UFFS
uffs文件系统报错写不进去数据
发布于 2021-11-08 19:09:20 浏览:759
/** * get a page buffer * \param[in] dev uffs device * \param[in] type dir, file or data ? * \param[in] node node on the tree * \param[in] page_id page_id * \param[in] oflag the open flag of current file/dir object * \return return the buffer if found in buffer list, if not found in * buffer list, it will get a free buffer, and load data from flash. * return NULL if not free buffer. */ uffs_Buf *uffs_BufGetEx(struct uffs_DeviceSt *dev, u8 type, TreeNode *node, u16 page_id, int oflag) { uffs_Buf *buf; u16 parent, serial, block, page; uffs_BlockInfo *bc; switch (type) { case UFFS_TYPE_DIR: parent = node->u.dir.parent; serial = node->u.dir.serial; block = node->u.dir.block; break; case UFFS_TYPE_FILE: parent = node->u.file.parent; serial = node->u.file.serial; block = node->u.file.block; break; case UFFS_TYPE_DATA: parent = node->u.data.parent; serial = node->u.data.serial; block = node->u.data.block; break; default: uffs_Perror(UFFS_MSG_SERIOUS, "unknown type"); return NULL; } buf = uffs_BufFind(dev, parent, serial, page_id); if (buf) { buf->ref_count++; return buf; } buf = _FindFreeBuf(dev); if (buf == NULL) { uffs_BufFlushMostDirtyGroup(dev); buf = _FindFreeBuf(dev); if (buf == NULL) { uffs_Perror(UFFS_MSG_SERIOUS, "no free page buf!"); return NULL; } /* Note: if uffs_BufFlushMostDirtyGroup() flush the same block as we'll write to, * the block will be changed to a new one! (and the content of 'node' is changed). * So here we need to update block number from the new 'node'. */ switch (type) { case UFFS_TYPE_DIR: block = node->u.dir.block; break; case UFFS_TYPE_FILE: block = node->u.file.block; break; case UFFS_TYPE_DATA: block = node->u.data.block; break; default: uffs_Perror(UFFS_MSG_SERIOUS, "unknown type"); return NULL; } } bc = uffs_BlockInfoGet(dev, block); if (bc == NULL) { uffs_Perror(UFFS_MSG_SERIOUS, "Can't get block info!"); return NULL; } page = uffs_FindPageInBlockWithPageId(dev, bc, page_id); if (page == UFFS_INVALID_PAGE) { uffs_BlockInfoPut(dev, bc); uffs_Perror(UFFS_MSG_SERIOUS, "can't find right page ? block %d page_id %d", bc->block, page_id); return NULL; } page = uffs_FindBestPageInBlock(dev, bc, page); if (!uffs_Assert(page != UFFS_INVALID_PAGE, "got an invalid page?\n")) return NULL; uffs_BlockInfoPut(dev, bc); buf->mark = UFFS_BUF_EMPTY; buf->type = type; buf->parent = parent; buf->serial = serial; buf->page_id = page_id; if (UFFS_FLASH_HAVE_ERR(uffs_FlashReadPage(dev, block, page, buf, oflag & UO_NOECC ? U_TRUE : U_FALSE))) { uffs_Perror(UFFS_MSG_SERIOUS, "can't load page from flash !"); return NULL; } buf->data_len = TAG_DATA_LEN(GET_TAG(bc, page)); buf->mark = UFFS_BUF_VALID; buf->ref_count++; _MoveNodeToHead(dev, buf); return buf; } 日志打印结果:pbuf: can't find right page ? block 52 page_id 63 fs : can't get buffer ?
2021-11-08
什么硬件 flash ?驱动有 bug 吧
759
Tomato_E
【文件系统】目录查询
文件系统Posix 接口 的close API疑问
SD卡连续读写文件报错
文件系统挂载断言机制
文件系统是否支持挂载NFS网络文件系统
文件系统挂载失败!!!
dfs_filesystem_lookup() 返回NULL
webnet 是否可以做全动态网页,使用内存池来加快速度
“文件系统装在表”报错
