关于rt-thread双网口指定网卡发送udp和tcp
发布于 2021-11-01 10:02:15 浏览:1871
想问下大家,当使用双网口的时候,其中网口e0指定为default网口,e1为第二网口,通过以下两种方法进行网卡绑定,发送udp广播(255.255.255.255): 1, ```c interface.s_addr = inet_addr(E0_IP); setsockopt(udp_socket, IPPROTO_IP, IP_MULTICAST_IF, &interface, sizeof(interface)); ``` 此方法无法指定网卡进行发送,E0_IP为我指定的IP地址,169.254.43.75,通过网线直连到doIP设备,发送的广播会通过另一个网卡发送出去,lwip打印如下 ``` lwip_socket(PF_INET, SOCK_DGRAM, 0) = 1 lwip_setsockopt(1, SOL_SOCKET, optname=0x20, ..) -> on Udp Socket = 1 The Interface:e0, IP No Change:169.254.43.75 Need Send is 169.254.43.75 inet_addr(169.254.43.75) = 1261174441 inet_addr(169.254.43.76) = 1277951657 interface.s_addr = 1261174441 borcast_ip = 255.255.255.255 lwip_sendto(1, data=2001cef4, short_size=8, flags=0x0 to=255.255.255.255 port=13400 udp_send udp_send: not yet bound to a port, binding now udp_bind(ipaddr = 0.0.0.0, port = 0) udp_bind: bound to 0.0.0.0, port 49153) udp_send: added header pbuf 2001fe68 before given pbuf 2000cc94 udp_send: sending datagram of length 16 udp_send: UDP packet length 16 udp_send: UDP checksum 0x2c33 udp_send: ip_output_if (,,,,0x11,) ip4_output_if: e11 IP header: +-------------------------------+ | 4 | 5 | 0x00 | 36 | (v, hl, tos, len) +-------------------------------+ | 12 |000| 0 | (id, flags, offset) +-------------------------------+ | 255 | 17 | 0xe672 | (ttl, proto, chksum) +-------------------------------+ | 169 | 254 | 43 | 76 | (src) +-------------------------------+ | 255 | 255 | 255 | 255 | (dest) +-------------------------------+ ``` 2, ```c bind(udp_socket, (struct sockaddr *)&server_addr, sizeof(struct sockaddr)) ``` 通过bind的方式进行发送,绑定成功,但是发送失败,返回120,打印如下 ``` lwip_socket(PF_INET, SOCK_DGRAM, 0) = 1 lwip_setsockopt(1, SOL_SOCKET, optname=0x20, ..) -> on Udp Socket = 1 The Interface:e0, IP No Change:169.254.43.75 Need Send is 169.254.43.75 lwip_bind(1, addr=169.254.43.75 port=0) udp_bind(ipaddr = 169.254.43.75, port = 0) udp_bind: bound to 169.254.43.75, port 49153) lwip_bind(1) succeeded borcast_ip = 255.255.255.255 lwip_sendto(1, data=2001cef4, short_size=8, flags=0x0 to=255.255.255.255 port=13400 udp_send ret = -1, Err = 120, Unknown error ``` 问下大佬们,怎么才能指定网卡并且正常发送出去呢?现在在rt-thread上,双网卡搞不定啊,求大佬们赐教!
sync
2021-11-01
先设置默认网卡1,建立socket1。然后设置默认网卡2,建立socket2。socket1,socket2也是可以同时工作的。
1.9k
Shaco
RT-THREAD在STM32H747平台上移植lwip
{lwip}使能RT_LWIP_DHCP时可以获取到ip
stm32f103 LWIP 2.0.2 TCP收发问题
lwip2.1不重启修改IP
关于网络协议栈的测试
可否将LWIP升级到2.1.2 和 2.0.3?
tcpclient 插拔网线问题?
两个tcpclient同时通讯可以吗?
SO_BINDTODEVICE 未定义该如何解决
NXP MCXN947测评之 adc
