LittlevGL_LVGL
死机
LVGL控件刷新死机问题
发布于 2021-09-15 16:30:31 浏览:3696
[tocm] 坛友们,最近遇到一个头大的问题,使用littlevgl2rtt移植littlevgl,做个几个页面,死机的问题,主函数的内容如下,只刷新一个文本框的值。 ```c rt_pin_detach_irq(Column_A); rt_pin_detach_irq(Column_B); rt_pin_detach_irq(Column_C); rt_pin_detach_irq(Column_D); rt_pin_detach_irq(Column_E); rt_pin_detach_irq(Column_F); rt_mutex_take(dynamic_mutex, RT_WAITING_FOREVER); if (guider_ui.screen == lv_scr_act()) { //lv_label_set_text(guider_ui.screen_label_1, strff); lv_textarea_set_text(guider_ui.screen_ta_1, "strff\0"); } rt_mutex_release(dynamic_mutex); rt_pin_attach_irq(Column_A, PIN_IRQ_MODE_FALLING, keyboard_isr_function, (void *)0x01); rt_pin_attach_irq(Column_B, PIN_IRQ_MODE_FALLING, keyboard_isr_function, (void *)0x02); rt_pin_attach_irq(Column_C, PIN_IRQ_MODE_FALLING, keyboard_isr_function, (void *)0x03); rt_pin_attach_irq(Column_D, PIN_IRQ_MODE_FALLING, keyboard_isr_function, (void *)0x04); rt_pin_attach_irq(Column_E, PIN_IRQ_MODE_FALLING, keyboard_isr_function, (void *)0x05); rt_pin_attach_irq(Column_F, PIN_IRQ_MODE_FALLING, keyboard_isr_function, (void *)0x06); ``` ## 硬件平台 stm32f407zet6 ili9431 240*320 lcd,使用键盘,无触摸,无SDRAM ## 软件平台 使用nxp gui guider开发页面之后添加文件到工程, ```c lv_ui guider_ui; static void lvgl_demo_run(void *p) { // lv_demo_widgets(); setup_ui(&guider_ui); events_init(&guider_ui); } ``` ## 输入设备 矩阵键盘扫描后会发送按键值,对接lvgl的按键接口,其他的地方都没有修改,对接rtt的修改如下了 ```c static void lvgl_tick_run(void *p) { // if (_lv_init) // { // lv_tick_inc(5); // } while (1) { lv_tick_inc(5); rt_thread_delay(5); } } static int lvgl_tick_handler_init(void) { // rt_timer_t timer = RT_NULL; // int ret; // timer = rt_timer_create("lv_tick", lvgl_tick_run, RT_NULL, 5, RT_TIMER_FLAG_PERIODIC); // if (timer == RT_NULL) // { // return RT_ERROR; // } // ret = rt_timer_start(timer); // return ret; int ret; rt_thread_t thread = RT_NULL; /* littleGL demo gui thread */ thread = rt_thread_create("lv-tick", lvgl_tick_run, RT_NULL, 10 * 1024, 3, 10); ret = rt_thread_startup(thread); return ret; } static void lvgl_task_run(void *p) { void *buf1 = disp_buf.buf1; static rt_base_t level; while (_lv_init) { rt_thread_mdelay(30); rt_pin_detach_irq(Column_A); rt_pin_detach_irq(Column_B); rt_pin_detach_irq(Column_C); rt_pin_detach_irq(Column_D); rt_pin_detach_irq(Column_E); rt_pin_detach_irq(Column_F); rt_mutex_take(dynamic_mutex, RT_WAITING_FOREVER); lv_task_handler(); rt_mutex_release(dynamic_mutex); rt_pin_attach_irq(Column_A, PIN_IRQ_MODE_FALLING, keyboard_isr_function, (void *)0x01); rt_pin_attach_irq(Column_B, PIN_IRQ_MODE_FALLING, keyboard_isr_function, (void *)0x02); rt_pin_attach_irq(Column_C, PIN_IRQ_MODE_FALLING, keyboard_isr_function, (void *)0x03); rt_pin_attach_irq(Column_D, PIN_IRQ_MODE_FALLING, keyboard_isr_function, (void *)0x04); rt_pin_attach_irq(Column_E, PIN_IRQ_MODE_FALLING, keyboard_isr_function, (void *)0x05); rt_pin_attach_irq(Column_F, PIN_IRQ_MODE_FALLING, keyboard_isr_function, (void *)0x06); // rt_hw_interrupt_enable(level); } #if (LV_ENABLE_GC == 1) lv_deinit(); #endif rt_free(buf1); } ``` ## 尝试过解决方案 1. 所有切换页面的地方加锁,关闭矩阵键盘的IO中断; 2. 把lvgl的任务处理线程都改到最高优先级; 3. 加大线程的栈空间; 4. 主函数中使用lv的地方也加锁; 5. 切换页面的时候删除对象,清理内存; ## 错误提示 ``` psr: 0x21000000 r00: 0x00000001 r01: 0xd7080003 r02: 0x00000000 r03: 0x2000fac8 r04: 0xd7080003 r05: 0xd7080003 r06: 0xd7080003 r07: 0x00000051 r08: 0x2000faa0 r09: 0xdeadbeef r10: 0xdeadbeef r11: 0xdeadbeef r12: 0x0805a621 lr: 0x08044601 pc: 0x08044612 hard fault on thread: main thread pri status sp stack size max used left tick error -------- --- ------- ---------- ---------- ------ ---------- --- lv-task 5 suspend 0x0000008c 0x00002800 15% 0x00000006 000 lv-tick 3 suspend 0x00000074 0x00002800 01% 0x0000000a 000 tshell 20 suspend 0x00000084 0x00001000 03% 0x0000000a 000 thread1 20 suspend 0x00000090 0x00000200 28% 0x00000001 000 tidle0 31 ready 0x00000054 0x00000400 08% 0x00000011 000 main 10 running 0x00000094 0x00005000 04% 0x00000012 000 bus fault: SCB_CFSR_BFSR:0x82 PRECISERR SCB->BFAR:D7080003 ``` 死在下面这个地方的概率很大 ``` lv_obj_t * lv_obj_get_parent(const lv_obj_t * obj) { LV_ASSERT_OBJ(obj, LV_OBJX_NAME); return obj->parent; } ``` 最近这个问题卡了好久了,头大,看过很多这方面的历程,大都移植了demo,没看到具体的工程,每次出错的地址还不一样,有没有搞过的坛友指点一下迷津,感激不尽.
2021-09-15
从你这个信息来看,空指针的可能性比较大! 看MPU是否可以让0地址不可读,能的话,应该可以找出不少问题来。
3.7k
RichardWei
新手请教关于hardfault怎么查
STM32F1+RTT串口接收中断进入hardfault
STM32F746NG随机进入hardfault(已解决)
