RTT 单色SPI屏幕 硬件SPI 一打开中断向量重定向,屏幕刷新特别慢
发布于 2021-11-07 15:51:44 浏览:1106
问题是,正常跑系统rtt标准版,硬件SPI刷新屏幕(JLX256128),速度还可以。准备加入bootloader,中断向量重定向,结果一打开中断向量重定向,屏幕刷新就慢了? 环境:RT-Thread Studio 2.1.2 组件:ota_downloader 硬件:GD32F103RGT6+JLX256128单色屏幕 下面是开启重定向的代码 ```c /** * Function ota_app_vtor_reconfig * Description Set Vector Table base location to the start addr of app(RT_APP_PART_ADDR). */ static int ota_app_vtor_reconfig(void) { #define NVIC_VTOR_MASK 0x3FFFFF80 /* Set the Vector Table base location by user application firmware definition */ SCB->VTOR = 0x8020000 & NVIC_VTOR_MASK; return 0; } INIT_BOARD_EXPORT(ota_app_vtor_reconfig); ``` 这是SPI初始化代码及数据传输代码 ```c static int rt_hw_spi_lcd_init(void) { __HAL_RCC_GPIOB_CLK_ENABLE(); rt_hw_spi_device_attach("spi3", GLX256128G_929_SPI_DEV, GPIOA, GPIO_PIN_15); struct rt_spi_configuration cfg; /* ���� spi �豸��ȡ�豸��� */ lcd_spi_dev = (struct rt_spi_device *)rt_device_find(GLX256128G_929_SPI_DEV); if (GLX256128G_929_SPI_DEV==NULL) { rt_kprintf("=============err=================="); } else { cfg.data_width = 8; cfg.mode = RT_SPI_MASTER | RT_SPI_MODE_0 | RT_SPI_MSB; cfg.max_hz = 50 * 1000 *1000; /* 20M */ rt_spi_configure(lcd_spi_dev, &cfg); } return RT_EOK; } /* �������Զ���ʼ�� */ INIT_COMPONENT_EXPORT(rt_hw_spi_lcd_init); void spi3_send_char(rt_uint8_t ch) { struct rt_spi_message msg1; msg1.send_buf = &ch; msg1.recv_buf = RT_NULL; msg1.length = 1; msg1.cs_take = 1; msg1.cs_release = 1; msg1.next = RT_NULL; rt_spi_transfer_message(lcd_spi_dev, &msg1); } rt_uint8_t spi3_rev_char() { struct rt_spi_message msg2; rt_uint8_t id = 0; msg2.send_buf = RT_NULL; msg2.recv_buf = &id; msg2.length = 1; msg2.cs_take = 1; msg2.cs_release = 1; msg2.next = RT_NULL; rt_spi_transfer_message(lcd_spi_dev, &msg2); return id; } void LCD_CS_H(void) { rt_spi_release(lcd_spi_dev); } void LCD_CS_L(void) { rt_spi_take(lcd_spi_dev); } ```
2021-11-07
留意下FLASH 0等待和非0等待,中断ISR(不仅仅是向量表地址)也一定不能放非0等待区。 这芯片最好BOOt只占用0区一个最小块,boot其它部分放后面。 另外,你的SPI没用DMA吧!
2021-11-07
这个问题可以分两步进行隔断实验。 1. APP在偏移之后,运行是否正常。通常可以debug的模式下指定APP的偏移地址,这个时候查看下是否运行正常, 如果运行正常则说明问题可能在BootLoader端。 如果运行不正常,说明问题可能在偏移地址这边,可以试着改下偏移地址试试看。
2021-11-07
有没有检查过系统时钟?主频正常不? spi频率正常不?用示波器看一下频率。 去我的文章里看看系统调试利器。帮你在系统查看内核状态。
cxhxy12345
2021-11-07
bootloader后硬件需要重新定向,但不会影响系统,你是不是重定向后初始化单元中对时钟的分配出来问题?
李肯陪你玩赚嵌入式
2021-11-07
从你描述的现象上看,跟RTOS系统关系不大,最好还是集中排查硬件SPI的配置。 如果可以建议,使用bootloader+无RTOS的APP直接驱动下SPI屏幕,看情况如何。 你的问题描述中提到了`中断向量重定向,结果一打开中断向量重定向,屏幕刷新就慢了`, 这里非常可疑,会不会这里重定向的过程中,动到了SPI相关的配置? 使用bootloader+无RTOS的APP把中断重定向的改动,确认不会影响到SPI,再往更下一步进行排查。
1.1k
ball_2020
BBB的SPI驱动
求个SPI上挂两个或多个设备的使用例子
SPI设备有个bug
SPI驱动
请教rt_spi_configure函数理解
SPI FLASH挂载的问题
SPI-FLASH 文件系统 SPIFFS
求助一个完整的 spi flash 驱动
关于同时使用文件系统与SPI FLASH的问题
