printf_格式化输出
rt_kprintf
rt_kprintf 输出有时正常有时导致系统崩溃
发布于 2021-12-22 09:27:40 浏览:970
工具:RT-Thread Studio 系统:rt-thread 4.03 芯片:STM32F407VET6 问题:rt_kprintf 打印一个uint32 格式数据到串口,同一个函数,函数用于计算 GUI 在页面切换时的进入时间和完成时间,最终用rt_kprintf打印两者的差值即耗时。 现象1:用 rt_kprintf 在有的页面是正常的,有的页面会出现系统崩溃。 现象2:把 rt_kprintf 改成 printf 后所有页面都正常输出,没有出现崩溃。 求助:请各位大佬指点迷津,该如何分析问题原因,从而解决使用 rt_kprintf 的问题。 崩溃信息: ``` [09:15:10.708]收←◆psr: 0x610f0000 r00: 0x0000002c r01: 0x0000013f r02: 0x00000011 r03: 0x014ba178 r04: 0x0000deb8 r05: 0xdeadbeef r06: 0xdeadbeef r07: 0x2000a148 r08: 0xdeadbeef r09: 0xdeadbeef r10: 0xdeadbeef r11: 0xdeadbeef r12: 0xffffffff lr: 0x0800e383 pc: 0x0800dd24 hard fault on thread: hci_gui_ thread pri status sp stack size max used left tick error -------- --- ------- ---------- ---------- ------ ---------- --- hci_gui_ 8 running 0x00000138 0x00000bb8 12% 0x00000004 000 hci_gui_ 9 ready 0x00000148 0x000007d0 16% 0x00000032 -02 button_a 9 ready 0x000000e8 0x000001f4 64% 0x0000000a 000 tshell 20 suspend 0x000000cc 0x00001000 05% 0x00000009 000 tidle0 31 ready 0x00000064 0x00000100 45% 0x00000001 000 timer 4 suspend 0x00000080 0x00000200 25% 0x00000009 000 main 10 ready 0x00000170 0x00000800 17% 0x00000002 -02 FPU active! bus fault: SCB_CFSR_BFSR:0x82 PRECISERR SCB->BFAR:014BA17A ``` 代码: ```c static void hci_gui_updata_thread_entry(void *param) { rt_thread_mdelay(1000); /* 延迟1秒开启显示 */ hci_main_menu(); /* 先显示主菜单 */ rt_tick_t time_s = 0; rt_tick_t time_e = 0; uint8_t t_data = 10; while(1) { rt_sem_take(&rx_sem_hci_set_refresh, RT_WAITING_FOREVER); time_s = rt_tick_get(); switch (Hci_con_Menu.page) { case MAIN_MENU_PAGE: hci_main_menu(); break; case MAIN_MENU_SET1: hci_set_menu_1(); break; case MAIN_MENU_SET2: hci_set_menu_2(); break; case MAIN_MENU_SET3: hci_set_menu_3(); break; default: hci_main_menu(); break; } time_e = rt_tick_get(); time_e = time_e - time_s; printf("time %d \r\n",time_e); //rt_kprintf("time %d \r\n",time_e); // rt_kprintf("程序耗时 = %d \r\n",t_data); } ```
2021-12-22
学以致用
是不是rt_kprintf中的中文引起的?改成英文试试
970
yutian0606
rt_kprintf问题,拔掉串口系统就不运行了么?
rt_kprintf打印异常
开启C++功能后,rt_kprintf和单步调试功能无法使用
大家有什么好用的方法开关串口打印吗
rt_kprintf 格式描述符
怎么实现printf函数打印浮点数?
rt_kprintf串口打印信息有时出现乱码,有时候又是正常的
GD32E230k开发板,打开终端窗口中最后一行是这样的,是什么问题,怎么解决?
rt_thread studio rt_kprintf输出中文乱码?
关于rt_kprintf无法显示浮点数
