信号量_semaphore
用信号量做线程同步的一个小问题
发布于 2021-10-19 22:19:37 浏览:697
两个线程之间用信号量做同步,但发现发送线程只发一次的话,接受线程会重复执行,不知道什么原因。 ```c static void one_key_brew_entry(void *param) { rt_err_t ret = RT_EOK; //parse_formula(formula2); while(1) { LOG_D("========wating recv brew sem, start formula making the value is %d\n", brew_sem.value); rt_sem_take(&brew_sem, RT_WAITING_FOREVER); LOG_D("recv brew sem, start formula making the value is %d\n", brew_sem.value); if (g_start_brew_flag == 1) { parse_formula(formula4); g_start_brew_flag = 0; } rt_thread_mdelay(100); } } ``` ![image.png](https://oss-club.rt-thread.org/uploads/20211019/aab374a2697f551744ef4851a013eba6.png.webp) 就是第一次接受成功以后,然后执行完相关的parse_formula,按道理就直接等待 信号量,brew_sem,就可以,但不知为何,打印了好多次。已经获取到了信号量,确认,主线程,没有发新的信号量。
2021-10-20
把关键的发送接收部分的代码贴出来嘛. 如果你开了finsh,这个时候用我刚做工具查看一下 brew_sem 信号量的详细内容,以及内存里的值正常不正常。详情请看我的最后一篇文章介绍。
李肯陪你玩赚嵌入式
2021-10-20
根据RRT对[rt_sem_take接口的介绍](https://docs.rt-thread.org/#/rt-thread-version/rt-thread-standard/programming-manual/ipc1/ipc1?id=%e4%bf%a1%e5%8f%b7%e9%87%8f): ![image.png](https://oss-club.rt-thread.org/uploads/20211020/a34811a4dffab556e2b98d77af82f855.png.webp) 以及源码里面的注释介绍: ``` /** * @brief This function will take a semaphore, if the semaphore is unavailable, the thread shall wait for * the semaphore up to a specified time. * * @note When this function is called, the count value of the sem->value will decrease 1 until it is equal to 0. * When the sem->value is 0, it means that the semaphore is unavailable. At this time, it will suspend the * thread preparing to take the semaphore. * On the contrary, the rt_sem_release() function will increase the count value of sem->value by 1 each time. * * @see rt_sem_trytake() * * @param sem is a pointer to a semaphore object. * * @param time is a timeout period (unit: an OS tick). If the semaphore is unavailable, the thread will wait for * the semaphore up to the amount of time specified by the argument. * NOTE: Generally, we use the macro RT_WAITING_FOREVER to set this parameter, which means that when the * semaphore is unavailable, the thread will be waitting forever. * * @return Return the operation status. ONLY When the return value is RT_EOK, the operation is successful. * If the return value is any other values, it means that the semaphore take failed. * * @warning This function can ONLY be called in the thread context. It MUST NOT BE called in interrupt context. */ rt_err_t rt_sem_take(rt_sem_t sem, rt_int32_t time) ``` ![image.png](https://oss-club.rt-thread.org/uploads/20211020/951c45c8774ffabc1956f5d3967c4052.png.webp) 我猜测你这种情况是一个接口返回error了,而不是ok,你可以使用int变量接收下这个接口的返回值。 还有一定,看你打印的brew_sem.value值为0,证明信号量此时是空的(大于0表示有信号量)。 还有办法,你可以把RT_DEBUG_IPC宏打开(rtdebug.h),调试下这个接口,我看到都有关键的log打印。
cxhxy12345
2021-10-20
看了sem的值是0,也就是你并没有做信号释放(同步)的操作,但还是能你连续进入,这个要看下你的线程优先级级,因为在sem值=0的情况下,你take信号的方式是RT_WAITING_FOREVER,也就是time!=0。函数如下: ![image.png](https://oss-club.rt-thread.org/uploads/20211020/8c31aef5af614c7cee405cf93bcf23bb.png.webp) 这里会进入一个重新调度的状态,建议你做如下判断 ```c Value=rt_sem_take(sem_rx, RT_WAITING_FOREVER); ``` 将value 打印出来,看下获取信号后返回的是什么状态,再根据这个判断你的故障点在那里
697
小住住
127
124
怎样可以将信号量复位为初始值
rt_sem_take 引起段错误
生产者消费者中是否可以使用一个事件集来代替多个二值信号量?
看RTT文档,不太懂有关信号量的死锁问题
这样使用UART接收一帧数据的方法是否可行
一对多线程间通信的问题
二值信号量的使用问题
USART1_IRQHandler串口中断接收问题
开发文档semaphore_sample.c有问题
