USART
缓冲区
usart的缓冲区有什么用?
发布于 2021-08-18 10:08:09 浏览:1120
[tocm] 配置串口的时候,缓冲区的作用? ```c pconfig.baud_rate = BAUD_RATE_115200; pconfig.data_bits = DATA_BITS_8; pconfig.stop_bits = STOP_BITS_1; pconfig.parity = PARITY_NONE; pconfig.bit_order = BIT_ORDER_LSB; pconfig.invert = NRZ_NORMAL; pconfig.bufsz = 256; pconfig.reserved = 0; ``` NRZ_NORMAL是什么意思? 缓冲区是256个字节,串口为中断接收,看了一下源码,应该是在串口接收中断里调用2个函数,在 rt_hw_serial_isr 函数里把接收到的数据放到局部变量fifo里,然后调用接收完成回调函数。 ## 问题一 中断应该是短小精悍,接收中断的中断服务函数放这么多代码,合理吗? ## 问题二 初始化的时候256个字节的缓冲区,和这个局部变量fifo怎么联系起来? 这个是局部变量,中断服务函数结束就消失了,没办法把接收到的数据传到这个256字节缓冲区里啊 ```c case RT_SERIAL_EVENT_RX_IND: { int ch = -1; rt_base_t level; struct rt_serial_rx_fifo* rx_fifo; /* interrupt mode receive */ rx_fifo = (struct rt_serial_rx_fifo*)serial->serial_rx; RT_ASSERT(rx_fifo != RT_NULL); while (1) { ch = serial->ops->getc(serial); if (ch == -1) break; /* disable interrupt */ level = rt_hw_interrupt_disable(); rx_fifo->buffer[rx_fifo->put_index] = ch; rx_fifo->put_index += 1; if (rx_fifo->put_index >= serial->config.bufsz) rx_fifo->put_index = 0; /* if the next position is read index, discard this 'read char' */ if (rx_fifo->put_index == rx_fifo->get_index) { rx_fifo->get_index += 1; rx_fifo->is_full = RT_TRUE; if (rx_fifo->get_index >= serial->config.bufsz) rx_fifo->get_index = 0; } /* enable interrupt */ rt_hw_interrupt_enable(level); } /* invoke callback */ if (serial->parent.rx_indicate != RT_NULL) { rt_size_t rx_length; /* get rx length */ level = rt_hw_interrupt_disable(); rx_length = (rx_fifo->put_index >= rx_fifo->get_index)? (rx_fifo->put_index - rx_fifo->get_index): (serial->config.bufsz - (rx_fifo->get_index - rx_fifo->put_index)); rt_hw_interrupt_enable(level); if (rx_length) { serial->parent.rx_indicate(&serial->parent, rx_length); } } break; ``` 还有串口接收函数 ```c rt_size_t rt_device_read(rt_device_t dev, rt_off_t pos, void* buffer, rt_size_t size); ``` ## 问题三 在接收的时候,数据会保存在这个buffer缓冲区里,可是这个缓冲区和前面的256个字节联系不上,和中断服务函数里的fifo也联系不上,它是怎么接收数据的呢? ## 问题四 如果是一次发送4个字节,可以利用rt_device_read一次接收四个吗?这4个字节的流动是怎样的? 文档里只介绍了函数,和使用,但是没介绍原理,谢谢大家
2021-08-18
疑问挺多哈,一个个说, ## 问题一 中断处理复杂,是不合理的,无论是裸机还是在系统里,中断处理尽最大化简化。 ## 问题二 这里的局部指针变量,下一句就初始化了,其实fifo是在初始化的设备对象管理的。 ```c struct rt_serial_rx_fifo* rx_fifo; /* interrupt mode receive */ rx_fifo = (struct rt_serial_rx_fifo*)serial->serial_rx; ``` ## 问题三 `rt_device_read`是从前边的 fifo 里面取出数据,放到这个新的 buffer 指针指向的缓冲区的。也就是说,驱动层有缓存,应用层也要有自己的数据存放内存区域。 问题四,串口是数据流设备,不保证一次接收多少个字节,但是通过多次调用 rt_device_read 是可以获取多个字节的,至于这四个字节顺序,要看发送方是高字节先发还是低字节先发。 昨天一个问题,我贴的一段代码,怎么处理一个完整串口数据包的。应该对你有帮助。 https://club.rt-thread.org/ask/question/432479.html
cxhxy12345
2021-08-18
你这些问题最根本的是对信号和指针的理解还有问题,其实很简单,中断只是简单的将接受数据放入FIFO中,这个FIFO具体大小自己决定。 RTT在中断接受一个字节后会将信号计数值++,串口接受线程在有信号后就会调用,调用时将获取FIFO的读指针去读取数据。 用户将缓冲的数据读出后可以放入到自己的处理缓冲中等待处理,如果通讯协议时固定字节,也可以通过FIFO的读写指针差判断是不是有完整命令接受,如果有则读取,没有则等待。 而每个串口对象在初始化时需要分配一个缓冲区作为FIFO,pcong.busfz只是你需要的缓冲区最大值定义。
1.1k
伊森亨特
74
串口DMA发送数据时,数据被覆盖
关于串口DMA模式下rt_device_close问题
finsh 控制台 适配 RS 485请大神指点????
串口无法接受数据,但可以发送
串口如何有效的清除掉接收缓冲,而不必一个一个的去读取
串口接收使用方式问题
雅特力FINSH问题
