SAL
udp
双网口_多网口
多网卡情况下如何判断是哪个网卡接收到的数据包
发布于 2021-08-25 16:48:01 浏览:1485
在多网卡情况下,不同网卡有不同的地址。 在socket中使用udp协议监听了一个端口,监听的地址为0.0.0.0表示任意网卡都可以接收到数据。现在的问题是,接收数据包我可以用(recvfrom)获取到发送方的ip地址和端口。但是我不知道是从哪个网卡接收到的。 查询了linux头文件 ```c #include
ssize_t recvmsg(int socket, struct msghdr *message, int flags); ``` 可以拿到本地接收端地址,但是这个函数在rtt中好像没有实现 连lwip中也只有 ```c int lwip_sendmsg(int s, const struct msghdr *message, int flags); ``` **没有找到recvmsg函数** 代码如下 ```c void task_udp(void *p) { int err = 0; int sockfd = 0; struct sockaddr_in bindAddr = {0}; struct sockaddr_in destAddr = {0}; struct sockaddr_in sourceAddr = {0}; int udp_tick = 0; int len = 0; char addr_str[128]; struct timeval tv; char * rx_buffer = malloc(UDP_BUF_SIZE); char * tx_buffer = malloc(UDP_BUF_SIZE); while(1) { sockfd = socket(AF_INET,SOCK_DGRAM,IPPROTO_IP); LOG_D("socket created :%d",sockfd); bindAddr.sin_family = AF_INET; bindAddr.sin_port = htons(UDP_BIND_PORT); bindAddr.sin_addr.s_addr = htonl(IPADDR_ANY); err = bind(sockfd, (struct sockaddr *)&bindAddr, sizeof(bindAddr)); if (err < 0) { LOG_D( "Failed to bind socket. Error %d", errno); } LOG_D( "socket bind :%d",ntohs(bindAddr.sin_port)); destAddr.sin_family = AF_INET; destAddr.sin_port = htons(UDP_SEND_PORT); // destAddr.sin_addr.s_addr = inet_addr(MULTICAST_IPV4_ADDR); destAddr.sin_addr.s_addr = inet_addr("255.255.255.255"); //htonl(IPADDR_BROADCAST); int mode = 0; ioctlsocket(sockfd, FIONBIO, &mode); /* Set recv timeout of this fd as per config */ tv.tv_sec = 10; tv.tv_usec = 0; setsockopt(sockfd, SOL_SOCKET, SO_RCVTIMEO, (const char*)&tv, sizeof(tv)); /* Set send timeout of this fd as per config */ tv.tv_sec = 3; tv.tv_usec = 0; setsockopt(sockfd, SOL_SOCKET, SO_SNDTIMEO, (const char*)&tv, sizeof(tv)); const int opt = 1; setsockopt(sockfd, SOL_SOCKET, SO_BROADCAST, (char *)&opt, sizeof(opt)); // this is also a listening socket, so add it to the multicast // group for listening... // socket_add_ipv4_multicast_group(sockfd, true); socklen_t socklen = sizeof(sourceAddr); while(1) { //len = recv(sockfd, rx_buffer, 1024-1, 0); len = recvfrom(sockfd, rx_buffer, UDP_BUF_SIZE-1, 0,(struct sockaddr *)&sourceAddr,&socklen); // Error occured during receiving if (len > 0) { inet_ntoa_r(((struct sockaddr_in *)&sourceAddr)->sin_addr.s_addr, addr_str, sizeof(addr_str) - 1); rx_buffer[len] = 0; LOG_D( "recvfrom from %s : %d , %d bytes", addr_str,ntohs(sourceAddr.sin_port) , len); LOG_D( "%s", rx_buffer); len = udpfind_json_process(rx_buffer,UDP_BUF_SIZE,board_ip_str_get(),board_mac_str_get() , board_unique_id_str() ); LOG_D( "send %d bytes", len); int err = sendto(sockfd,rx_buffer, len, 0,(struct sockaddr *)&destAddr,sizeof(destAddr)); if (err < 0) { LOG_D( "Error occured during sending: errno %d", errno); break; } }else { if(!(errno == EINTR || errno == EWOULDBLOCK || errno == EAGAIN)) { // LOG_E("net recv err :%d",rc); LOG_D( "recvfrom failed: errno %d", errno); break; } } //vTaskDelay(100 / portTICK_RATE_MS); } if (sockfd != -1) { LOG_D( "Shutting down socket and restarting..."); shutdown(sockfd, 0); closesocket(sockfd); } } free(rx_buffer); free(tx_buffer); } ```
2021-08-25
每个网卡创建一个socket,然后绑定到网卡吧! 然后用select来监听所有网卡,这样从哪个网口来的就清楚了。
文武斌
2021-08-25
在LWIP 2.1.2版本的源码下 `rt-thread/components/net/lwip-2.1.2/src/api/sockets.c` 找到了函数 ```c ssize_t lwip_recvmsg(int s, struct msghdr *message, int flags) ``` 不知道是否可以直接跳过SAL调用这个函数
1.5k
文武斌
27
74
SAL 不支持 PF_PACKET,如何修改可以支持?
SAL组件好像并不支持DTLS
添加SAL组件后socket相关函数均提示declared implicitly
sal组件socket等函数无法使用
SAL关闭自带的一个socket连接
wiznet与libmodbus软件包衔接对接SAL层传参问题
sal验证link.rt-thread.org:8101失败
请问 AT-SAL,recv() 函数在服务端断开之后没有返回,是设计如此吗?
多网卡的出现创建socket失败
