HAL库正常驱动的UART,使用rt-thread无法正常驱动
发布于 2021-08-29 11:38:10 浏览:1056
事情经过是这样:我使用RT-Thread UART V2版本开驱动串口进行开发,在串口1(用于调试,无负载)、串口2(DMA收发,用于外部485通信)、串口3(DMA,与板载sim800c通信)。 在使用过程中串口1、2均能正常读写,但是串口3在使用中却无法正常驱动,主要表现为:执行类似代码:`rt_device_write(uart3, 0, "OK\r\n", 4)`成功,但是却并无数据输出。 进行跟踪调试,底层HAL库也成功执行(此时无输出)。 配置如下: ![image.png](https://oss-club.rt-thread.org/uploads/20210829/9ce81e459a5a6ab531ac350e7e80cb27.png) ![image.png](https://oss-club.rt-thread.org/uploads/20210829/3565a867fdfa5d775145e4144efdd990.png) ![image.png](https://oss-club.rt-thread.org/uploads/20210829/7e0eb7f0c19cc0b57b7557d26401d32b.png) 代码如下: ```c int main(void) { MX_USART3_UART_Init(); sim800c_restart(); /* 查找串口设备 */ rt_device_t uart3 = rt_device_find(UART_Sim800C); rt_device_open(uart3, RT_DEVICE_FLAG_RX_NON_BLOCKING | RT_DEVICE_FLAG_TX_BLOCKING); char *str = "OK\r\n"; while (1) { rt_device_write(uart3,0,str,4); rt_thread_mdelay(1000); } return RT_EOK; } ``` 有通过cubeMx重建单独测试项目,测试串口3的DMA功能,完好收发。配置如下图 ![image.png](https://oss-club.rt-thread.org/uploads/20210829/671c7d9f1e4b69f5b6d26506f85883ab.png.webp) ![image.png](https://oss-club.rt-thread.org/uploads/20210829/1ce175ac55e3f00a039e8b6bbbad44cb.png.webp) 代码如下: ```c /* USER CODE END 0 */ UART_HandleTypeDef huart3; DMA_HandleTypeDef hdma_usart3_rx; DMA_HandleTypeDef hdma_usart3_tx; /* USART3 init function */ void MX_USART3_UART_Init(void) { huart3.Instance = USART3; huart3.Init.BaudRate = 115200; huart3.Init.WordLength = UART_WORDLENGTH_8B; huart3.Init.StopBits = UART_STOPBITS_1; huart3.Init.Parity = UART_PARITY_NONE; huart3.Init.Mode = UART_MODE_TX_RX; huart3.Init.HwFlowCtl = UART_HWCONTROL_NONE; huart3.Init.OverSampling = UART_OVERSAMPLING_16; if (HAL_UART_Init(&huart3) != HAL_OK) { Error_Handler(); } } void HAL_UART_MspInit(UART_HandleTypeDef* uartHandle) { GPIO_InitTypeDef GPIO_InitStruct = {0}; if(uartHandle->Instance==USART3) { /* USER CODE BEGIN USART3_MspInit 0 */ /* USER CODE END USART3_MspInit 0 */ /* USART3 clock enable */ __HAL_RCC_USART3_CLK_ENABLE(); __HAL_RCC_GPIOB_CLK_ENABLE(); /**USART3 GPIO Configuration PB10 ------> USART3_TX PB11 ------> USART3_RX */ GPIO_InitStruct.Pin = GPIO_PIN_10; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH; HAL_GPIO_Init(GPIOB, &GPIO_InitStruct); GPIO_InitStruct.Pin = GPIO_PIN_11; GPIO_InitStruct.Mode = GPIO_MODE_INPUT; GPIO_InitStruct.Pull = GPIO_NOPULL; HAL_GPIO_Init(GPIOB, &GPIO_InitStruct); /* USART3 DMA Init */ /* USART3_RX Init */ hdma_usart3_rx.Instance = DMA1_Channel3; hdma_usart3_rx.Init.Direction = DMA_PERIPH_TO_MEMORY; hdma_usart3_rx.Init.PeriphInc = DMA_PINC_DISABLE; hdma_usart3_rx.Init.MemInc = DMA_MINC_ENABLE; hdma_usart3_rx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE; hdma_usart3_rx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE; hdma_usart3_rx.Init.Mode = DMA_NORMAL; hdma_usart3_rx.Init.Priority = DMA_PRIORITY_LOW; if (HAL_DMA_Init(&hdma_usart3_rx) != HAL_OK) { Error_Handler(); } __HAL_LINKDMA(uartHandle,hdmarx,hdma_usart3_rx); /* USART3_TX Init */ hdma_usart3_tx.Instance = DMA1_Channel2; hdma_usart3_tx.Init.Direction = DMA_MEMORY_TO_PERIPH; hdma_usart3_tx.Init.PeriphInc = DMA_PINC_DISABLE; hdma_usart3_tx.Init.MemInc = DMA_MINC_ENABLE; hdma_usart3_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE; hdma_usart3_tx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE; hdma_usart3_tx.Init.Mode = DMA_NORMAL; hdma_usart3_tx.Init.Priority = DMA_PRIORITY_LOW; if (HAL_DMA_Init(&hdma_usart3_tx) != HAL_OK) { Error_Handler(); } __HAL_LINKDMA(uartHandle,hdmatx,hdma_usart3_tx); /* USART3 interrupt Init */ HAL_NVIC_SetPriority(USART3_IRQn, 0, 0); HAL_NVIC_EnableIRQ(USART3_IRQn); /* USER CODE BEGIN USART3_MspInit 1 */ /* USER CODE END USART3_MspInit 1 */ } } ``` ``` /* USER CODE BEGIN 0 */ extern UART_HandleTypeDef huart3; /* USER CODE END 0 */ /** * @brief The application entry point. * @retval int */ int main(void) { /* USER CODE BEGIN 1 */ /* USER CODE END 1 */ /* MCU Configuration--------------------------------------------------------*/ /* Reset of all peripherals, Initializes the Flash interface and the Systick. */ HAL_Init(); /* USER CODE BEGIN Init */ /* USER CODE END Init */ /* Configure the system clock */ SystemClock_Config(); /* USER CODE BEGIN SysInit */ /* USER CODE END SysInit */ /* Initialize all configured peripherals */ MX_GPIO_Init(); MX_DMA_Init(); MX_USART3_UART_Init(); /* USER CODE BEGIN 2 */ /* USER CODE END 2 */ /* Infinite loop */ /* USER CODE BEGIN WHILE */ while (1) { /* USER CODE END WHILE */ /* USER CODE BEGIN 3 */ HAL_UART_Transmit_DMA(&huart3, "OK\r\n", 4); HAL_Delay(2000); } /* USER CODE END 3 */ } ```
2021-08-29
有过把3搞成调试串口吗,能不能单独开串口3? 有使用示波器看串口线信号吗?
itdreamworks
2021-08-29
求一硬件开发工程师合作
上图是串口3不是串口1,串口3测试只有噪声
游走在01的海洋
2021-08-29
一、看了你们讨论的,并且裸机跑串口3正常,那就是应用逻辑的冲突导致了串口3的输出问题; 1.梳理所有应用,查看是否有的应用与串口3引脚冲突; 2.至于其他的暂时没想到;
Code_Monkey
2021-11-08
楼主后来解决问题了吗?可否分享一下解决办法
1.1k
itdreamworks
求一硬件开发工程师合作
rt thread 2.0.2 usart 接收缓存问题
关于STM32串口通信的问题
STM32F1+RTT串口接收终端数据丢失问题
UART TX丢数据?
RTT打开串口的时候如何自定义波特率呢?
STM32F4的USART数据接收问题
串口1234使用问题
串口接收回调函数
LPC18xx UART问题讨论
x1000串口配置的失败问题
恩智浦mcxn947的RT-Thread的PIN驱动测评
FRDM-MCXN947在windows下使用GDB
单片机单片魂
