SConscript
scons脚本
如何编写scons脚本让生成的目标文件在build文件夹下?
发布于 2021-11-08 10:58:39 浏览:1248
[tocm] 如图,生成的.o 文件在源码同一个文件夹下了,但是其它的文件夹的源码生成的.o却是在build文件夹下。想请教一下怎么修改 ![image.png](https://oss-club.rt-thread.org/uploads/20211108/7499297caf5eab85ffd1032ab26d4b2c.png) 这是对应该问价夹的 scons脚本 ```python import rtconfig from building import * cwd = GetCurrentDir() # add the general drivers. src = Glob('drv_common.c') if GetDepend(['RT_USING_PIN']): src += Glob('drv_gpio.c') if GetDepend(['RT_USING_SERIAL']): if GetDepend(['RT_USING_SERIAL_V2']): src += Glob('drv_usart_v2.c') else: src += Glob('drv_usart.c') if GetDepend(['RT_USING_HWTIMER']): src += Glob('drv_hwtimer.c') if GetDepend(['RT_USING_PWM']): Glob('drv_pwm.c') if GetDepend(['RT_USING_SPI']): src += Glob('drv_spi.c') if GetDepend(['RT_USING_QSPI']): Glob('drv_qspi.c') if GetDepend(['RT_USING_I2C', 'RT_USING_I2C_BITOPS']): if GetDepend('BSP_USING_I2C1') or GetDepend('BSP_USING_I2C2') or GetDepend('BSP_USING_I2C3') or GetDepend('BSP_USING_I2C4'): Glob('drv_soft_i2c.c') if GetDepend(['BSP_USING_ETH', 'RT_USING_LWIP']): Glob('drv_eth.c') if GetDepend(['RT_USING_ADC']): src += Glob('drv_adc.c') if GetDepend(['RT_USING_DAC']): src += Glob('drv_dac.c') if GetDepend(['RT_USING_CAN']): src += Glob('drv_fdcan.c') if GetDepend(['RT_USING_PM', 'SOC_SERIES_STM32L4']): src += Glob('drv_pm.c') src += Glob('drv_lptim.c') if GetDepend('BSP_USING_SDRAM'): src += Glob('drv_sdram.c') if GetDepend('BSP_USING_LCD'): src += Glob('drv_lcd.c') if GetDepend('BSP_USING_LCD_MIPI'): src += Glob('drv_lcd_mipi.c') if GetDepend('BSP_USING_ONCHIP_RTC'): src += Glob('drv_rtc.c') if GetDepend(['BSP_USING_ON_CHIP_FLASH', 'SOC_SERIES_STM32G0']): src += Glob('drv_flash/drv_flash_g0.c') if GetDepend(['BSP_USING_ON_CHIP_FLASH', 'SOC_SERIES_STM32F0']): src += Glob('drv_flash/drv_flash_f0.c') if GetDepend(['BSP_USING_ON_CHIP_FLASH', 'SOC_SERIES_STM32F1']): src += Glob('drv_flash/drv_flash_f1.c') if GetDepend(['BSP_USING_ON_CHIP_FLASH', 'SOC_SERIES_STM32F2']): src += Glob('drv_flash/drv_flash_f2.c') if GetDepend(['BSP_USING_ON_CHIP_FLASH', 'SOC_SERIES_STM32F4']): src += Glob('drv_flash/drv_flash_f4.c') if GetDepend(['BSP_USING_ON_CHIP_FLASH', 'SOC_SERIES_STM32F7']): src += Glob('drv_flash/drv_flash_f7.c') if GetDepend(['BSP_USING_ON_CHIP_FLASH', 'SOC_SERIES_STM32L4']): src += Glob('drv_flash/drv_flash_l4.c') if GetDepend(['BSP_USING_ON_CHIP_FLASH', 'SOC_SERIES_STM32H7']): src += Glob('drv_flash/drv_flash_h7.c') if GetDepend(['BSP_USING_ON_CHIP_FLASH', 'SOC_SERIES_STM32WB']): src += Glob('drv_flash/drv_flash_wb.c') if GetDepend('RT_USING_HWCRYPTO'): src += Glob('drv_crypto.c') if GetDepend(['BSP_USING_WDT']): src += Glob('drv_wdt.c') if GetDepend(['BSP_USING_SDIO']): src += Glob('drv_sdio.c') if GetDepend(['BSP_USING_USBD']): src += Glob('drv_usbd.c') if GetDepend(['BSP_USING_PULSE_ENCODER']): src += Glob('drv_pulse_encoder.c') if GetDepend(['BSP_USING_USBH']): src += Glob('drv_usbh.c') path = [cwd] path += [cwd + '/config'] if GetDepend('BSP_USING_ON_CHIP_FLASH'): path += [cwd + '/drv_flash'] group = DefineGroup('Stm32Driver', src, depend = [''], CPPPATH = path) Return('group') ```
chenyaxing
2021-11-08
泥上偶然留指爪,鸿飞那复计东西。
VariantDir 这个接口应该是你需要的 ref:https://www.scons.org/doc/3.1.2/HTML/scons-user.html ![image.png](https://oss-club.rt-thread.org/uploads/20211108/b1f2e616535ec00e4403e2d43de1e4ca.png.webp) ![image.png](https://oss-club.rt-thread.org/uploads/20211108/965828e1fa325d6a0696fc8826e3605f.png.webp)
2021-11-08
Hi @myLLgf :我曾经也有这个疑问: 你可以试下在下面的代码中加入如下修改。 比如在bsp的Sconstruct的代码如下 ```python objs.extend(SConscript(os.path.join(libraries_path_prefix, 'drivers', 'SConscript'))) # include cmsis objs.extend(SConscript(os.path.join(libraries_path_prefix, 'cmsis', 'SConscript'))) ``` 修改如下: ```python objs.extend(SConscript(os.path.join(libraries_path_prefix, 'drivers', 'SConscript'),variant_dir='build/drivers')) # include cmsis objs.extend(SConscript(os.path.join(libraries_path_prefix, 'cmsis', 'SConscript'),variant_dir='build/cmsis')) ``` 具体的可以根据自己的bsp下面做对应的修改。这样的话,编译后的.o文件会被放到build目录下面
李肯陪你玩赚嵌入式
2021-11-08
找了**rt-thread/bsp/stm32/libraries/HAL_Drivers/SConscript**比对了下,你驱动`Glob`试试看? ![image.png](https://oss-club.rt-thread.org/uploads/20211108/e492c4f927e8a7014bb3e9ea7147d543.png.webp)
myLLgf
2021-11-09
感谢各位的帮助!根目录下的 sconstruct 文件中 ``` # include libraries objs.extend(SConscript(os.path.join(libraries_path_prefix, stm32_library, 'SConscript'))) # include drivers objs.extend(SConscript(os.path.join(libraries_path_prefix, 'HAL_Drivers', 'SConscript'))) ``` 这两行可以不要, 在 Library 文件夹里加个 sconsscript 把子文件夹的脚本自动添加 objs 就行了 ``` import os from building import * cwd = GetCurrentDir() objs = [] list = os.listdir(cwd) for d in list: path = os.path.join(cwd, d) if os.path.isfile(os.path.join(path, 'SConscript')): objs = objs + SConscript(os.path.join(d, 'SConscript')) Return('objs') ``` 这样生成的目标文件最寻了 building.py 里的规则,都在build目录下
charlown.cai
2021-11-09
试了一下,对于startup.s/stratup.S依然会在库里面生成,折中的办法就是将borad/sconscript判断使用的startup语句移到库中的sconscript实现: ``` path = [ cwd + '/CMSIS', cwd + '/CMSIS/WCH/CH32F10x/Include', cwd + '/StdPeriph_Driver/inc'] if rtconfig.CROSS_TOOL == 'keil': src += ['CMSIS/WCH/CH32F10x/Source/ARM/startup_ch32f10x.s'] if rtconfig.CROSS_TOOL == 'gcc': src += ['CMSIS/WCH/CH32F10x/Source/GCC/startup_ch32f10x.S'] group = DefineGroup('ch32f10x_lib', src, depend = [''], CPPPATH = path) Return('group') ``` 这样的话就可以,我是用ch32测试的
1.2k
myLLgf
RTT-Studio生成的工程,子目录没有SConscript文件
DefineGroup中如何增加文件夹中所有lib文件
使用SConscript生成IAR工程时怎么添加分级目录?
关于rtt下的头文件包含问题
scons的使用问题
ENV工具构建MDK5报错ParseError
SConscript添加.a文件,加不上!
rt-thread studio,SConscript问题
请教自定义工程结构的思路
sconscript中的remove_components是在哪里定义
