RS485
DMA收发
串口2 DMA收发 485 波特率115200时正常,到了230400就不正常了
发布于 2021-06-21 03:28:22 浏览:1653
开发环境:STM32CubeMX RTT:4.03 芯片:STM32F407 ```c #include "uart2.h" #include
#define uart2_tempsum 120 //串口缓冲数据个数 uint8_t uart2_rx[uart2_tempsum]={0}; //串口发送缓冲个数 uint8_t uart2_tx[uart2_tempsum]={0}; //串口接收缓冲个数 uint8_t uart2_temp[uart2_tempsum]={0}; //串口临时缓冲 u16 uart2_ReceiveLen=0; //串口接收的数据个数 u16 uart2_SendLen=0; //串口发送的数据个数 struct serial_configure config2 = RT_SERIAL_CONFIG_DEFAULT; /* 初始化配置参数 */ #define UART2_NAME "uart2" // 串口设备名称 static rt_device_t uart2_serial; //串口设备句柄 static struct rt_messagequeue rx_mq2; //消息队列控制块 /* 串口接收消息结构*/ struct rx_msg { rt_device_t dev; rt_size_t size; }; /* 接收数据回调函数 */ static rt_err_t uart2_Receive(rt_device_t dev, rt_size_t size) { struct rx_msg msg; rt_err_t result; msg.dev = dev; msg.size = size; result = rt_mq_send(&rx_mq2, &msg, sizeof(msg)); if ( result == -RT_EFULL) { /* 消息队列满 */ rt_kprintf("message queue full!\n"); } return result; } /* 接收数据回调函数 */ static rt_err_t uart2_Send(rt_device_t dev, rt_size_t size) { EN2=0; return 0; } static void serial_thread_entry(void *parameter) { struct rx_msg msg; rt_err_t result; rt_uint32_t rx_length; static char rx_buffer[RT_SERIAL_RB_BUFSZ + 1]; rt_thread_mdelay(3000); uart2_serial = rt_device_find(UART2_NAME); //查找串口设备 if (!uart2_serial) { rt_kprintf("find %s failed!\n", UART2_NAME); return RT_ERROR; } /* 初始化消息队列 */ rt_mq_init(&rx_mq2, "rx_mq2", uart2_temp, /* 存放消息的缓冲区 */ sizeof(struct rx_msg), /* 一条消息的最大长度 */ uart2_tempsum, /* 存放消息的缓冲区大小 */ RT_IPC_FLAG_FIFO); /* 如果有多个线程等待,按照先来先得到的方法分配消息 */ rt_device_control(uart2_serial, RT_DEVICE_CTRL_CONFIG, &config2); /* 以 DMA 接收及轮询发送方式打开串口设备 */ rt_device_open(uart2_serial, RT_DEVICE_FLAG_DMA_RX|RT_DEVICE_FLAG_DMA_TX); /* 设置接收回调函数 */ rt_device_set_rx_indicate(uart2_serial, uart2_Receive); /* 设置发送回调函数 */ rt_device_set_tx_complete(uart2_serial, uart2_Send); /* 发送字符串 */ //rt_device_write(uart2_serial, 0, str, (sizeof(str) - 1)); while (1) { rt_memset(&msg, 0, sizeof(msg)); /* 从消息队列中读取消息*/ result = rt_mq_recv(&rx_mq2, &msg, sizeof(msg), RT_WAITING_FOREVER); if (result == RT_EOK) { /* 从串口读取数据*/ rx_length = rt_device_read(msg.dev, 0, rx_buffer, msg.size); //rx_buffer[rx_length] = '\0'; /* 通过串口设备 uart2_serial 输出读取到的消息 */ EN2=1; rt_device_write(uart2_serial, 0, rx_buffer, rx_length); //EN2=0; /* 打印数据 */ rt_kprintf("%d\n",rx_length); } } } //baud_rate : 修改波特率 //data_bits : 数据位 //stop_bits : 停止位 //parity : 校验位 int uart2_dma_start(u16 baud_rate,u16 data_bits,u16 stop_bits,u16 parity) { int res; /* step2:修改串口配置参数 */ config2.baud_rate = baud_rate; //修改波特率为 9600 config2.data_bits = data_bits; //数据位 8 config2.stop_bits = stop_bits; //停止位 1 config2.bufsz = 128; //修改缓冲区 buff size 为 128 config2.parity = parity; //无奇偶校验位 /* 创建 uart2_serial 线程 */ rt_thread_t thread = rt_thread_create("uart2_serial", serial_thread_entry, RT_NULL, 1024, 25, 10); /* 创建成功则启动线程 */ if (thread != RT_NULL) { rt_thread_startup(thread); } else { rt_kprintf("uart2_dma_start failed\n"); res = -1; } return res; } ``` ![image.png](https://oss-club.rt-thread.org/uploads/20210621/fd2dcb6e50379e5f90474fa258a45f65.png.webp) ![image.png](https://oss-club.rt-thread.org/uploads/20210621/92e96c347ea1ac71842a2d6bc501ec14.png.webp)
Acuity
2021-06-22
参考裸机DMA收发实现,1.5Mbps波特率不翻车:[https://acuity.blog.csdn.net/article/details/108367512](https://acuity.blog.csdn.net/article/details/108367512)
2021-06-21
串口速率不能过高,速率合适就好。
123
2021-06-21
问题应该是485硬件部分的问题。485主频支持多高的频率?有没有对硬件进行测试?拉个示波器看看波形最好了,像一些低成本的485通信,速率超过9600就不是很稳定了。
qq280502071
2021-06-21
改好了 用HAL库初始化 关闭DMA接收发送中断,只是用了IDLE空闲与发送完成TC中断 初始化后,DMA接收开起。 发送前开起TC中断,RS485设置为发送模式,数据发送后,TC中断,关闭TC中断,并清除标志,485设置为接收方式,开起下一次中断。 为了加快处理速度,中断里用的是寄存器操作。 ![image.png](https://oss-club.rt-thread.org/uploads/20210621/3aa9681fc37e239defc8def8a82f17d0.png) 结贴。
2021-06-21
用消息队列不如用信号量,用信号量不如用rt_thread_yield rt_thread_suspend rt_thread_resume 等方法
1.7k
qq280502071
串口三种发送方式下485收发引脚控制,轮询发送,中断发送,DMA发送
RTT系统写串口部分,串口用的RS485有问题
关于485软件包无法发送超时的问题
关于485软件包PARITY_EVEN的问题
关于485软件包发送后无法接收的问题
485软件包的“RS485_SAMPLE_MASTER_PIN”怎么取值?
libmodbus基于RS485使用偶校验时发送数据出错
485半双工收发问题
f407在进行tcp通信的情况下,能否使用uart2进行485通信
遇到一个奇怪的现象,麻烦各位大神帮忙分析一下。
NXP MCXN947测评之 adc
