串口发送一段时间后停止发送
发布于 2021-09-17 15:56:37 浏览:1304
大家好!想请教一下:我写了一个传感器采集数据,并打印和通过串口发送一串报文驱动数码管显示内容。采集的数据放在一个数组中。在测试中发现串口发送一段时间后就不再发送数据。想请教一下这是什么环节出现了问题。 1、传感器采集数据的程序 ``` #include
#include "sht3x.h" #include
#define SHT85_I2C_BUS_NAME "i2c1" #define SHT85_ADDR 0x44 #define THREAD_PRIORITY 25 #define THREAD_STACK_SIZE 1024 #define THREAD_TIMESLICE 5 static rt_thread_t Sht85_Thread = RT_NULL; static rt_thread_t Sht85_Print_Thread = RT_NULL; static rt_sem_t Sht85_sem = RT_NULL; float humidity = 0; void SHT85_Init(void) { Sht85_sem = rt_sem_create("SHT85_sem", 0, RT_IPC_FLAG_FIFO); //i2c1采集线程初始化 // Sht85_Thread = rt_thread_create("SHT85_Get", SHT85_Thread_entry, RT_NULL, THREAD_STACK_SIZE, THREAD_PRIORITY, THREAD_TIMESLICE); if(Sht85_Thread!=RT_NULL) { rt_thread_startup(Sht85_Thread); } else { rt_kprintf("sht85 thread create failed\n"); } Sht85_Print_Thread = rt_thread_create("SHT85_Print",SHT85_Print_Thread_entry,RT_NULL,THREAD_STACK_SIZE,THREAD_PRIORITY-1,THREAD_TIMESLICE); if(Sht85_Print_Thread!=RT_NULL) { rt_thread_startup(Sht85_Print_Thread); } } static void SHT85_Thread_entry(void* parameter) { sht3x_device_t sht85_device; sht85_device = sht3x_init(SHT85_I2C_BUS_NAME, SHT85_ADDR); int i = 0; while(1) { if(sht3x_read_singleshot(sht85_device)==RT_EOK) { humidity = sht85_device->humidity; I2c1_Buffer[i++] = humidity; if(i==10) { rt_sem_release(Sht85_sem); i = 0; } } else { rt_kprintf("read sht85 fail.\r\n"); break; } rt_thread_mdelay(200); } } static void SHT85_Print_Thread_entry(void* parameter) { static rt_err_t sem_result; while(1) { sem_result = rt_sem_take(Sht85_sem, RT_WAITING_FOREVER); if(sem_result==RT_EOK) { printf("i2c1 value: %.2f\n",I2c1_Buffer[0]); uart6_transmit(I2c1_Buffer[0],0x02); } else { rt_sem_delete(Sht85_sem); return; } rt_thread_mdelay(2000); } } ``` 2、串口发送的程序 ``` #include
#define UART_NAME "uart6" /* 需要操作的设备 */ static rt_device_t serial; /* 设备句柄 */ struct serial_configure config = RT_SERIAL_CONFIG_DEFAULT; void uart6_transmit(float x,uint8_t func) /*x为需要显示的变量(湿度、风速等),function为显示功能参数 */ // { //0x01--温度、0x02--湿度、0x03--风速、0x04--等效温度 rt_err_t ret = RT_EOK; rt_size_t send_len = 0; uint8_t PN; //正负位// uint8_t digits; //小数点位// Data_TypeDef num; num.Frame_Head = 0xAA; num.Length = 5; num.Function = func; if(x<0) { PN = 0; } else { PN = 1; } if(x>=10 || (x<=-1&&x>-10)) //显示一位小数// { digits = 1; if(x>0) { x = x*10; } else { x = -x*10; } } else if(x>-1 && x<10) //显示两位小数// { digits = 2; if(x>0) { x = x*100; } else { x = -x*100; } } else if(x<=-10) //显示零位小数// { digits = 0; x = -x; } num.Data_Nature = digits + PN*16; num.Data_High = (int)x>>8; //数据化为十六进制高八位// num.Data_Low = (int)x & (0xFF); //数据化为十六进制低八位// num.BBC = num.Function^num.Data_High^num.Data_Low^num.Data_Nature; uint8_t str[7] = {num.Frame_Head,num.Length,num.Function,num.Data_High,num.Data_Low,num.Data_Nature,num.BBC}; /* 查找系统中的串口设备 */ serial = rt_device_find(UART_NAME); if (!serial) { rt_kprintf("find %s failed!\n",UART_NAME); } /*配置参数*/ config.baud_rate = BAUD_RATE_9600; //修改波特率为 9600 config.data_bits = DATA_BITS_8; //数据位 8 config.stop_bits = STOP_BITS_1; //停止位 1 config.bufsz = 256; //修改缓冲区 buff size config.parity = PARITY_NONE; //无奇偶校验位 rt_device_control(serial, RT_DEVICE_CTRL_CONFIG, &config); /* 以中断接收及轮询发送模式打开串口设备 */ ret = rt_device_open(serial, RT_DEVICE_FLAG_INT_RX); if (ret != RT_EOK) { rt_kprintf("open device failed\r\n"); } /* 发送字符串 */ send_len = rt_device_write(serial, 0, str, sizeof(str)); if (send_len != sizeof(str)) { rt_kprintf("send data failed\r\n"); } ///* 关闭设备 */ // ret = rt_device_close(serial); // if (ret != RT_EOK) // { // rt_kprintf("close device failed\r\n"); // } // //// rt_kprintf("serial device test successful\r\n"); } ``` 在串口调试助手捕获到这样的消息,是因为我的内存设置的原因吗? ![image.png](https://oss-club.rt-thread.org/uploads/20210917/c67d1994613bf7f0284eefc3b236f3b7.png.webp)
李肯陪你玩赚嵌入式
2021-09-17
![image.png](https://oss-club.rt-thread.org/uploads/20210917/e9bc496e8ca970536a57cadfb036e211.png.webp) ![image.png](https://oss-club.rt-thread.org/uploads/20210917/ff1be38000ab5ddd4452f057ff5f3054.png) ![image.png](https://oss-club.rt-thread.org/uploads/20210917/9f6c1163c13fff79565e4a19176e7729.png) 如上几张图,猜测大概率是串口的fifo buffer满了,排查下吧。 (components/drivers/serial/serial.c:358)
2021-09-17
把串口线程的优先级提高一下试试,有可能串口发送或者接收被打断。
cxhxy12345
2021-09-17
你这里要将串口发送的配置移动到串口初始化中
2021-09-17
uart6_transmit 里,每次都打开一次串口? rt_device_write(serial, 0, str, sizeof(str)); 直接写 num 结构体变量不行?
1.3k
啾啾_
rt_thread studio 啥时候能用呢
RT_Thread使用反馈帖子
RTT studio 下的 AT指令问题。
rt thread Studio 关于J-LINK下载问题
RT-Thread studio 调试设置问题
RTT-Studio 如何设置调试配置参数?
rt_thread studio 软件包配置
RT-Studio目前只能开发STM32的项目吗?
rtt studio 生成hex名字修改
