RS485
uart4
同时打开CAN与RS485的通讯,RS485无法正常通讯
发布于 2021-10-09 08:46:56 浏览:848
```c /*START RS485*/ /******************uart task*********************/ rt_thread_t thread = rt_thread_create("MsgProLoop", MsgProLoop, RT_NULL, 128*12,17, 10); /* 创建成功则启动线程 */ if (thread != RT_NULL) { rt_thread_startup(thread); } else { rt_kprintf("Create SDIOCortex error!"); } /********************************************************/ //////////////////////////////////////////////////////// /**************************uart receive******************/ rt_pin_write(44,1); rt_thread_mdelay(1); while (rt_device_read(serial, -1, &ch, 1) != 1) { /* 阻塞等待接收信号量,等到信号量后再次读取数据 */ rt_sem_take(&rx_sem, RT_WAITING_FOREVER); } rt_thread_mdelay(1); rt_pin_write(44,0); //////////////////////////////////////////////// /****************send uart data**************************/ rt_pin_write(44,0); rt_thread_mdelay(1); size = rt_device_write(serial, 0, LocSpeedRemData, (sizeof(LocSpeedRemote_T))); rt_thread_mdelay(1); rt_pin_write(44,1); /**************send uart data end****************************/ /*END RS485*/ /*can start*/ rt_err_t res; rt_thread_t thread; rt_thread_t threadtx; char can_name[RT_NAME_MAX]; rt_strncpy(can_name, CAN_DEV_NAME1, RT_NAME_MAX); /* 查找 CAN 设备 */ can_timeout1 = rt_timer_create("tmrcan1", cansendtimeout1, RT_NULL, 2000, RT_TIMER_FLAG_ONE_SHOT|RT_TIMER_FLAG_SOFT_TIMER); can_dev1 = rt_device_find(can_name); if (!can_dev1) { rt_kprintf("find %s failed!\n", can_name); return RT_ERROR; } /* 初始化 CAN 接收信号量 */ rt_sem_init(&rx_sem1, "rx_sem", 0, RT_IPC_FLAG_FIFO); res = rt_device_control(can_dev1, RT_CAN_CMD_SET_BAUD, (void *)CAN250kBaud); res = rt_device_control(can_dev1, RT_CAN_CMD_SET_MODE, (void *)RT_CAN_MODE_NORMAL); /* 以中断接收及发送方式打开 CAN 设备 */ res = rt_device_open(can_dev1, RT_DEVICE_FLAG_INT_TX | RT_DEVICE_FLAG_INT_RX); RT_ASSERT(res == RT_EOK); /* 创建数据接收线程 */ thread = rt_thread_create("can_rx1", can_rx_thread1, RT_NULL, 1024, 19, 10); if (thread != RT_NULL) { rt_thread_startup(thread); } else { rt_kprintf("create can_rx1 thread failed!\n"); } threadtx = rt_thread_create("can_tx1", can_tx_thread1, RT_NULL, 1024, 18, 10); if (threadtx != RT_NULL) { rt_thread_startup(threadtx); } else { rt_kprintf("create can_tx thread failed!\n"); } /*can end*/ ```
守望者
2021-10-09
问题自己已解决!!!
水中天
2021-10-09
能贴一下正确解决方案,开源学习,我们避免踩坑么?谢谢
848
守望者
谁有STM32裸跑的CANopen程序啊???
CAN驱动程序框架
CAN驱动接口如何规范一下
STM32F10XCAN驱动使用的问题
rtthread2.1.0下,找不到can1设备
