[文件系统] 文件写的例子
发布于 2010-02-12 00:12:16 浏览:8854
这几天几位同学来问RT-Thread中文件读写接口是如何的,因为要写入到SD卡中,试过好几次都有问题,不知道写文件的操作应该如何进行,下面用一个例子解释文件写的操作流程(readwrite.c例程,可在STM3210目录下的project_filesystem工程使用)。这个例程建议使用ELM FatFs文件系统,因为以后ELM FatFs文件系统会逐渐取代以前的EFSL文件系统: ``` #include
/* TEST_FN是测试用的文件名,采用宏定义方便修改 */ #define TEST_FN "/test.dat" /* 保存测试用到的数据,这里采用全局类型的变量以避免占用栈空间 */ static char test_data[120], buffer[120]; /* 文件读写测试 */ void readwrite(const char* filename) { int fd; int index, length; /* 只写,创建和截零 模式打开 */ fd = open(TEST_FN, O_WRONLY | O_CREAT | O_TRUNC, 0); if (fd < 0) { rt_kprintf("open file for write failed "); return; } /* 准备写入数据 */ for (index = 0; index < sizeof(test_data); index ++) { test_data[index] = index + 27; } /* 写入数据 */ length = write(fd, test_data, sizeof(test_data)); if (length != sizeof(test_data)) { rt_kprintf("write data failed "); close(fd); return; } /* 关闭文件 */ close(fd); /* 只写并在末尾添加打开 */ fd = open(TEST_FN, O_WRONLY | O_CREAT | O_APPEND, 0); if (fd < 0) { rt_kprintf("open file for append write failed "); return; } length = write(fd, test_data, sizeof(test_data)); if (length != sizeof(test_data)) { rt_kprintf("append write data failed "); close(fd); return; } /* 关闭文件 */ close(fd); /* 只读打开进行数据校验 */ fd = open(TEST_FN, O_RDONLY, 0); if (fd < 0) { rt_kprintf("check: open file for read failed "); return; } length = read(fd, buffer, sizeof(buffer)); if (length != sizeof(buffer)) { rt_kprintf("check: read file failed "); close(fd); return; } for (index = 0; index < sizeof(test_data); index ++) { if (test_data[index] != buffer[index]) { rt_kprintf("check: check data failed at %d ", index); close(fd); return; } } length = read(fd, buffer, sizeof(buffer)); if (length != sizeof(buffer)) { rt_kprintf("check: read file failed "); close(fd); return; } for (index = 0; index < sizeof(test_data); index ++) { if (test_data[index] != buffer[index]) { rt_kprintf("check: check data failed at %d ", index); close(fd); return; } } /* 检查数据完毕,关闭文件 */ close(fd); /* 打印结果 */ rt_kprintf("read/write done. "); } #ifdef RT_USING_FINSH #include
FINSH_FUNCTION_EXPORT(readwrite, perform file read and write test); #endif ``` 上面的例子中和写相关的主要是两个open函数,但是使用的参数并不相同。 第一个open: fd = open(TEST_FN, O_WRONLY | O_CREAT | O_TRUNC, 0); 其中 O_WRONLY指明这是一个写入方式的打开模式; O_CREAT指明如果文件不存在则创建文件 O_TRUNC指明如果文件存在,则把文件的长度归零,然后打开 最后的参数0是为了和POSIX标准兼容的,原意指明创建的模式(读、写、可执行等等),因为RT-Thread不支持多用户系统,所以默认忽略这个参数。 第二个open: fd = open(TEST_FN, O_WRONLY | O_CREAT | O_APPEND, 0); 和第一个open相比,只是把O_TRUNC参数更改为O_APPEND,即更改为打开后,如果再进行写入,将从文件的末尾位置开始写。 这两种使用方法能够覆盖大多数使用情况,如果总是记录新的文件,那么用前一种方式打开文件然后写入。如果是保留老的记录,仅把新的记录添加到文件末尾,那么使用第二种即可。
gzc1017
2010-02-15
谢谢您的回复!期望RTT在新的一年里创造新的辉煌!更多的人支持和运用RTT。
ljt8015
2010-03-15
文件系统不支持长文件名 我通过ftp拷贝一个 文件夹 也不行,只能拷贝单个文件!~~~~
pdm208
2010-06-29
我也是用这个例子的,可是文件的打开即open函数返回的值fp总是小于0,文件总是打不开啊?我不知道问题存在哪里,SD卡驱动以及文件系统初始化都通过了,麻烦你给我解答一下,谢谢!!!
2010-06-29
>我也是用这个例子的,可是文件的打开即open函数返回的值fp总是小于0,文件总是打不开啊?我不知道问题存在哪里,SD卡驱动以及文件系统初始化都通过了,麻烦你给我解答一下,谢谢!!! --- finsh里面执行 ``` finsh>>ls("/") ``` 看看结果如何! 现在使用ELMFAT如果文件系统非法也可以初始化成功的.所以不能保证驱动完全OK.虽然显示初始化成功了.
pdm208
2010-07-05
执行fd = open(TEST_FN, O_WRONLY | O_CREAT | O_TRUNC, 0);这个语句时,调用了chk_mounted()函数,会出现寻找不到有效的fat扇区if (fmt || LD_WORD(fs->win+BPB_BytsPerSec) != SS(fs))/* No valid FAT patition is found */ return FR_NO_FILESYSTEM; 这是原因造成的啊?麻烦帮我解答一下,谢谢!
2010-07-05
应该是驱动的问题, ELM FatFs正如前面aozima说的,它并不对文件系统做严格一些的检查就认为文件系统装载成功。而实际上,可能并没检查出来文件系统是完整的。所以,你可以像aozima说的那个步骤: finsh>> ls("/") 看看是否能够列出文件系统根目录,如果未列出来,那么驱动还未做好还存在问题。
pdm208
2010-07-05
可是SD卡的驱动是文件系统里自带的啊?我不知道驱动的问题到底出在哪里?我是这方面的初学者,麻烦帮帮忙!
2010-07-05
你的硬件平台? 一般驱动是和具体的硬件平台相关的,即使是RT-Thread的发布也是针对某一具体的硬件平台,且驱动并不是文件系统的一部分。硬件配置不同,那么驱动肯定需要做相应的改动。
pdm208
2010-07-06
我的开发板上单片机用的是STM32F103ZE,调试用的工程是RT_THREAD STM3210里的文件工程,我不知道问题会出在哪里?
xiao苦
2010-07-06
stm32官方驱动有点小问题呵,但是应该是可以用的。 但是我写的时候发现写的内容后面多出很多乱码呵。 也不知道什么什么rt-thread会更正下。另外,希望能有个独立fats系统。一直跟rt挂钩其实挺麻烦的
8.9k
414
5913
70
