scons编译出错
scons make 编译失败,求原因
发布于 2021-09-16 08:04:44 浏览:1061
请教大家出错的原因, 而且为什么make 和scons编译结果不一样呢? 步骤 1. scons --target=makefile ![image.png](https://oss-club.rt-thread.org/uploads/20210916/318c1157218285b75366ab08a40ba463.png) 2 make ![image.png](https://oss-club.rt-thread.org/uploads/20210916/c25b654a209c647a022bdfc91b428b0c.png) 使用scons 编译 3 ![image.png](https://oss-club.rt-thread.org/uploads/20210916/cff7a6fe0fe99f3d6e83b4bdae8d7fb2.png) rtconfig.py ```python import os ARCH = 'risc-v' CPU = 'bumblebee' CROSS_TOOL = 'gcc' if os.getenv('RTT_CC'): CROSS_TOOL = os.getenv('RTT_CC') if CROSS_TOOL == 'gcc': PLATFORM = 'gcc' EXEC_PATH = r'E:/DevBoard/ARTT/rt-studio/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/WCH/RISC-V-GCC-WCH/8.2.0/bin' #EXEC_PATH = r'/opt/unknown-gcc/bin' else: print('Please make sure your toolchains is GNU GCC!') exit(0) if os.getenv('RTT_EXEC_PATH'): EXEC_PATH = os.getenv('RTT_EXEC_PATH') BUILD = 'debug' CORE = 'risc-v' MAP_FILE = 'rtthread.map' LINK_FILE = './linkscripts/link.lds' TARGET_NAME = 'rtthread.hex' if PLATFORM == 'gcc': PREFIX = 'riscv-none-embed-' CC = PREFIX + 'gcc' CXX= PREFIX + 'g++' AS = PREFIX + 'gcc' AR = PREFIX + 'ar' LINK = PREFIX + 'gcc' TARGET_EXT = 'elf' SIZE = PREFIX + 'size' OBJDUMP = PREFIX + 'objdump' OBJCPY = PREFIX + 'objcopy' DEVICE = ' -march=rv32imac -mabi=ilp32 -DUSE_PLIC -DUSE_M_TIME -DNO_INIT -mcmodel=medany -msmall-data-limit=8 -L. -nostartfiles -lc ' CFLAGS = DEVICE CFLAGS += ' -save-temps=obj' AFLAGS = '-c'+ DEVICE + ' -x assembler-with-cpp' AFLAGS += ' -IIlibraries/Core -Ilibraries/WCH32V103_std_peripheral -Ilibraries/WCH32V103_std_peripheral/inc' LFLAGS = DEVICE LFLAGS += ' -Wl,--gc-sections,-cref,-Map=' + MAP_FILE LFLAGS += ' -T ' + LINK_FILE LFLAGS += ' -Wl,-wrap=memset' CPATH = '' LPATH = '' if BUILD == 'debug': CFLAGS += ' -O0 -g3' AFLAGS += ' -g3' else: CFLAGS += ' -O2' POST_ACTION = OBJCPY + ' -O binary $TARGET ' + TARGET_NAME + '\n' POST_ACTION += SIZE + ' $TARGET\n' ``` link.lds ```c ENTRY( _start ) __stack_size = 2048; PROVIDE( _stack_size = __stack_size ); MEMORY { FLASH (rx) : ORIGIN = 0x00000000, LENGTH = 64K RAM (xrw) : ORIGIN = 0x20000000, LENGTH = 20K } SECTIONS { .init : { _sinit = .; . = ALIGN(4); KEEP(*(SORT_NONE(.init))) . = ALIGN(4); _einit = .; } >FLASH AT>FLASH .vector : { *(.vector); . = ALIGN(64); } >FLASH AT>FLASH .text : { . = ALIGN(4); *(.text) *(.text.*) *(.rodata) *(.rodata*) *(.glue_7) *(.glue_7t) *(.gnu.linkonce.t.*) /* section information for finsh shell */ . = ALIGN(4); __fsymtab_start = .; KEEP(*(FSymTab)) __fsymtab_end = .; . = ALIGN(4); __vsymtab_start = .; KEEP(*(VSymTab)) __vsymtab_end = .; . = ALIGN(4); /* section information for initial. */ . = ALIGN(4); __rt_init_start = .; KEEP(*(SORT(.rti_fn*))) __rt_init_end = .; . = ALIGN(4); /* section information for modules */ . = ALIGN(4); __rtmsymtab_start = .; KEEP(*(RTMSymTab)) __rtmsymtab_end = .; . = ALIGN(4); } >FLASH AT>FLASH .fini : { KEEP(*(SORT_NONE(.fini))) . = ALIGN(4); } >FLASH AT>FLASH PROVIDE( _etext = . ); PROVIDE( _eitcm = . ); .preinit_array : { PROVIDE_HIDDEN (__preinit_array_start = .); KEEP (*(.preinit_array)) PROVIDE_HIDDEN (__preinit_array_end = .); } >FLASH AT>FLASH .init_array : { PROVIDE_HIDDEN (__init_array_start = .); KEEP (*(SORT_BY_INIT_PRIORITY(.init_array.*) SORT_BY_INIT_PRIORITY(.ctors.*))) KEEP (*(.init_array EXCLUDE_FILE (*crtbegin.o *crtbegin?.o *crtend.o *crtend?.o ) .ctors)) PROVIDE_HIDDEN (__init_array_end = .); } >FLASH AT>FLASH .fini_array : { PROVIDE_HIDDEN (__fini_array_start = .); KEEP (*(SORT_BY_INIT_PRIORITY(.fini_array.*) SORT_BY_INIT_PRIORITY(.dtors.*))) KEEP (*(.fini_array EXCLUDE_FILE (*crtbegin.o *crtbegin?.o *crtend.o *crtend?.o ) .dtors)) PROVIDE_HIDDEN (__fini_array_end = .); } >FLASH AT>FLASH .ctors : { /* gcc uses crtbegin.o to find the start of the constructors, so we make sure it is first. Because this is a wildcard, it doesn't matter if the user does not actually link against crtbegin.o; the linker won't look for a file to match a wildcard. The wildcard also means that it doesn't matter which directory crtbegin.o is in. */ KEEP (*crtbegin.o(.ctors)) KEEP (*crtbegin?.o(.ctors)) /* We don't want to include the .ctor section from the crtend.o file until after the sorted ctors. The .ctor section from the crtend file contains the end of ctors marker and it must be last */ KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .ctors)) KEEP (*(SORT(.ctors.*))) KEEP (*(.ctors)) } >FLASH AT>FLASH .dtors : { KEEP (*crtbegin.o(.dtors)) KEEP (*crtbegin?.o(.dtors)) KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .dtors)) KEEP (*(SORT(.dtors.*))) KEEP (*(.dtors)) } >FLASH AT>FLASH .dalign : { . = ALIGN(4); PROVIDE(_data_vma = .); } >RAM AT>FLASH .dlalign : { . = ALIGN(4); PROVIDE(_data_lma = .); } >FLASH AT>FLASH .data : { *(.gnu.linkonce.r.*) *(.data .data.*) *(.gnu.linkonce.d.*) . = ALIGN(8); PROVIDE( __global_pointer$ = . + 0x800 ); *(.sdata .sdata.*) *(.sdata2.*) *(.gnu.linkonce.s.*) . = ALIGN(8); *(.srodata.cst16) *(.srodata.cst8) *(.srodata.cst4) *(.srodata.cst2) *(.srodata .srodata.*) . = ALIGN(4); PROVIDE( _edata = .); } >RAM AT>FLASH .bss : { . = ALIGN(4); PROVIDE( _sbss = .); *(.sbss*) *(.gnu.linkonce.sb.*) *(.bss*) *(.gnu.linkonce.b.*) *(COMMON*) . = ALIGN(4); PROVIDE( _ebss = .); } >RAM AT>FLASH PROVIDE( _end = _ebss); PROVIDE( end = . ); .stack ORIGIN(RAM) + LENGTH(RAM) - __stack_size : { . = ALIGN(4); PROVIDE(_susrstack = . ); . = . + __stack_size; PROVIDE( _eusrstack = .); } >RAM } ```
李肯陪你玩赚嵌入式
2021-09-16
看你的使用scons编译报错, undefined reference to `xxx' 大概率是这个xxx函数的实现库你没有加入链接列表。 先确认下这个xxx函数在哪里实现的,是你的源码还是库里面实现的。
2021-09-16
1. 这个是生成Makefile,所以并不会去build。 2. make出错是因为生成的Makefile中,不知道pin.c文件在哪里。 3. 错误已经很明显,链接错误,这个时候需要看你的配置,你的BSP。
1.1k
xianting77
Whatever brings you down, will eventlly make you stronger!
在 studio 中添加emwin,编译报错问题
studio创建芯片项目添加LWIP编译报错?
BSP首次使用编译不过
DHT软件包下载后编译错误
1.1.3版本的RTstudio导入1.1.4下面建立的工程后设置芯片编译就报错
STM32F103使用EMU添加PWM组件后出现编译报错
求助,关于串口配置编译报错的问题
Azure SDK for C移植中遇到的编译问题
Studio 报错 unknown 'HAL_StatusTypeDef'
studio建工程,并使能AT组件和Air720出现的一些问题
