CmBacktrace
stm32F103通过SPI发送数据失败
发布于 2021-08-06 10:24:17 浏览:1018
```c #define SPI_BUS_NAME "spi2" /* SPI总线名称 */ #define SPI_W25Q64_DEVICE_NAME "spi20" /* SPI设备名称 */ rt_uint8_t w25x_read_id = 0x90; static struct rt_spi_device spi_dev_w25q64; struct stm32_hw_spi_cs { rt_uint32_t pin; }; static struct stm32_hw_spi_cs spi_cs; /*收发数据*/ rt_err_t w25q64_write_cmd(const rt_uint8_t cmd) { rt_uint8_t id[5] = {0}; rt_spi_send_then_recv(&spi_dev_w25q64, &cmd, 1, id, 5); rt_kprintf("use rt_spi_send_then_recv() read w25q ID is:%x%x\n", id[3], id[4]); } /*注册spi设备*/ static int rt_hw_w25q64_config(void) { rt_err_t res; spi_cs.pin = 28; rt_pin_mode(spi_cs.pin, PIN_MODE_OUTPUT); /* 设置片选管脚模式为输出 */ res = rt_spi_bus_attach_device(&spi_dev_w25q64, SPI_W25Q64_DEVICE_NAME, SPI_BUS_NAME,(void*)&spi_cs); if (res != RT_EOK) { rt_kprintf("rt_spi_bus_attach_device!\r\n"); return res; } /* config spi */ { struct rt_spi_configuration cfg; cfg.data_width = 8; cfg.mode = RT_SPI_MASTER | RT_SPI_MODE_2 | RT_SPI_MSB; cfg.max_hz = 20 * 1000 *1000; rt_spi_configure(&spi_dev_w25q64, &cfg); } return RT_EOK; } void test() { rt_hw_w25q64_config(); w25q64_write_cmd(w25x_read_id); } int main(void) { LOG_D("Hello RT-Thread!"); test(); return RT_EOK; } ``` 运行到`rt_spi_send_then_recv(&spi_dev_w25q64, &cmd, 1, id, 5);`出错。 串口返回: ``` psr: 0x01000000 r00: 0x0000001c r01: 0x00000000 r02: 0x00000000 r03: 0x0000001c r04: 0xdeadbeef r05: 0xdeadbeef r06: 0xdeadbeef r07: 0x20001da4 r08: 0xdeadbeef r09: 0xdeadbeef r10: 0xdeadbeef r11: 0xdeadbeef r12: 0x00000000 lr: 0x0800ae05 pc: 0x08008140 hard fault on thread: main thread pri status sp stack size max used left tick error -------- --- ------- ---------- ---------- ------ ---------- --- tshell 20 ready 0x00000044 0x00001000 01% 0x0000000a 000 tidle0 31 ready 0x00000040 0x00000100 25% 0x00000020 000 timer 4 suspend 0x0000007c 0x00000200 24% 0x00000009 000 main 10 running 0x00000040 0x00000800 14% 0x00000010 000 bus fault: SCB_CFSR_BFSR:0x04 IMPRECISERR ```
小兵666
2021-08-06
打开片选管脚的时钟没有?
赵云无双
2021-08-06
怎么打开管脚的时钟?没找到相关的说明。看了好多代码都没提这事。
游走在01的海洋
2021-08-06
一、看看这篇文章“rt-thread基于stm32标准库的SPI驱动”https://club.rt-thread.org/ask/article/46.html 二、另外提供一个检查办法:使用示波器分别查看片选、时钟、输出、输入的波形,可以查看SPI是否正常运行;
cxhxy12345
2021-08-06
你这个无法替你分析,到底是硬件问题还是配置问题、软件问题,很难分析。 https://www.cnblogs.com/silencehuan/p/10950973.html 可以看下这个,上面有详细的SPI驱动写法,也许对你有帮助
1k
赵云无双
新手请教关于hardfault怎么查
STM32F1+RTT串口接收中断进入hardfault
STM32F746NG随机进入hardfault(已解决)
