 创建 serial 线程 */ rt_thread_t thread = rt_thread_create("serial", (void (*)(void *parameter))data_parsing, RT_NULL, 1024, 25, 10); /* 创建成功则启动线程 */ if (thread != RT_NULL) { rt_thread_startup(thread); } else { ret = RT_ERROR; } return ret; } /* 导出到 msh 命令列表中 */ MSH_CMD_EXPORT(u, uart device sample); ``` ![4fd122da71ebfa8b21fe990bf5ea6d84.png.webp](https://oss-club.rt-thread.org/uploads/20210609/4fd122da71ebfa8b21fe990bf5ea6d84.png.webp)
123
2021-07-11
之前有网友遇到这种情况是串口配置没配好,芯片型号没选对。
zhkag
2021-06-09
您的发过同样的问题吧?别重复发相同的问题 如果只更改了串口号的话才出现的问题,建议查看这两个串口初始化有什么不同的地方,去排查原因
elegy
2021-06-21
结帖
1.2k
elegy
26
串口DMA发送数据时,数据被覆盖
关于串口DMA模式下rt_device_close问题
finsh 控制台 适配 RS 485请大神指点????
串口无法接受数据,但可以发送
串口如何有效的清除掉接收缓冲,而不必一个一个的去读取
串口接收使用方式问题
雅特力FINSH问题
MCXN947测评系列(二)串口设备测评
