bench
SFUD bench测试失败
发布于 2021-06-15 15:51:49 浏览:1024
1、测试环境 硬件:I.MX 1052 rtthread版本:4.0.3 IDE版本:keil 5.27 Flash芯片:W25Q128 SPI:4线spi,非qspi 2、初始化打印如下 ``` [W/SFUD] [SFUD] Warning: The OS tick(500) is less than 1000. So the flash write will take more time. [D/SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud.c:861) The flash device manufacturer ID is 0xEF, memory type ID is 0x40, capaci [D/SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:131) Check SFDP header is OK. The reversion is V1.5, NPN is 0. [D/SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:173) Check JEDEC basic flash parameter header is OK. The table id is 0, [D/SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:203) JEDEC basic flash parameter table info: [D/SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:204) MSB-LSB 3 2 1 0 [D/SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0001] 0xFF 0xF9 0x20 0xE5 [D/SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0002] 0x07 0xFF 0xFF 0xFF [D/SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0003] 0x6B 0x08 0xEB 0x44 [D/SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0004] 0xBB 0x42 0x3B 0x08 [D/SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0005] 0xFF 0xFF 0xFF 0xFE [D/SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0006] 0x00 0x00 0xFF 0xFF [D/SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0007] 0xEB 0x40 0xFF 0xFF [D/SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0008] 0x52 0x0F 0x20 0x0C [D/SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0009] 0x00 0x00 0xD8 0x10 [D/SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:215) 4 KB Erase is supported throughout the device. Command is 0x20. [D/SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:234) Write granularity is 64 bytes or larger. [D/SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:245) Target flash status register is non-volatile. [D/SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:271) 3-Byte only addressing. [D/SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:305) Capacity is 16777216 Bytes. [D/SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:311) Flash device supports 4KB block erase. Command is 0x20. [D/SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:311) Flash device supports 32KB block erase. Command is 0x52. [D/SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:311) Flash device supports 64KB block erase. Command is 0xD8. [I/SFUD] Find a Winbond flash chip. Size is 16777216 bytes. [D/SFUD] (..\..\..\components\drivers\spi\sfud\src\sfud.c:840) Flash device reset success. [I/SFUD] norflash0 flash device is initialize success. [I/SFUD] Probe SPI flash norflash0 by SPI device spi30 success. ``` 3、msh 指令测试如下,测试正常 ``` msh >sf read 0 32 Read the sf_cmd flash data success. Start from 0x00000000, size is 32. The data is: Offset (h) 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F [00000000] FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ [00000010] FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ msh >sf write 0 0 1 2 3 4 5 6 7 Too many args ! We only Use: sf write 0 0 1 2 3 4 5 6 Write the sf_cmd flash data success. Start from 0x00000000, size is 7. Write data: 0 1 2 3 4 5 6 . msh >sf write 7 7 8 9 10 11 12 13 14 Too many args ! We only Use: sf write 7 7 8 9 10 11 12 13 Write the sf_cmd flash data success. Start from 0x00000007, size is 7. Write data: 7 8 9 10 11 12 13 . msh >sf read 0 32 Read the sf_cmd flash data success. Start from 0x00000000, size is 32. The data is: Offset (h) 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F [00000000] 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D FF FF ................ [00000010] FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ``` 4、sf bench 测试,读失败 ``` msh >sf bench yes Erasing the sf_cmd 16777216 bytes data, waiting... Erase benchmark success, total time: 35.413S. Writing the sf_cmd 16777216 bytes data, waiting... Write benchmark success, total time: 131.036S. Reading the sf_cmd 16777216 bytes data, waiting... Data check ERROR! Please check you flash by other command. Read sf_cmd failed, already rd for 0 bytes, read 256 each time Read benchmark has an error. Error code: 3. This flash operate has an error. Error code: 3. ``` 比较奇怪的一个点是,bench测试失败,在通过sf read/write 测试,读写不正常。 但是在程序启动后测试都正常, easyflash也能正常启动,但是bench测试通不过 ``` msh >pr printenv msh >printenv iap_need_copy_app=0 iap_need_crc32_check=0 iap_copy_app_size=0 stop_in_bootloader=0 mode: next generation size: 188/4096 bytes. msh >seten setenv msh >setenv boottime 0 msh >saveenv msh >pr printenv msh >printenv iap_need_copy_app=0 iap_need_crc32_check=0 iap_copy_app_size=0 stop_in_bootloader=0 boottime=0 mode: next generation size: 221/4096 bytes. ```
zhkag
2021-06-15
1、 > 在通过sf read/write 测试,读写不正常。 我看sf read/write是正常的啊 2、其次你要明白bench测试,测试的到底是什么
2021-06-15
我估计是你的os tick设置不对:Warning: The OS tick(500) is less than 1000.
1k
freedom195
好好学习,天天向上
30
53
【分享】如何使用 SFUD 库来操作 SPI Flash 设备
SFUD怎么使用
请教大家一下关于 SFUD 的的问题
移植sfud
使用SFUD操作FLASH
env使用easyflash不是3.2.4版本,而且没有type插件?
新增了W25X32设备成功,无法格式化
easyflash随着数据存储量增加,耗费时间加长
关于SFDP的问题
spi nand flash 能使用SFUD驱动吗
FRDM-MCXN94 7Flash实践--W25Q64
