AB32VG1
AB32VG1开发板的三路LPWM使用
发布于 2021-07-25 10:19:06 浏览:832
AB32VG1开发板的三路LPWM不能同时输出吗?我在程序中用3路LPWM控制全彩灯,通过控制占空比实现全彩灯,灯的颜色变化不明显,结果发现只有1路LPWM输出,是不是不支持三路LPWM同时输出呀?
jzz
2021-07-25
我这边测试也这样 只有一路LPWM是能输出的 按板子上默认设置RGB灯的三路PWM:R是t5pwm G是lpwm0 B是lpwm1 然后我用同一个函数创建三个线程控制这三个灯的占空比变化 代码如下 ```c /* * Copyright (c) 2006-2021, RT-Thread Development Team * * SPDX-License-Identifier: Apache-2.0 * * Change Logs: * Date Author Notes * 2021-07-25 Administrator the first version */ #include "rtthread.h" #define PWM1_DEV_NAME "lpwm0" /* PWM 设备名称 */ struct rt_device_pwm *pwm1_dev; /* PWM 设备句柄 */ #define PWM2_DEV_NAME "lpwm1" /* PWM 设备名称 */ struct rt_device_pwm *pwm2_dev; /* PWM 设备句柄 */ #define PWM3_DEV_NAME "lpwm2" /* PWM 设备名称 */ struct rt_device_pwm *pwm3_dev; /* PWM 设备句柄 */ #define PWM4_DEV_NAME "t5pwm" /* PWM 设备名称 */ struct rt_device_pwm *pwm4_dev; /* PWM 设备句柄 */ #define PWM5_DEV_NAME "t3pwm" /* PWM 设备名称 */ struct rt_device_pwm *pwm5_dev; /* PWM 设备句柄 */ #define PWM6_DEV_NAME "t4pwm" /* PWM 设备名称 */ struct rt_device_pwm *pwm6_dev; /* PWM 设备句柄 */ typedef struct led_ctl { struct rt_device_pwm *dev; int ch; int min; int max; }led_ctl_t; led_ctl_t led_R,led_G,led_B; void led_init(void) { pwm1_dev = (struct rt_device_pwm *)rt_device_find(PWM1_DEV_NAME); if(pwm1_dev){ rt_pwm_set(pwm1_dev, 3, 100000, 100000); rt_pwm_enable(pwm1_dev, 3); } pwm2_dev = (struct rt_device_pwm *)rt_device_find(PWM2_DEV_NAME); if(pwm2_dev){ rt_pwm_set(pwm2_dev, 1, 100000, 100000); rt_pwm_enable(pwm2_dev, 1); } pwm3_dev = (struct rt_device_pwm *)rt_device_find(PWM3_DEV_NAME); if(pwm3_dev){ rt_pwm_set(pwm3_dev, 1, 100000, 100000); rt_pwm_enable(pwm3_dev, 1); } pwm4_dev = (struct rt_device_pwm *)rt_device_find(PWM4_DEV_NAME); if(pwm4_dev){ rt_pwm_set(pwm4_dev, 1, 100000, 100000); rt_pwm_enable(pwm4_dev, 1); } pwm5_dev = (struct rt_device_pwm *)rt_device_find(PWM5_DEV_NAME); if(pwm5_dev){ rt_pwm_set(pwm5_dev, 1, 100000, 100000); rt_pwm_enable(pwm5_dev, 1); } pwm6_dev = (struct rt_device_pwm *)rt_device_find(PWM6_DEV_NAME); if(pwm6_dev){ rt_pwm_set(pwm6_dev, 1, 100000, 100000); rt_pwm_enable(pwm6_dev, 1); } // 用同一个函数创建三个线程 分别传入RGB的LED的PWM设备句柄 extern void led_thread(void *p); rt_thread_t tid; led_R.dev = pwm4_dev; led_R.ch = 1; led_R.min = 777; led_R.max = 999; tid = rt_thread_create("led_R", led_thread, &led_R, 512, 26, 2);//PE1 if(tid){ rt_thread_startup(tid); } // 绿色LED无法控制??? led_G.dev = pwm5_dev; led_G.ch = 1; led_G.min = 1; led_G.max = 999; tid = rt_thread_create("led_G", led_thread, &led_G, 512, 26, 2);//PE4 if(tid){ rt_thread_startup(tid); } led_B.dev = pwm2_dev; led_B.ch = 1; led_B.min = 777; led_B.max = 999; tid = rt_thread_create("led_B", led_thread, &led_B, 512, 26, 2);//PA1 if(tid){ rt_thread_startup(tid); } } INIT_APP_EXPORT(led_init); void led_thread(void *p) { led_ctl_t *ctl = (led_ctl_t *)p; /* PWM 设备句柄 */ int var = ctl->max; int dir = 0; if(ctl->dev) while(1) { if(dir){ if(var < ctl->max) var++; else { dir = 0; } }else { if (var > ctl->min) { var--; }else { dir = 1; } } rt_pwm_set(ctl->dev, ctl->ch, 100000, 100*var%100000); rt_thread_mdelay(5); } } ``` 绿灯线程中传入正常的LPWM1的句柄之后绿灯的亮度就没什么变化,尝试传入t3pwm的句柄并且把绿灯接到PB0就能明显看到亮度变化
832
xzx
玩iot camera笔记之3测试试用3路pwm
[已解决]PWM输出异常分析
给RT-Thread添加PWM驱动框架
关于rt-thread-3.1.0 pwm
stm32f103ze 添加pwm 设备失败
