SRAM
堆_heap_动态内存管理
绝对定位
stm32f407关于外部sram的使用问题,想把全局大数组放到外部sram
发布于 2021-07-20 17:02:30 浏览:1741
初始化外部sram这块是没问题的,free也可以出来sram内存部分 这个图是全局大数组已经定义到外部内存 ![image.png](https://oss-club.rt-thread.org/uploads/20210720/1cc6f461c533bcd626aaaa35d7700109.png) 我是用GCC 编译的但是还是会报错 链接脚本有问题 ![image.png](https://oss-club.rt-thread.org/uploads/20210720/60ef84738c9e47a32c3c41142108c3de.png.webp) 而链接脚本是如下: ```c /* * linker script for STM32F4xx with GNU ld * bernard.xiong 2009-10-14 * flybreak 2018-11-19 Add support for RAM2 */ /* Program Entry, set to mark it as "used" and avoid gc */ MEMORY { CODE (rx) : ORIGIN = 0x08000000, LENGTH = 1024k /* 1024KB flash */ RAM1 (rw) : ORIGIN = 0x20000000, LENGTH = 128k /* 128K sram */ RAM2 (rw) : ORIGIN = 0x10000000, LENGTH = 64k /* 64K sram */ } ENTRY(Reset_Handler) _system_stack_size = 0x200; SECTIONS { .text : { . = ALIGN(4); _stext = .; KEEP(*(.isr_vector)) /* Startup code */ . = ALIGN(4); *(.text) /* remaining code */ *(.text.*) /* remaining code */ *(.rodata) /* read-only data (constants) */ *(.rodata*) *(.glue_7) *(.glue_7t) *(.gnu.linkonce.t*) /* section information for finsh shell */ . = ALIGN(4); __fsymtab_start = .; KEEP(*(FSymTab)) __fsymtab_end = .; . = ALIGN(4); __vsymtab_start = .; KEEP(*(VSymTab)) __vsymtab_end = .; /* section information for initial. */ . = ALIGN(4); __rt_init_start = .; KEEP(*(SORT(.rti_fn*))) __rt_init_end = .; . = ALIGN(4); PROVIDE(__ctors_start__ = .); KEEP (*(SORT(.init_array.*))) KEEP (*(.init_array)) PROVIDE(__ctors_end__ = .); . = ALIGN(4); _etext = .; } > CODE = 0 /* .ARM.exidx is sorted, so has to go in its own output section. */ __exidx_start = .; .ARM.exidx : { *(.ARM.exidx* .gnu.linkonce.armexidx.*) /* This is used by the startup in order to initialize the .data secion */ _sidata = .; } > CODE __exidx_end = .; /* .data section which is used for initialized data */ .data : AT (_sidata) { . = ALIGN(4); /* This is used by the startup in order to initialize the .data secion */ _sdata = . ; *(.data) *(.data.*) *(.gnu.linkonce.d*) PROVIDE(__dtors_start__ = .); KEEP(*(SORT(.dtors.*))) KEEP(*(.dtors)) PROVIDE(__dtors_end__ = .); . = ALIGN(4); /* This is used by the startup in order to initialize the .data secion */ _edata = . ; } >RAM1 .stack : { . = ALIGN(4); _sstack = .; . = . + _system_stack_size; . = ALIGN(4); _estack = .; } >RAM1 __bss_start = .; .bss : { . = ALIGN(4); /* This is used by the startup in order to initialize the .bss secion */ _sbss = .; *(.bss) *(.bss.*) *(COMMON) . = ALIGN(4); /* This is used by the startup in order to initialize the .bss secion */ _ebss = . ; *(.bss.init) } > RAM1 __bss_end = .; _end = .; /* Stabs debugging sections. */ .stab 0 : { *(.stab) } .stabstr 0 : { *(.stabstr) } .stab.excl 0 : { *(.stab.excl) } .stab.exclstr 0 : { *(.stab.exclstr) } .stab.index 0 : { *(.stab.index) } .stab.indexstr 0 : { *(.stab.indexstr) } .comment 0 : { *(.comment) } /* DWARF debug sections. * Symbols in the DWARF debugging sections are relative to the beginning * of the section so we begin them at 0. */ /* DWARF 1 */ .debug 0 : { *(.debug) } .line 0 : { *(.line) } /* GNU DWARF 1 extensions */ .debug_srcinfo 0 : { *(.debug_srcinfo) } .debug_sfnames 0 : { *(.debug_sfnames) } /* DWARF 1.1 and DWARF 2 */ .debug_aranges 0 : { *(.debug_aranges) } .debug_pubnames 0 : { *(.debug_pubnames) } /* DWARF 2 */ .debug_info 0 : { *(.debug_info .gnu.linkonce.wi.*) } .debug_abbrev 0 : { *(.debug_abbrev) } .debug_line 0 : { *(.debug_line) } .debug_frame 0 : { *(.debug_frame) } .debug_str 0 : { *(.debug_str) } .debug_loc 0 : { *(.debug_loc) } .debug_macinfo 0 : { *(.debug_macinfo) } /* SGI/MIPS DWARF 2 extensions */ .debug_weaknames 0 : { *(.debug_weaknames) } .debug_funcnames 0 : { *(.debug_funcnames) } .debug_typenames 0 : { *(.debug_typenames) } .debug_varnames 0 : { *(.debug_varnames) } } ```
Jone
2021-07-20
写了还是懒
GCC与ARMCC的扩展内存时都要修改链接文件来增加section,前者在`sct分散加载文件`中增加section,而后者是在`lds链接脚本`中添加section。 第二点区别是两者修饰变量存放位置的修饰方法也不同。 --- 用gcc先添加Section再修饰变量,参考这篇文章吧[GCC连接脚本](https://club.rt-thread.org/ask/question/424879.html)
123
2021-07-20
[RTT Studio中怎么指定某个数组存放在设定的地址上](https://club.rt-thread.org/ask/question/425265.html) 这个试试可以不?
1.7k
xiaoyu
27
27
关于利用0x68000000作为扩展sram?
请问RTT stduio的sram外设需要怎么添加
tm32f407-atk-explorer这个BSP中,1M外置的SRAM
基于bsp工程,stm32f4xx_hal_sram.c如何正确编译。
RT-Thread的SRAM文件怎么启动
关于STM32的STM32_SRAM_SIZE问题
使用memheap外置sram出错
L431 RAM设置成SRAM1 启动失败
SRAM进行初始化,找不到这三个函数(已解决)
STM32L452 sram2的定向使用,求助
NXP MCXN947测评之 adc
