easyflash
STM32F429
STM32f4移植easyflash分配env空间不足的问题
发布于 2022-01-13 14:25:00 浏览:1169
移植完了FAL,用命令行,把easyflash的分区读写擦都试过了,没有问题。fal bench也是正常的。 增加上easyflash后,并增加初始化代码,显示env分配空间不足。 ``` \ | / - RT - Thread Operating System / | \ 4.0.3 build Jan 13 2022 2006 - 2020 Copyright by rt-thread team [I/sal.skt] Socket Abstraction Layer initialize success. [D/FAL] (fal_flash_init:63) Flash device | stm32f4_onchip | addr: 0x08000000 | len: 0x00200000 | blk_size: 0x00020000 |initialized finish. [I/FAL] ==================== FAL partition table ==================== [I/FAL] | name | flash_dev | offset | length | [I/FAL] ------------------------------------------------------------- [I/FAL] | bl | stm32f4_onchip | 0x00000000 | 0x00020000 | [I/FAL] | app1 | stm32f4_onchip | 0x00020000 | 0x000e0000 | [I/FAL] | easyflash | stm32f4_onchip | 0x00100000 | 0x00020000 | [I/FAL] | app2 | stm32f4_onchip | 0x00120000 | 0x000e0000 | [I/FAL] ============================================================= [I/FAL] RT-Thread Flash Abstraction Layer (V0.5.0) initialize success. [I/at.clnt] AT client(V1.3.1) on device uart3 initialize success. msh >[I/at.dev.ec200x] ec200x device network initialize success. msh >user_easy_flash [Flash] (../packages/EasyFlash-v4.1.0/src/ef_env.c:1818) ENV start address is 0x00000000, size is 8192 bytes. [Flash] Warning: Sector header check failed. Format this sector (0x00000000). [D/fal_flash_port] erase done: addr (0x08100000), size 4096 [Flash] Warning: Sector header check failed. Format this sector (0x00001000). [D/fal_flash_port] erase done: addr (0x08101000), size 4096 [Flash] Warning: All sector header check failed. Set it to default. [D/fal_flash_port] erase done: addr (0x08100000), size 4096 [D/fal_flash_port] erase done: addr (0x08101000), size 4096 [Flash] (../packages/EasyFlash-v4.1.0/src/ef_env.c:1059) Trigger a GC check after alloc ENV failed. [Flash] (../packages/EasyFlash-v4.1.0/src/ef_env.c:1196) Warning: Alloc an ENV (size 46) failed when new ENV. Now will GC then retry. [Flash] (../packages/EasyFlash-v4.1.0/src/ef_env.c:1264) The remain empty sector is 1, GC threshold is 1. [Flash] (../packages/EasyFlash-v4.1.0/src/ef_env.c:1059) Trigger a GC check after alloc ENV failed. [Flash] (../packages/EasyFlash-v4.1.0/src/ef_env.c:1264) The remain empty sector is 0, GC threshold is 1. [Flash] EasyFlash V4.1.0 is initialize success. [Flash] You can get the latest version on https://github.com/armink/EasyFlash . [D/main] =============================================== [D/main] The system now boot 1 times [D/main] =============================================== ``` 然后我命令行挂载easyflash的分区,读一下flash,全是ff. 自己用命令行写,再读出来是没问题的。 ``` msh >fal write 0 1 2 3 4 5 Write data success. Start from 0x00000000, size is 5. Write data: 1 2 3 4 5 . msh >fal read 32 Usage: fal read addr size - read 'size' bytes starting at 'addr'. msh >fal read 0 32 Read data success. Start from 0x00000000, size is 32. The data is: Offset (h) 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F [00000000] 01 02 03 04 05 FF FF FF FF FF FF FF FF FF FF FF ................ [00000010] FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ```
2022-01-13
空白的flash扇区内容是0xFF是对的呀。
2022-01-13
嵌入式
因为你没有贴上你的代码,可以参考这个博客来对照一下你的代码[FAL分区管理与easyflash变量管理](https://blog.csdn.net/m0_37621078/article/details/102689903)
1.2k
ZsjLoveStudy
关于FAL移植
添加fal软件包之后编译出现错误,求助!
FAL驱动移植&构建脚本问题
帮我看一下这样分区会不会冲突??
EasyFlash 4.0疑似出BUG
疑似FAL日志输出与DFS冲突??
fal软件包偏移量大于等于当前分区的大小会报错
为什么片内Flash总是写失败?
片上flash的文件系统的建立
