ftp
ftp上传文件有时成功,有时不成功
发布于 2021-12-01 10:51:47 浏览:863
我这个ftp上传文件有时成功,但也比较慢,有时却不成功,TYPE == TYPE_A void command_put(char *filename) { int infile; unsigned char databuf[FILEBUF_SIZE] = ""; int bytes=0, bytessend = 0; infile = open(filename,O_RDONLY); if(infile == 0) { rt_kprintf("fopen() failed"); //close(data_sock); return; } if(command_port() == -1) return; send_msg("STOR", filename, 1); z = lwip_read(server_sock, buffer, sizeof(buffer)); buffer[z-2] = 0; rt_kprintf("%s\n", buffer); while((bytes = read(infile, databuf, FILEBUF_SIZE)) > 0) { rt_kprintf("read infile\n"); rt_kprintf("bytes = %d\n", bytes); rt_kprintf("TYPE%d\n", TYPE); if(TYPE == TYPE_A) { rt_kprintf("lwip_write TYPE_A\n"); //replace((char *)databuf, "\r\n", "\n", FILEBUF_SIZE-1); //replace((char *)databuf, "\n", "\r\n", FILEBUF_SIZE-1); lwip_write(data_sock, databuf, sizeof(databuf)); } else if(TYPE == TYPE_I) { rt_kprintf("lwip_write TYPE_I\n"); lwip_write(data_sock, (const char *)databuf, bytes); } bytessend += bytes; memset(&databuf, 0, FILEBUF_SIZE); } memset(&databuf, 0, FILEBUF_SIZE); rt_kprintf("close(infile)\n"); close(infile); lwip_close(data_sock); rt_kprintf("lwip_read server_sock\n"); z = lwip_read(server_sock, buffer, sizeof(buffer)); buffer[z-2] = 0; rt_kprintf("%s\n", buffer); rt_kprintf("%d bytes send\n", bytessend); return; }
2021-12-01
你这问题有点儿多啊,没记错的话,我建议过你测试板子稳定性,还有测试网卡,测试 lwip。单独写个简单的收发功能,回显的也成,长时间跑一下,跑一天两天的。 然后逐步添加应用,基础环境没安定好,就去调试复杂应用,能确定是应用的代码原因呢还是底层的原因呢?
863
hbq19891025
75
rt_thread有基于lwip的ftp客户端的相关事例吗。
请教用模块内置FTP时AT的使用问题
[FTP]求教,FTP客户端的实现,非tftp
pc上ftp 登陆不了art pi的开发板
RTT studio 添加ftp软件包报错重复定义,求教该怎么解决?
errorunknown type name socklen_t'报错如何解决
agile_ftp使用问题
qemu-vexpress-a9的网络ping出现问题
qemu的FTP编译运行后提示栈溢出
qemu的FTP下载文件后找不到了
