studio 下载软件包不成功
发布于 2021-11-05 16:03:27 浏览:875
按照其他楼主的方法,替换了_ssl.pyd文件,然后有的软件包可以下载,有的软件包下载不了 ``` There is no tracking information for the current branch. Please specify which branch you want to merge with. See git-pull(1) for details. git pull
If you wish to set tracking information for this branch you can do so with: git branch --set-upstream-to=origin/
master ==============================> LIBMODBUS latest is downloaded successfully. ==============================> libmodbus update done Operation completed successfully. done! ``` modbus协议栈可以下载成功 ``` error message:Can't connect to HTTPS URL because the SSL module is not available. https://github.com/RT-Thread-packages/cJSON/archive/v1.7.15.zip error message:Can't connect to HTTPS URL because the SSL module is not available. https://github.com/RT-Thread-packages/cJSON/archive/v1.7.15.zip error message:Can't connect to HTTPS URL because the SSL module is not available. https://github.com/RT-Thread-packages/cJSON/archive/v1.7.15.zip error message:Can't connect to HTTPS URL because the SSL module is not available. https://github.com/RT-Thread-packages/cJSON/archive/v1.7.15.zip error message:Can't connect to HTTPS URL because the SSL module is not available. D:/RT-ThreadStudio/platform/env_released/env\local_pkgs\cJSON-1.7.15.zip download fail! ({'path': '/packages/iot/cJSON', 'ver': 'v1.7.15', 'name': 'CJSON'}, 'download failed.') ==============================> libmodbus update done Operation failed. done! ``` cjson和其他网络协议栈下载失败
2021-11-05
你的电脑可以访问 github ? 被墙了吧! 配置一下修改成从 gitee 镜像仓库下载,这样就不怕墙了 https://club.rt-thread.org/ask/article/3130.html
2021-11-05
可能网络问题,那个URL链接,你直接在你电脑的浏览器里试试看能不能直接下载下来,验证一下是否网络问题。
李肯陪你玩赚嵌入式
2021-11-05
网络问题的可能性比较大。
2021-11-05
这个从log来看是从github上面下载的。github下载在国内会比较慢,可以试试翻墙用VPN试试。 可以试试这个 https://github.com/freefq/free
rcp
2021-11-22
参考下这个用户的解决方法 ![image.png](https://oss-club.rt-thread.org/uploads/20211122/46f2fb59068d0a39c959777ba0d27177.png) https://club.rt-thread.org/ask/question/432681.html 升级替换下python
875
吕蛋蛋
56
rt_thread studio 啥时候能用呢
RT_Thread使用反馈帖子
RTT studio 下的 AT指令问题。
rt thread Studio 关于J-LINK下载问题
RT-Thread studio 调试设置问题
RTT-Studio 如何设置调试配置参数?
rt_thread studio 软件包配置
RT-Studio目前只能开发STM32的项目吗?
rtt studio 生成hex名字修改
