STM32F407
STM32F4使用CUBEMX生成DMA模式的DAC,运行出现Hardfault
发布于 2021-11-02 22:35:47 浏览:1353
代码 初始化TIM6代码 ```c TIM_HandleTypeDef mytim6; static void tim6_init(void) { TIM_MasterConfigTypeDef master_config = {0}; mytim6.Instance = TIM6; mytim6.Init.Prescaler = 1 - 1; mytim6.Init.Period = 3500; mytim6.Init.CounterMode = TIM_COUNTERMODE_UP; mytim6.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_ENABLE; HAL_TIM_Base_Init(&mytim6); master_config.MasterOutputTrigger = TIM_TRGO_UPDATE; master_config.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE; HAL_TIMEx_MasterConfigSynchronization(&mytim6, &master_config); //HAL_TIM_Base_Start_IT(&mytim6); } ``` 初始化DAC,具体引脚,DMA模式都在MSPinit函数里 ```c DAC_HandleTypeDef *hdac1; extern DMA_HandleTypeDef hdma_dac1; static void dac_dma_config(void) { DAC_ChannelConfTypeDef *hdacch1_cfg; __HAL_RCC_DMA1_CLK_ENABLE(); HAL_NVIC_SetPriority(DMA1_Stream5_IRQn, 3, 0); HAL_NVIC_EnableIRQ(DMA1_Stream5_IRQn); hdac1->Instance = DAC1; HAL_DAC_Init(hdac1); hdacch1_cfg->DAC_Trigger = DAC_TRIGGER_T6_TRGO; hdacch1_cfg->DAC_OutputBuffer = DAC_OUTPUTBUFFER_DISABLE; HAL_DAC_ConfigChannel(hdac1, hdacch1_cfg, DAC_CHANNEL_1); } MSH_CMD_EXPORT(dac_dma_config, dac sample); ``` DMA模式,GPIO等初始化 ```c void HAL_DAC_MspInit(DAC_HandleTypeDef *hdac) { GPIO_InitTypeDef GPIO_InitStruct = {0}; if (hdac->Instance == DAC) { /* USER CODE BEGIN DAC_MspInit 0 */ /* USER CODE END DAC_MspInit 0 */ /* Peripheral clock enable */ __HAL_RCC_DAC_CLK_ENABLE(); __HAL_RCC_GPIOA_CLK_ENABLE(); /**DAC GPIO Configuration PA4 ------> DAC_OUT1 PA5 ------> DAC_OUT2 */ GPIO_InitStruct.Pin = GPIO_PIN_4 | GPIO_PIN_5; GPIO_InitStruct.Mode = GPIO_MODE_ANALOG; GPIO_InitStruct.Pull = GPIO_NOPULL; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); /* USER CODE BEGIN DAC_MspInit 1 */ hdma_dac1.Instance = DMA1_Stream5; hdma_dac1.Init.Channel = DMA_CHANNEL_7; hdma_dac1.Init.Direction = DMA_MEMORY_TO_PERIPH; hdma_dac1.Init.PeriphInc = DMA_PINC_DISABLE; hdma_dac1.Init.MemInc = DMA_MINC_ENABLE; hdma_dac1.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD; hdma_dac1.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD; hdma_dac1.Init.Mode = DMA_CIRCULAR; hdma_dac1.Init.Priority = DMA_PRIORITY_HIGH; hdma_dac1.Init.FIFOMode = DMA_FIFOMODE_DISABLE; hdma_dac1.Init.FIFOThreshold = DMA_FIFO_THRESHOLD_HALFFULL; hdma_dac1.Init.MemBurst = DMA_MBURST_SINGLE; hdma_dac1.Init.PeriphBurst = DMA_PBURST_SINGLE; HAL_DMA_Init(&hdma_dac1); __HAL_LINKDMA(hdac, DMA_Handle1, hdma_dac1); /* USER CODE END DAC_MspInit 1 */ } } ``` 以上代码基本都是CUBEMX生成后直接复制过来的 仅仅调用dac_dma_config()这个函数时就会报HardFault ![1.png](https://oss-club.rt-thread.org/uploads/20211102/8bbd24e3de15ba9db6d097cb7a2099b9.png) 通过Keil debug调试发现pc寄存器指向的地方在HAL_DAC_ConfigChannel这个函数里,我改了几下都没用,请问这到底是啥原因导致的? 还有如果这种方法确实无法使用,那么在RTThread DAC驱动中该如何修改才能使用DMA功能?仅用RTThread原有框架驱动下输出的DAC频率最高似乎只有200Hz左右
2021-11-02
hi: hdac1 这个是一个指针: `DAC_HandleTypeDef *hdac1;` 没有进行初始化就使用了: ```c hdac1->Instance = DAC1; HAL_DAC_Init(hdac1); hdacch1_cfg->DAC_Trigger = DAC_TRIGGER_T6_TRGO; hdacch1_cfg->DAC_OutputBuffer = DAC_OUTPUTBUFFER_DISABLE; HAL_DAC_ConfigChannel(hdac1, hdacch1_cfg, DAC_CHANNEL_1); ```
2021-11-02
hdac1没人赋值,是个空指针吧。
ZWH
2021-11-02
这个人很勤快,没空留下点什么
内存溢出了
1.4k
Tourist
新手请教关于hardfault怎么查
STM32F1+RTT串口接收中断进入hardfault
STM32F746NG随机进入hardfault(已解决)
MCXN947测评系列(二)串口设备测评
