信号量_semaphore
信号量初始化失败,但返回的是RT_EOK
发布于 2021-10-19 10:20:06 浏览:1227
![1.png](https://oss-club.rt-thread.org/uploads/20211019/b0d671abdb7c7ab2823a0ef1a2fe8786.png) ![2.png](https://oss-club.rt-thread.org/uploads/20211019/3ee374e9ea9bda0be67bb4478c54f897.png) 使用NANO版本,硬件是STM32G030,信号量怎么也初始化不了,返回的也是RT_EOK
Papalymo
2021-10-19
请勿打扰
init 是初始化信号量。 换成create: ```c key_it_sem = rt_sem_create("ksem", 100, RT_IPC_FLAG_PRIO); ``` 或者修改信号量类型为: ```c struct rt_semaphore key_it_sem; ``` 信号量参考例程:https://github.com/RT-Thread/rt-thread/blob/master/examples/utest/testcases/kernel/semaphore_tc.c 信号量文档:https://www.rt-thread.org/document/site/#/rt-thread-version/rt-thread-standard/programming-manual/ipc1/ipc1?id=%e4%bf%a1%e5%8f%b7%e9%87%8f
李肯陪你玩赚嵌入式
2021-10-19
或许你可以了解下rt_sem_init()和rt_sem_create()的区别。 ```c /**@{*/ /** * @brief This function will initialize a static semaphore object. * * @note For the static semaphore object, its memory space is allocated by the compiler during compiling, * and shall placed on the read-write data segment or on the uninitialized data segment. * By contrast, the rt_sem_create() function will allocate memory space automatically and initialize * the semaphore. * * @see rt_sem_create() * * @param sem is a pointer to the semaphore to initialize. It is assumed that storage for the semaphore will be * allocated in your application. * * @param name is a pointer to the name you would like to give the semaphore. * * @param value is the initial value for the semaphore. * If used to share resources, you should initialize the value as the number of available resources. * If used to signal the occurrence of an event, you should initialize the value as 0. * * @param flag is the semaphore flag, which determines the queuing way of how multiple threads wait * when the semaphore is not available. * The semaphore flag can be ONE of the following values: * * RT_IPC_FLAG_PRIO The pending threads will queue in order of priority. * * RT_IPC_FLAG_FIFO The pending threads will queue in the first-in-first-out method * (also known as first-come-first-served (FCFS) scheduling strategy). * * NOTE: RT_IPC_FLAG_FIFO is a non-real-time scheduling mode. It is strongly recommended to * use RT_IPC_FLAG_PRIO to ensure the thread is real-time UNLESS your applications concern about * the first-in-first-out principle, and you clearly understand that all threads involved in * this semaphore will become non-real-time threads. * * @return Return the operation status. When the return value is RT_EOK, the initialization is successful. * If the return value is any other values, it represents the initialization failed. * * @warning This function can ONLY be called from threads. */ rt_err_t rt_sem_init(rt_sem_t sem, const char *name, rt_uint32_t value, rt_uint8_t flag) ``` ```c /** * @brief Creating a semaphore object. * * @note For the semaphore object, its memory space is allocated automatically. * By contrast, the rt_sem_init() function will initialize a static semaphore object. * * @see rt_sem_init() * * @param name is a pointer to the name you would like to give the semaphore. * * @param value is the initial value for the semaphore. * If used to share resources, you should initialize the value as the number of available resources. * If used to signal the occurrence of an event, you should initialize the value as 0. * * @param flag is the semaphore flag, which determines the queuing way of how multiple threads wait * when the semaphore is not available. * The semaphore flag can be ONE of the following values: * * RT_IPC_FLAG_PRIO The pending threads will queue in order of priority. * * RT_IPC_FLAG_FIFO The pending threads will queue in the first-in-first-out method * (also known as first-come-first-served (FCFS) scheduling strategy). * * NOTE: RT_IPC_FLAG_FIFO is a non-real-time scheduling mode. It is strongly recommended to * use RT_IPC_FLAG_PRIO to ensure the thread is real-time UNLESS your applications concern about * the first-in-first-out principle, and you clearly understand that all threads involved in * this semaphore will become non-real-time threads. * * @return Return a pointer to the semaphore object. When the return value is RT_NULL, it means the creation failed. * * @warning This function can NOT be called in interrupt context. You can use macor RT_DEBUG_NOT_IN_INTERRUPT to check it. */ rt_sem_t rt_sem_create(const char *name, rt_uint32_t value, rt_uint8_t flag) ```
1.2k
BruceLhr
怎样可以将信号量复位为初始值
rt_sem_take 引起段错误
生产者消费者中是否可以使用一个事件集来代替多个二值信号量?
看RTT文档,不太懂有关信号量的死锁问题
这样使用UART接收一帧数据的方法是否可行
一对多线程间通信的问题
二值信号量的使用问题
USART1_IRQHandler串口中断接收问题
开发文档semaphore_sample.c有问题
MCXN947测评系列(二)串口设备测评
猪的行独
