SD卡_TF卡
STM32H7
H7加入SDIO驱动后不能挂载sd卡,请帮忙看看
发布于 2021-08-02 17:55:25 浏览:1312
板子:银杏STM32H750 icore4T,使用STM32H7 Art-pi的sdio驱动,但是在挂载过程中,一直在sd.c这个文件的一些函数里卡着。 这是hal_msp的sdmmc配置: ``` void HAL_SD_MspInit(SD_HandleTypeDef* hsd) { GPIO_InitTypeDef GPIO_InitStruct = {0}; RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0}; if(hsd->Instance==SDMMC1) { /* USER CODE BEGIN SDMMC1_MspInit 0 */ /* USER CODE END SDMMC1_MspInit 0 */ /** Initializes the peripherals clock */ PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_SDMMC; PeriphClkInitStruct.SdmmcClockSelection = RCC_SDMMCCLKSOURCE_PLL; if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK) { // Error_Handler(); } /* Peripheral clock enable */ __HAL_RCC_SDMMC1_CLK_ENABLE(); __HAL_RCC_GPIOC_CLK_ENABLE(); __HAL_RCC_GPIOD_CLK_ENABLE(); /**SDMMC1 GPIO Configuration PC12 ------> SDMMC1_CK PC11 ------> SDMMC1_D3 PC10 ------> SDMMC1_D2 PD2 ------> SDMMC1_CMD PC9 ------> SDMMC1_D1 PC8 ------> SDMMC1_D0 */ GPIO_InitStruct.Pin = GPIO_PIN_12|GPIO_PIN_11|GPIO_PIN_10|GPIO_PIN_9 |GPIO_PIN_8; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF12_SDIO1; HAL_GPIO_Init(GPIOC, &GPIO_InitStruct); GPIO_InitStruct.Pin = GPIO_PIN_2; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF12_SDIO1; HAL_GPIO_Init(GPIOD, &GPIO_InitStruct); /* SDMMC1 interrupt Init */ HAL_NVIC_SetPriority(SDMMC1_IRQn, 0, 0); HAL_NVIC_EnableIRQ(SDMMC1_IRQn); /* USER CODE BEGIN SDMMC1_MspInit 1 */ /* USER CODE END SDMMC1_MspInit 1 */ } } ``` 这是System_clock的配置: ``` void SystemClock_Config(void) { RCC_OscInitTypeDef RCC_OscInitStruct = {0}; RCC_ClkInitTypeDef RCC_ClkInitStruct = {0}; RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0}; /** Supply configuration update enable */ HAL_PWREx_ConfigSupply(PWR_LDO_SUPPLY); /** Configure the main internal regulator output voltage */ __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE0); while(!__HAL_PWR_GET_FLAG(PWR_FLAG_VOSRDY)) {} /** Macro to configure the PLL clock source */ __HAL_RCC_PLL_PLLSOURCE_CONFIG(RCC_PLLSOURCE_HSE); /** Initializes the RCC Oscillators according to the specified parameters * in the RCC_OscInitTypeDef structure. */ RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI48|RCC_OSCILLATORTYPE_HSI |RCC_OSCILLATORTYPE_HSE; RCC_OscInitStruct.HSEState = RCC_HSE_ON; RCC_OscInitStruct.HSIState = RCC_HSI_DIV1; RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT; RCC_OscInitStruct.HSI48State = RCC_HSI48_ON; RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON; RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE; RCC_OscInitStruct.PLL.PLLM = 5; RCC_OscInitStruct.PLL.PLLN = 192; RCC_OscInitStruct.PLL.PLLP = 2; RCC_OscInitStruct.PLL.PLLQ = 2; RCC_OscInitStruct.PLL.PLLR = 2; RCC_OscInitStruct.PLL.PLLRGE = RCC_PLL1VCIRANGE_2; RCC_OscInitStruct.PLL.PLLVCOSEL = RCC_PLL1VCOWIDE; RCC_OscInitStruct.PLL.PLLFRACN = 0; if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK) { Error_Handler(); } /** Initializes the CPU, AHB and APB buses clocks */ RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2 |RCC_CLOCKTYPE_D3PCLK1|RCC_CLOCKTYPE_D1PCLK1; RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK; RCC_ClkInitStruct.SYSCLKDivider = RCC_SYSCLK_DIV1; RCC_ClkInitStruct.AHBCLKDivider = RCC_HCLK_DIV2; RCC_ClkInitStruct.APB3CLKDivider = RCC_APB3_DIV2; RCC_ClkInitStruct.APB1CLKDivider = RCC_APB1_DIV2; RCC_ClkInitStruct.APB2CLKDivider = RCC_APB2_DIV2; RCC_ClkInitStruct.APB4CLKDivider = RCC_APB4_DIV2; if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4) != HAL_OK) { Error_Handler(); } PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_LTDC|RCC_PERIPHCLK_USART2 |RCC_PERIPHCLK_RNG|RCC_PERIPHCLK_SPI5|RCC_PERIPHCLK_SDMMC |RCC_PERIPHCLK_ADC|RCC_PERIPHCLK_QSPI |RCC_PERIPHCLK_FMC|RCC_PERIPHCLK_CKPER; PeriphClkInitStruct.PLL2.PLL2M = 5; PeriphClkInitStruct.PLL2.PLL2N = 54; PeriphClkInitStruct.PLL2.PLL2P = 2; PeriphClkInitStruct.PLL2.PLL2Q = 2; PeriphClkInitStruct.PLL2.PLL2R = 2; PeriphClkInitStruct.PLL2.PLL2RGE = RCC_PLL2VCIRANGE_2; PeriphClkInitStruct.PLL2.PLL2VCOSEL = RCC_PLL2VCOWIDE; PeriphClkInitStruct.PLL2.PLL2FRACN = 0; PeriphClkInitStruct.PLL3.PLL3M = 5; PeriphClkInitStruct.PLL3.PLL3N = 192; PeriphClkInitStruct.PLL3.PLL3P = 2; PeriphClkInitStruct.PLL3.PLL3Q = 2; PeriphClkInitStruct.PLL3.PLL3R = 106; PeriphClkInitStruct.PLL3.PLL3RGE = RCC_PLL3VCIRANGE_2; PeriphClkInitStruct.PLL3.PLL3VCOSEL = RCC_PLL3VCOWIDE; PeriphClkInitStruct.PLL3.PLL3FRACN = 0; PeriphClkInitStruct.FmcClockSelection = RCC_FMCCLKSOURCE_D1HCLK; PeriphClkInitStruct.SdmmcClockSelection = RCC_SDMMCCLKSOURCE_PLL2; PeriphClkInitStruct.QspiClockSelection = RCC_QSPICLKSOURCE_D1HCLK; PeriphClkInitStruct.CkperClockSelection = RCC_CLKPSOURCE_HSI; PeriphClkInitStruct.Spi45ClockSelection = RCC_SPI45CLKSOURCE_PLL2; PeriphClkInitStruct.Usart234578ClockSelection = RCC_USART234578CLKSOURCE_D2PCLK1; PeriphClkInitStruct.RngClockSelection = RCC_RNGCLKSOURCE_HSI48; PeriphClkInitStruct.AdcClockSelection = RCC_ADCCLKSOURCE_CLKP; if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK) { Error_Handler(); } } ``` drv_sdio和sdio驱动文件均复制art-pi相同文件 现在挂载过程如下:能读出卡容量,但是之后就卡住了 ![image.png](https://oss-club.rt-thread.org/uploads/20210802/af39cbda919fae2debff63a20cab05b0.png.webp) 调试后发现是在这里出的问题 ![image.png](https://oss-club.rt-thread.org/uploads/20210802/4619aa705b65db89d0ea0be6ad71f7a1.png.webp) 然后进入mmcsd_send_app_cmd函数,在这里出问题 ![image.png](https://oss-club.rt-thread.org/uploads/20210802/4197a84c030f67b3d5cf63a1b7da0af8.png) 然后就send command循环套,返回err 实在不知道哪里出了问题,时钟配置是直接复制的,不知道有没有配置对,希望有大佬指点一下
zhognrui
2021-08-02
如果我把mmcsd_app_set_bus_width这个的进入err注释掉,就提示这个错误信息: ![image.png](https://oss-club.rt-thread.org/uploads/20210802/5b5700dbe1ab5cd3f15f9d42c861cae3.png)
红枫
2021-08-02
把NOPULL改成PULLUP试试
adaphoto
2021-08-03
RT-Thread-关于STM32H7开发板上使用SDIO接口驱动SD卡挂载文件系统的问题总结RT-Thread问答社区 - RT-Thread https://club.rt-thread.org/ask/article/2404.html 建议查看一下ram区的定位,0x24000000
adg7660
2022-03-08
你好,问题解决了吗?我也碰到了一样的问题
1.3k
zhognrui
代码分享,stm32f407的sdio驱动。
求个在STM32F103 RTT上使用SDIO接口的例子
是否能增加一个 SDIO AP61xx 的驱动呢
sdio和fsmc驱动lcd冲突
关于rt-thread系统sdio驱动框架使用
sdio驱动是怎么使用的?也没有文档和例程啊
MCXN947测评系列(二)串口设备测评
测试DFS+elm的删除命令rm,有点搞笑的经历
vision board 开箱
猪的行独
