外部中断
workqueue_工作队列
rt-thread work queue 延时较大
发布于 2021-08-05 21:04:19 浏览:837
[tocm] ## 问题描述 rt-thread workqueue 从中断触发到执行有2~3ms 延时,不知是哪里问题? ## 问题细节: s0: 工作队列优先级: 已经试最高 ```c thread pri status sp stack size max used left tick error -------- --- ------- ---------- ---------- ------ ---------- --- thd_spi3 5 suspend 0x00000090 0x00000800 24% 0x00000001 000 thd_spi2 5 suspend 0x00000090 0x00000800 25% 0x00000001 000 thd_spi1 5 suspend 0x00000090 0x00000800 24% 0x00000001 000 thd_spi0 5 suspend 0x00000090 0x00000800 34% 0x00000001 000 spi_wq 1 suspend 0x00000148 0x00001000 09% 0x00000007 000 // 工作队列优先级 最高是中断 thd_card 5 suspend 0x000000e8 0x00000400 36% 0x00000001 000 thd_jsd 5 suspend 0x000000a0 0x00000400 38% 0x00000001 000 thd_xsd 5 suspend 0x000000a0 0x00000400 40% 0x00000001 000 thd_bee 4 suspend 0x000000a4 0x00000400 16% 0x00000001 000 thd_lcd 5 suspend 0x000000cc 0x00000400 32% 0x00000001 000 tshell 20 ready 0x00000220 0x00000c18 17% 0x00000002 000 tidle 31 ready 0x00000048 0x00000100 40% 0x00000007 000 main 10 suspend 0x0000010c 0x00000800 30% 0x00000013 000 ``` 日志测试时间: ```c void drv_spi_irq_rx_work(struct rt_work *work, void *work_data) { uint8_t sbuf_size = 0; struct spi_work_data *spi_data = NULL; spi_data = (struct spi_work_data *)work_data; LOG_D("rx s0"); /* s0:提取数据 */ sbuf_size = app_data_queue_size(SPI0_S + spi_data->port * 2); if (sbuf_size > 0) { LOG_D("rx s1"); uint8_t *s_pac = app_data_queue_pop(SPI0_S + spi_data->port * 2); /* s1: 发送数据: 此处存在 dma_sem 管理发送完成才会退出函数 */ app_spi_transfer(spi_data->port, &(port_ant[spi_data->port].ant_spi), s_pac, port_ant[spi_data->port].rpac, ANT_SPI_LEN); /* s2: 回收数据 */ app_data_queue_push(IDLE_E, s_pac); /* s3: 数据发送完成继续扫描数据 */ if (app_data_queue_size(SPI0_S + spi_data->port * 2) == 0) { rt_sem_release(&(port_ant[spi_data->port].scan_lock)); } LOG_D("rx s2"); } else { LOG_D("tx rx"); app_spi_transfer(spi_data->port, &(port_ant[spi_data->port].ant_spi), port_ant[spi_data->port].spac, port_ant[spi_data->port].rpac, ANT_SPI_LEN); } /* 解析数据 */ // app_dtq_rcmd_decode(&port_ant[spi_data->port], \ (spi_pac_t *)(port_ant[spi_data->port].rpac)); } ``` ``` [534518]: isr rx 接收中断时间 [534521]: rx s0 工作队列函数开始时间 [534521]: rx s1 [534522]: rx s2 ``` 实际测量测试时隙: **SPI_FIFO 是从机控制的管脚,主机配置为上升沿中断,有数据上报拉高,数据读走后拉低** ![6CDECDBF-A2C6-4c53-9D69-9889D26D1EE7.png](https://oss-club.rt-thread.org/uploads/20210805/9ba41942af917a22f7dfd691455cde46.png.webp)
2021-08-06
这个workqueue队列里面是否还有其它任务? workqueue是一个一个任务往下执行的,所以不适合实时任务,只适合一些如OTA检查等任务。 你可以用一个独立的新高优先级来测试,并把优先级调到最高。
mysterywolf
2021-08-06
workqueue 的性质就是这样的,你不可以把实时性有要求的任务放在workqueue中
837
懒洋洋
BBB的SPI驱动
求个SPI上挂两个或多个设备的使用例子
SPI设备有个bug
SPI驱动
请教rt_spi_configure函数理解
SPI FLASH挂载的问题
SPI-FLASH 文件系统 SPIFFS
求助一个完整的 spi flash 驱动
关于同时使用文件系统与SPI FLASH的问题
