HWTIMER_硬件定时器
硬件定时器定时不准确?
发布于 2021-11-02 09:33:02 浏览:1084
再用官方例程去调试硬件定时器的时候,发现延时5s后在回调函数里面调用rt_tick_get()不准确,这是怎么回事啊 ```c static rt_err_t timeout_cb(rt_device_t dev, rt_size_t size) { rt_kprintf("this is hwtimer timeout callback fucntion!\n"); rt_kprintf("tick is :%d !\n", rt_tick_get()); return 0; } static int hwtimer_sample(int argc, char *argv[]) { rt_err_t ret = RT_EOK; rt_hwtimerval_t timeout_s; /* 定时器超时值 */ rt_device_t hw_dev = RT_NULL; /* 定时器设备句柄 */ rt_hwtimer_mode_t mode; /* 定时器模式 */ /* 查找定时器设备 */ hw_dev = rt_device_find(HWTIMER_DEV_NAME); if (hw_dev == RT_NULL) { rt_kprintf("hwtimer sample run failed! can't find %s device!\n", HWTIMER_DEV_NAME); return RT_ERROR; } /* 以读写方式打开设备 */ ret = rt_device_open(hw_dev, RT_DEVICE_OFLAG_RDWR); if (ret != RT_EOK) { rt_kprintf("open %s device failed!\n", HWTIMER_DEV_NAME); return ret; } /* 设置超时回调函数 */ rt_device_set_rx_indicate(hw_dev, timeout_cb); /* 设置模式为周期性定时器 */ mode = HWTIMER_MODE_PERIOD; ret = rt_device_control(hw_dev, HWTIMER_CTRL_MODE_SET, &mode); if (ret != RT_EOK) { rt_kprintf("set mode failed! ret is :%d\n", ret); return ret; } /* 设置定时器超时值为5s并启动定时器 */ timeout_s.sec = 5; /* 秒 */ timeout_s.usec = 0; /* 微秒 */ if (rt_device_write(hw_dev, 0, &timeout_s, sizeof(timeout_s)) != sizeof(timeout_s)) { rt_kprintf("set timeout value failed\n"); return RT_ERROR; } /* 延时3500ms */ rt_thread_mdelay(3500); /* 读取定时器当前值 */ rt_device_read(hw_dev, 0, &timeout_s, sizeof(timeout_s)); rt_kprintf("Read: Sec = %d, Usec = %d\n", timeout_s.sec, timeout_s.usec); return ret; ``` 调试的结果: ``` Read: Sec = 3, Usec = 499387 msh />this is hwtimer timeout callback fucntion! tick is :38289 ! this is hwtimer timeout callback fucntion! tick is :43284 ! this is hwtimer timeout callback fucntion! tick is :48279 ! this is hwtimer timeout callback fucntion! tick is :53274 ! this is hwtimer timeout callback fucntion! tick is :58269 ! ```
2021-11-02
rt_tick_get()获取的是当前tick值,2次tick值之差换算为时间等同于定时时间值,计算出来都是4995,4995ms ≈ 5s,结果是准确的呀。
李肯陪你玩赚嵌入式
2021-11-02
估计楼主搞混了tick值和时间值的关系, 按照你的系统搭配置,应该1tick=1ms,也就是1000个tick=1S 正确评估定时器的定时是否精确的方法: 1.在启动定时器前rt_tick_get取一下当前的tick0值; 2.每一次定时器超时回调的时候取一下tickn值; 3.分别计算出: tick1-tick0,tick2-tick1,以此类推; 4.根据1tick与1s的换算关系,对步骤3的差值进行比较; 5。得出比较结论。 如果你不像做tick与时间的换算,你可以考虑使用rt_tick_get_millisecond代替rt_tick_get。
2021-11-02
仔细帮你查看了一下dr_hwtimer.c里面的代码, 如果5tick是你觉得疑惑的地方,你可以追踪一下dr_hwtimer.c里面的如何把5s转换成tick的地方,并且打印出来看下,最后设置的是否是5000还是4995. 以我的经验来看,应该是在clock放大和乘积的时候,有一些地方精读的丢失。具体由于不知道你的时钟是多少,所以你可以自己找到root cause。 ``` { prescaler_value = (uint32_t)(HAL_RCC_GetPCLK1Freq() * pclk1_doubler / 10000) - 1; } tim->Init.Period = 10000 - 1; tim->Init.Prescaler = prescaler_value; tim->Init.ClockDivision = TIM_CLOCKDIVISION_DIV1; ```
1.1k
吕蛋蛋
56
请问HWTIMER设备支持计数模式吗
HWTIMER 设备没有计数模式吗
ART-Pi开发板,新建Wifi示例工程,打开hwtimer就42个错误?
求助:使用HWTIMER timer13的问题
使用menuconfig 使能硬件定时器的驱动,使能PWM 编码器等,编译错误
STM32H743 的硬件定时器是不是是不是没有晚上
硬件定时器如何实现us,ms级定时功能
纳秒级的高精度定时器在RTT中的实现
HWTIMER设备TIM2_CONFIG函数要自己手动添加?F407ZGT6
【已解决】STMF103ZE定时器hwtimer 定时时间为us的时候不准确
