使用串口传输一组数据驱动另一外设
发布于 2021-09-14 20:54:12 浏览:583
大家好!我想请教一下。我想通过板子上的串口6以数组的形式发送一组数据到另一个板子,驱动上面的数码管屏幕显示数据。 这个是我在keil裸机开发里写的程序,数组包含六个元素,帧头,功能,数据各位数和校验和。串口6需要修改波特率为9600. ```c void Humi_Display(float humidity) //ÏÔʾʪ¶Èµ½ÆÁÄ» { uint8_t func=0,ten=0,units=0,digit=0; Data_TypeDef Data_2; Data_2.Frame_Head = 0xAA; Data_2.Function = 0x02; Data_2.Ten = (int)(humidity/10)%10; Data_2.Units = (int)(humidity/1)%10; Data_2.Digit = (int)(humidity*10/1)%10; func=Data_2.Function; ten=Data_2.Ten; units=Data_2.Units; digit=Data_2.Digit; Data_2.BBC = func^ten^units^digit; uint8_t Message[6]={Data_2.Frame_Head,Data_2.Function,Data_2.Ten,Data_2.Units,Data_2.Digit,Data_2.BBC}; HAL_UART_Transmit(&huart6,Message,sizeof(Message),0xFFFF); ``` 下面是我在rt-thread 中的代码 ```c #include
#define UART_NAME "uart6" /* 需要操作的设备 */ static rt_device_t serial; /* 设备句柄 */ struct serial_configure config = RT_SERIAL_CONFIG_DEFAULT; void uart_sample(float x) { uint8_t func = 0x02; uint8_t ten = (int)(x/10)%10; uint8_t units = (int)(x/1)%10; uint8_t digit = (int)(x*10/1)%10; rt_err_t ret = RT_EOK; rt_size_t send_len = 0; uint8_t str[6] = {0xAA,func,ten,units,digit,func^ten^units^digit}; /* 查找系统中的串口设备 */ serial = rt_device_find(UART_NAME); if (!serial) { rt_kprintf("find %s failed!\n",UART_NAME); } /*配置参数*/ config.baud_rate = BAUD_RATE_9600; //修改波特率为 9600 config.data_bits = DATA_BITS_8; //数据位 8 config.stop_bits = STOP_BITS_1; //停止位 1 config.bufsz = 128; //修改缓冲区 buff size 为 128 config.parity = PARITY_NONE; //无奇偶校验位 rt_device_control(serial, RT_DEVICE_CTRL_CONFIG, &config); /* 以中断接收及轮询发送模式打开串口设备 */ ret = rt_device_open(serial, RT_DEVICE_FLAG_INT_RX); if (ret != RT_EOK) { rt_kprintf("open device failed\r\n"); } /* 发送字符串 */ send_len = rt_device_write(serial, 0, str, (sizeof(str) - 1)); if (send_len != sizeof(str) - 1) { rt_kprintf("send data failed\r\n"); } /* 关闭设备 ret = rt_device_close(serial); if (ret != RT_EOK) { rt_kprintf("close device failed\r\n"); return -RT_ERROR; } rt_kprintf("serial device test successful\r\n");*/ } ``` 代码编译没有问题,但是下载后数码管没有显示数字(已通电)。可以麻烦帮我看一下哪里出了纰漏吗,谢谢!
Trank_飛飛
2021-09-15
行有不得者,皆反求诸己
感觉sizeof(str) - 1这个玩意儿有点害人,你用sizeof(str) 试试。我之前测试UART的时候发现如果sizeof(str) - 1数据会少一个字节。
2021-09-14
波特率没改成功? rt_device_write(serial, 0, str, 6); 不应该这样吗?你少发了个字节
583
啾啾_
串口DMA发送数据时,数据被覆盖
关于串口DMA模式下rt_device_close问题
finsh 控制台 适配 RS 485请大神指点????
串口无法接受数据,但可以发送
串口如何有效的清除掉接收缓冲,而不必一个一个的去读取
串口接收使用方式问题
雅特力FINSH问题
