mbedtls
MBEDTLS_TIMING_C 的作用
发布于 2021-07-12 18:37:20 浏览:1138
```c /** * \def MBEDTLS_TIMING_C * * Enable the semi-portable timing interface. * * \note The provided implementation only works on POSIX/Unix (including Linux, * BSD and OS X) and Windows. On other platforms, you can either disable that * module and provide your own implementations of the callbacks needed by * \c mbedtls_ssl_set_timer_cb() for DTLS, or leave it enabled and provide * your own implementation of the whole module by setting * \c MBEDTLS_TIMING_ALT in the current file. * * \note See also our Knowledge Base article about porting to a new * environment: * https://tls.mbed.org/kb/how-to/how-do-i-port-mbed-tls-to-a-new-environment-OS * * Module: library/timing.c * Caller: library/havege.c * * This module is used by the HAVEGE random number generator. */ #define MBEDTLS_TIMING_C ``` MBEDTLS_TIMING_C,在mbedtld初始化时 会调用到查询rtc设备,查询当前的时间。但是现在没有注册rtc设备,这个宏定义是否能屏蔽呢
2021-07-12
参考这个: [求助 mbedtls 验证 CA 证书的问题](https://club.rt-thread.org/ask/question/429813.html) 测试期间不校验证书是可以屏蔽的,产品中为了安全,需要RTC来确认时间。 所以要校验证书,还得先校时。
1.1k
Lavague
libcurl2rtt编译失败
rt-thread + mbedTLS 连接阿里云ssl握手不成功
rt-thread+polarssl https连接阿里云握手失败?
mbedtls+ stm32f411 握手耗时15s
mbedtls 定义全局变量就会死机
MbedTLS软件包编译失败 unknown type name 'DIR'
mbedtls/config.h文件缺失
mbedtls_client_read data error 错误
socket使用SAL TLS没有反应
