ADC设备
温度采集
rtthread studio adc三通道采集ntc电阻出现问题
发布于 2021-09-04 13:36:22 浏览:1306
是这样配置的 三个通道采集三个ntc热敏电阻的值 比单个通道采集一个热敏电阻时 温度要低1度左右 ```c #include "temp_adc.h" #define ADC_DEV_NAME "adc1" /* ADC 设备名称 */ #define ADC_DEV_CHANNEL_PA3 3 /* ADC 通道 */ #define ADC_DEV_CHANNEL_PA4 4 /* ADC 通道 */ #define ADC_DEV_CHANNEL_PA5 5 /* ADC 通道 */ #define REFER_VOLTAGE 330 /* 参考电压 3.3V,数据精度乘以100保留2位小数*/ #define CONVERT_BITS (1 << 12) /* 转换位数为12位 */ rt_adc_device_t adc_dev; /**中位值平均滤波法 * (1)原理:采一组队列去掉最大值和最小值 * (2)特点:优点:融合了两种滤波的优点。对于偶然出现的脉冲性干扰,可消除有其引起的采样值偏差,对周期干扰有良好的抑制作用,平滑度高,适于高频振荡的系统; 缺点:测量速度慢; * */ #define N 8 static rt_uint32_t filter(rt_uint32_t ADC_DEV_CHANNEL) { rt_uint8_t i = 0, j = 0; rt_uint32_t value_buf[N]; rt_uint32_t temp = 0,sum = 0; for(i = 0; i < N; i++){ value_buf[i] = rt_adc_read(adc_dev, ADC_DEV_CHANNEL); rt_thread_delay(5); } for(j = 0; j < N - 1; j++) { for(i = 0; i < N - j; i++) { if(value_buf[i] > value_buf[i + 1]) { temp = value_buf[i]; value_buf[i] = value_buf[i + 1]; value_buf[i + 1] = temp; } } } for(i = 1; i < N - 1; i++) { sum += value_buf[i]; } return (rt_uint32_t)(sum / (N - 2)); } /***********************************end***********************************/ //电压换算成温度 static float temp_data(rt_uint32_t ADC_DEV_CHANNEL) { float Rt=0; float Rp=10; float T2=273.15+25; float Bx=3435; float Ka=273.15; rt_uint32_t value=0; float temp=0,vol; /* 读取采样值 */ value = filter(ADC_DEV_CHANNEL); // rt_kprintf("ADC:%d \n", value); /* 转换为对应电压值 */ vol = (float)value * REFER_VOLTAGE / CONVERT_BITS; // rt_kprintf("the voltage is :%d.%02dV \n", (int)vol / 100, (int)vol % 100); Rt = vol * 10 / (REFER_VOLTAGE-vol);//求出当前温度阻值 (BaseVoltage-RV)/R16=RV/RT; // rt_kprintf("Rt :%d \n", (int)(Rt * 10000)); temp = 1 / (1 / T2 + (log(Rt / Rp) / Bx)) - Ka;//%RT = RN exp*B(1/T-1/TN)% // rt_kprintf("temp :%d.%02dC \n", (int)(temp * 100) / 100,(int)(temp * 100) % 100); return temp; } static float adc_vol(rt_uint32_t ADC_DEV_CHANNEL,float *temp) { rt_err_t ret = RT_EOK; /* 查找设备 */ adc_dev = (rt_adc_device_t)rt_device_find(ADC_DEV_NAME); if (adc_dev == RT_NULL) { rt_kprintf("adc sample run failed! can't find %s device!\n", ADC_DEV_NAME); return RT_ERROR; } /* 使能设备 */ ret = rt_adc_enable(adc_dev, ADC_DEV_CHANNEL); *temp = temp_data(ADC_DEV_CHANNEL); /* 关闭通道 */ ret = rt_adc_disable(adc_dev, ADC_DEV_CHANNEL); return ret; } ``` ```c static void temp_get_entry(void *parameter) { while(1) { float temp3=0,temp4=0,temp5=0,temp=0; adc_vol(ADC_DEV_CHANNEL_PA3,&temp3); rt_thread_delay(10); adc_vol(ADC_DEV_CHANNEL_PA4,&temp4); rt_thread_delay(10); adc_vol(ADC_DEV_CHANNEL_PA5,&temp5); rt_thread_delay(10); temp = (temp3 + temp4 + temp5)/3; rt_kprintf("temp :%dC %dC %dC temp:%dC\n", (int)(temp3 * 100),(int)(temp4 * 100),(int)(temp5 * 100),(int)(temp * 100)); } } rt_thread_t temp_get_adc=RT_NULL; int temp_get_adc_init(void) { //创建显示线程 优先级设置为31 temp_get_adc = rt_thread_create("temp_get_adc", temp_get_entry, RT_NULL, 2048, 8, 20); //启动显示线程 if(RT_NULL != temp_get_adc) { rt_thread_startup(temp_get_adc); // rt_kprintf("display_ok\n"); } return 0; } ```
fubaojun2006
2021-12-02
哇(挖)~~坑~~~啊!
看你的程序,一次打开 读取8次,然后做了排序,后取 中位值平均滤波法 已经很完美了。 我觉得可以试试把 NTC 通道 安排在几个不同的PORT 的IO口上, 比如A口一个NTC , C口 一个NTC ,排除这种外部硬件引起的串扰问题。 或者是在`filter`函数做一下调整,先读取两次丢弃,然后先延时,然后再读取。 ```c static rt_uint32_t filter(rt_uint32_t ADC_DEV_CHANNEL) { rt_uint8_t i = 0, j = 0; rt_uint32_t value_buf[N]; rt_uint32_t temp = 0,sum = 0; _ rt_adc_read(adc_dev, ADC_DEV_CHANNEL); //丢弃1 rt_thread_delay(5); //延时 rt_adc_read(adc_dev, ADC_DEV_CHANNEL); //丢弃2_ for(i = 0; i < N; i++){ _rt_thread_delay(5); //调整顺序_ value_buf[i] = rt_adc_read(adc_dev, ADC_DEV_CHANNEL); } ``` 你写的程序代码,实在是挑不出毛病的。 再不然就是 像你这样对时间不敏感的,就降低ADC CLK频率,加大采样时间周期数。 再一个就是 在硬件引脚那里加入一个小的滤波电容。
靖哥哥我滴神
2021-09-04
使用的ADC设备 不知道为啥会出现这样的原因 编译环境是rtthread studio
红枫
2021-09-04
试试每个通道连续采集2次,取第二次采集值,这样可以消除通道间的影响
StackYuan
2021-09-06
这个要把实际的NTC电路拿出来看,ADC是名义上的IO高阻态吗,如果本身温感输出端阻抗就很高,IO的阻抗就需要注意到
Trank_飛飛
2021-09-16
行有不得者,皆反求诸己
你可以试试吧关闭通道的函数单独做一个线程,用条件或者命令关闭,然后多读几次数据看看后面的数据正常不正常,我之前用ADC发现第一次数据好像确实有点问题,但是后面的数据是OK的,根据例程读完之后立刻关闭通道,似乎你每一次都是第一次有问题的数据。。
1.3k
靖哥哥我滴神
40
rt_thread studio 啥时候能用呢
RT_Thread使用反馈帖子
RTT studio 下的 AT指令问题。
rt thread Studio 关于J-LINK下载问题
RT-Thread studio 调试设置问题
RTT-Studio 如何设置调试配置参数?
rt_thread studio 软件包配置
RT-Studio目前只能开发STM32的项目吗?
rtt studio 生成hex名字修改
