信号量_semaphore
获取信号量卡在rt_ipc_list_suspend()的问题
发布于 2021-10-15 11:24:05 浏览:1151
[tocm] # RTT版本号 - V4.0.3 # 问题描述 在使用rt_sem_take()函数进行信号量获取时,会卡死在如下函数(位于ipc.c): ```c /** * This function will suspend a thread to a specified list. IPC object or some * double-queue object (mailbox etc.) contains this kind of list. * * @param list the IPC suspended thread list * @param thread the thread object to be suspended * @param flag the IPC object flag, * which shall be RT_IPC_FLAG_FIFO/RT_IPC_FLAG_PRIO. * * @return the operation status, RT_EOK on successful */ rt_inline rt_err_t rt_ipc_list_suspend(rt_list_t *list, struct rt_thread *thread, rt_uint8_t flag) { /* suspend thread */ rt_thread_suspend(thread); switch (flag) { case RT_IPC_FLAG_FIFO: rt_list_insert_before(list, &(thread->tlist)); break; case RT_IPC_FLAG_PRIO: { struct rt_list_node *n; struct rt_thread *sthread; /* find a suitable position */ for (n = list->next; n != list; n = n->next) { sthread = rt_list_entry(n, struct rt_thread, tlist); /* find out */ if (thread->current_priority < sthread->current_priority) { /* insert this thread before the sthread */ rt_list_insert_before(&(sthread->tlist), &(thread->tlist)); break; } } /* * not found a suitable position, * append to the end of suspend_thread list */ if (n == list) rt_list_insert_before(list, &(thread->tlist)); } break; default: break; } return RT_EOK; } ``` 具体是卡在31-42的for循环中,Debug发现for循环条件中,list变量的next和prev成员均为同一个,导致无限循环: ![image.png](https://oss-club.rt-thread.org/uploads/20211015/0e97a519c7995fecb3c4928dc9cc3fe8.png) thread和sthread亦为同一个: ![image.png](https://oss-club.rt-thread.org/uploads/20211015/fc5557fa67125d36d705da6b27d7e241.png)
mysterywolf
2021-10-15
"头好壮壮"问题 终于出现了 你把 ```c if (thread->current_priority < sthread->current_priority) ``` 改成 ```c if (thread->current_priority <= sthread->current_priority) ``` 多加个等于号试试 顺便请麻烦提供一个简单的范例 让我们可以复现这个问题. 这个范例对我们非常重要 谢谢!
李肯陪你玩赚嵌入式
2021-10-15
啊,有些不可思议; rt_sem_take()应该是一个应用非常广泛的接口, 不应该会出这种致命命题, 建议[参考文档](https://docs.rt-thread.org/#/rt-thread-version/rt-thread-standard/programming-manual/ipc1/ipc1?id=%e7%ba%bf%e7%a8%8b%e9%97%b4%e5%90%8c%e6%ad%a5),排查上是否有接口使用流程上的时序问题?
2021-10-15
prev == next 不是问题,问题是 thread 和 sthread 不应该一样。 sthread->next 应该是指向 list 0x2000594C 或者其它地址的,但是它指向了自己。这是死循环的原因。 或者说,这个线程曾经执行过 `rt_sem_take` ,它已经被挂到了信号量的挂起线程列表上。但是某种原因让 thread 的 tlist 指针从链表上脱落了,指向了它自己,但是信号量的挂起线程列表上还挂着它的指针,进而出现了 sthread 和 thread 相等的现象。 强烈建议使用我刚做的工具查一下。`rt_sem_take` 前后把thread和sem的内存打印出来。
flyboy
2021-10-15
Do my self();
thread和sthread亦为同一个的话,那不就意味着,这个线程之前已经被挂上去了吗?这是又挂起了一个相同的线程吗?不好搞,有复现的代码最好了,我们来帮忙看看。
BarryAllen
2021-10-22
感谢各位大神!找到出现此问题的原因了,是因为我粗心的在中断中使用了rt_thread_mdelay(),才导致一系列的问题
1.2k
BarryAllen
怎样可以将信号量复位为初始值
rt_sem_take 引起段错误
生产者消费者中是否可以使用一个事件集来代替多个二值信号量?
看RTT文档,不太懂有关信号量的死锁问题
这样使用UART接收一帧数据的方法是否可行
一对多线程间通信的问题
二值信号量的使用问题
USART1_IRQHandler串口中断接收问题
开发文档semaphore_sample.c有问题
NXP MCXN947测评之 adc
