littlefs
关于littlefs中,读取文件数据错误
发布于 2021-10-29 13:42:18 浏览:1181
```c #include
#include "main.h" #define W25QXX_CS_SET HAL_GPIO_WritePin(SPI1_CS_GPIO_Port,SPI1_CS_Pin,GPIO_PIN_SET); //W25QXXµÄƬѡÐźŲ»Ñ¡Í¨ #define W25QXX_CS_RESET HAL_GPIO_WritePin(SPI1_CS_GPIO_Port,SPI1_CS_Pin,GPIO_PIN_RESET); //W25QXXµÄƬѡÐźŲ»Ñ¡Í¨ osMutexId SPIMutexHandle; static char log_buf[256]; void sfud_log_debug(const char *file, const long line, const char *format, ...); /** * SPI write data then read data */ static sfud_err spi_write_read(const sfud_spi *spi,uint8_t *write_buf, size_t write_size, uint8_t *read_buf, size_t read_size) { sfud_err result = SFUD_SUCCESS; if (write_size) SFUD_ASSERT(write_buf); if (read_size) SFUD_ASSERT(read_buf); /* µÍµçƽÐźÅʹÄÜCSÒý½Å */ W25QXX_CS_RESET; /* ¿ªÊ¼¶ÁдÊý¾Ý */ if(read_size && write_size) { if( HAL_OK != HAL_SPI_Transmit(&hspi1, (uint8_t *)write_buf, write_size, 1000) ) result = SFUD_ERR_TIMEOUT; if( HAL_OK != HAL_SPI_Receive(&hspi1, (uint8_t *)read_buf, read_size, 1000) ) result = SFUD_ERR_TIMEOUT; } else if (write_size) { if( HAL_OK != HAL_SPI_Transmit(&hspi1, (uint8_t *)write_buf, write_size, 1000) ) result = SFUD_ERR_TIMEOUT; } else { if( HAL_OK != HAL_SPI_Receive(&hspi1, (uint8_t *)read_buf, read_size, 1000) ) result = SFUD_ERR_TIMEOUT; } /* ¸ßµçƽÐźÅʧÄÜCSÒý½Å */ W25QXX_CS_SET; return result; } static void spi_lock(const sfud_spi *spi) { osMutexWait(SPIMutexHandle, portMAX_DELAY); } static void spi_unlock(const sfud_spi *spi) { osMutexRelease(SPIMutexHandle); } /* about 100 microsecond delay */ static void retry_delay_100us(void) { DWT_Delay_us(100); } sfud_err sfud_spi_port_init(sfud_flash *flash) { sfud_err result = SFUD_SUCCESS; osMutexDef(spiMutex); SPIMutexHandle = osMutexCreate(osMutex(spiMutex)); /* ͬ²½ Flash ÒÆÖ²ËùÐèµÄ½Ó¿Ú¼°Êý¾Ý */ flash->spi.wr = spi_write_read; flash->spi.lock = spi_lock; flash->spi.unlock = spi_unlock; /* about 100 microsecond delay */ flash->retry.delay = retry_delay_100us; /* adout 60 seconds timeout */ flash->retry.times = 60 * 10000; return result; } /** * This function is print debug info. * * @param file the file which has call this function * @param line the line number which has call this function * @param format output format * @param ... args */ void sfud_log_debug(const char *file, const long line, const char *format, ...) { va_list args; /* args point to the first variable parameter */ va_start(args, format); printf("[SFUD](%s:%ld) ", file, line); /* must use vprintf to print */ vsnprintf(log_buf, sizeof(log_buf), format, args); printf("%s\r\n", log_buf); va_end(args); } /** * This function is print routine info. * * @param format output format * @param ... args */ void sfud_log_info(const char *format, ...) { va_list args; /* args point to the first variable parameter */ va_start(args, format); printf("[SFUD]"); /* must use vprintf to print */ vsnprintf(log_buf, sizeof(log_buf), format, args); printf("%s\r\n", log_buf); va_end(args); } ``` 之前在RTT里使用没有任何问题,现在换了FREERTOS,将littlefs移植过来之后,写文件没有出现过问题,但是读文件时会出现文件命名还有数据,读出来的数据长度是0,或者读出的数据出现很多0xff,此时retry_time之后,查询spi总线状态,发现一直处于busy。
2021-10-29
哦,那就换回 rtt 嘛。 可能是引脚配置出问题了,底层驱动不工作了
宋策_0114
2021-10-29
**问题已解决** 原因:在A线程读文件过程中,B线程又执行了打开路径或打开文件等命令,导致lfs_t *lfs和lfs_file_t *file变量重新被赋值,从而A线程读过程中出错。
风来吴山
2022-01-01
littlefs有个sync的同步,实现它。
1.2k
宋策_0114
romfs无法执行df命令
w25q128挂载littlefs出现assert failed?
使用littlefs出现Corrupted dir pair at 1 0
使用片上flash的 littlefs 无法创建多个目录
littlefs挂载总是在lfs.c文件中 LFS_ASSERT
littlefs文件系统卡顿问题
需要littlefs 挂载在片上flash
日志存储是使用fat如何做磨损平衡?
挂载littlefs文件系统的flash寿命计算方式?
