bug反馈
ringbuffer_环形缓冲区
对ringbuffer中rt_ringbuffer_put_force函数的疑问
发布于 2021-07-16 10:06:17 浏览:1623
[tocm] 最近研究驱动框架,顺带研读了ringbuffer源代码,发现一处疑问,个人认为是bug,也可能能力有限分析不对,请各位大佬批评指正,代码如下: ```c rt_size_t rt_ringbuffer_put_force(struct rt_ringbuffer *rb, const rt_uint8_t *ptr, rt_uint16_t length) { rt_uint16_t space_length; RT_ASSERT(rb != RT_NULL); space_length = rt_ringbuffer_space_len(rb); if (length > rb->buffer_size) { ptr = &ptr[length - rb->buffer_size]; length = rb->buffer_size; } if (rb->buffer_size - rb->write_index > length) { /* read_index - write_index = empty space */ memcpy(&rb->buffer_ptr[rb->write_index], ptr, length); /* this should not cause overflow because there is enough space for * length of data in current mirror */ rb->write_index += length; if (length > space_length) rb->read_index = rb->write_index; return length; } memcpy(&rb->buffer_ptr[rb->write_index], &ptr[0], rb->buffer_size - rb->write_index); memcpy(&rb->buffer_ptr[0], &ptr[rb->buffer_size - rb->write_index], length - (rb->buffer_size - rb->write_index)); /* we are going into the other side of the mirror */ rb->write_mirror = ~rb->write_mirror; rb->write_index = length - (rb->buffer_size - rb->write_index); /******************分析这里,似乎是有bug??? ****************/ if (length > space_length) { rb->read_mirror = ~rb->read_mirror; rb->read_index = rb->write_index; } return length; } RTM_EXPORT(rt_ringbuffer_put_force); ``` `rt_ringbuffer_put_force`函数,向buffer中put数据的策略为: 1)如果数据长度`length > buffer_size,`就将数据截断,只留后面的`buffer_size`长度的数据,从下面代码可以看出来: ```c if (length > rb->buffer_size) { ptr = &ptr[length - rb->buffer_size]; length = rb->buffer_size; } ``` 2)space_length为空闲区长度,如果`length > space_length`,就将buffer中老的数据覆盖掉。 的确,`rt_ringbuffer_put_force`是按照上面两条策略在put数据,但是代码到下面这几行,存在问题了: 这里是一条华丽的分界线 --- ```c if (length > space_length) { rb->read_mirror = ~rb->read_mirror; rb->read_index = rb->write_index; } ``` 这里是`length >= buffer_size - write_index`的情况,不然前面的代码直接return了。针对这种情况: 1. `write_index`一定会溢出(也就是会超过`buffer_size`),这个时候一定有`write_mirror = ~write_mirror`。(问题来了:`read_index`是否会溢出?这得分情况讨论,看下面2) 2. read_index 呢(`length > space_length, read_index`就一定会超过buffer_size???,我认为不一定 ),下面讨论: ### 情况2 `write_index < read_index`,这种情况下,空闲区域在缓冲区中间,有数据的区域在缓冲区两头,这种情况下,read_index和write_index都会溢出,因此有: ` read_mirror = ~read_mirror` ### 情况1 `read_index < write_index`,这种情况,有数据区域在缓冲区中间,缓冲区两头是空闲的,这个时候,write_index一定会溢出,但是read_index却不会溢出(因为前面限定了length最大不会超过buffer_size),这种情况下,read_mirror不变。 附一张截图,供大家理解我的意思: ![image.png](https://oss-club.rt-thread.org/uploads/20210716/3ae2ab545300acecb9932b79ce94d7a4.png.webp) 所以我认为应该这样改: ```c if (length > space_length && write_index ≤ read_index) { rb->read_mirror = ~rb->read_mirror; rb->read_index = rb->write_index; } ``` 大家认为呢?
123
2021-07-16
@RongLiu 先表一表楼主,可以的,很细心。? 首先这个不叫溢出,这个叫回环,环形buffer的回环属于正常操作。(而溢出是致命的错误,溢出有标准的解释和处理手段,不要乱起名字)。 然后是这个 `情况1`,分析的很有道理,`write_index` 回环的时候,`read_index` 不一定会触发回环,这个时候如果强行将 `read_mirror` 取反,则会导致 环形缓冲区的数据长度清空,而不是满。 最后是关于楼主修改的部分是有问题的,应该这样改 ```c if (length > space_length) { if(rb->write_index <= rb->read_index) /* 情况1 */ rb->read_mirror = ~rb->read_mirror; rb->read_index = rb->write_index; /* 情况2 */ } ``` 应该充分考虑当`length > space_length`时候的情况,也就是情况1和情况2,显然楼主分析完之后,代码没有考虑情况2. 另外提供一份测试代码,方便测试: ```c void test(void) { rt_uint8_t ring_buffer[64]; /* ringbuffer的缓冲区*/ rt_memset(ring_buffer, -1, 64); /* 先格式化为0xff */ struct rt_ringbuffer test_rb; rt_ringbuffer_init(&test_rb, ring_buffer, 64); rt_uint8_t write_buffer[40], read_buffer[40]; /* 读buffer缓冲区和写buffer缓冲区 */ rt_memset(write_buffer, 0, 40); rt_ringbuffer_put(&test_rb, write_buffer, 40); rt_ringbuffer_get(&test_rb, read_buffer, 5); rt_kprintf("rt_ringbuffer_data_len = [%d]\n", rt_ringbuffer_data_len(&test_rb)); rt_uint8_t write_second_buffer[34]; rt_memset(write_second_buffer, 1, 40); rt_ringbuffer_put_force(&test_rb, write_second_buffer, 34); rt_kprintf("rt_ringbuffer_data_len = [%d]\n", rt_ringbuffer_data_len(&test_rb)); } ```
2021-07-16
笔记好评!(草书看不懂,先夸再说 :-( ) ---
玩具箱
2021-07-16
不明白为什么会认为write_index一定会溢出?
flyboy
2021-07-23
Do my self();
厉害了,谁来把测试用例提交上来? https://github.com/RT-Thread/rt-thread/tree/master/examples/utest
zhang515140166
2022-04-27
```c if (length > space_length) { rb->read_mirror = ~rb->write_mirror; rb->read_index = rb->write_index; } ``` 这样改就可以了。
1.6k
arminker
大量接收数据 如何处理能减少丢包率
有没有一种实现类似 ringbuffer, 但返回数据长度 和传入时候一样
使用ringbuffer时,自检到thread的type不匹配
RINGBUFF里镜像索引取反是为什么?
系统提供环形FIFO写入重载时可能存在数据错乱问题
rt_ringbuffer_peak疑问
串口DMA接收回调函数不起作用
串口 DMA ringbuffer 接收有可能覆盖数据
rt_ringbuffer_init在buffer_size赋值是否有问题?
rtthread 中的ringbuff是线程安全的吗?
